單片機源文件萬年歷
康1314
2018-5-10 11:16
單片機源文件萬年歷
#include<AT89X51.h>
unsigned char code dispcode[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x40};//共陰極
unsigned char dispbitcode[]={0x00,0x21,0x42,0x63,0x84,0xA5,0xC6,0xE7};//管子的選擇
unsigned char dispbuf[8]={0,0,10,0,0,10,2,1}; //16為顯示間斷號符
unsigned char dispbym[8]={1,2,7,0,6,0,0,2};
unsigned char dispbitcnt;
unsigned char second;
unsigned char minite;
unsigned char hour;
unsigned char day;
unsigned char month;
unsigned char yearh;
unsigned char yearl;
unsigned int tcnt;
unsigned char mstcnt;
unsigned char i,j;
void main(void)
TMOD=0x02; //設置模式為定時器T0的模式2 (8位自動重裝計數初值的計數值)
TH0=0x06; //設置計數器初值,靠TH0存儲重裝的計數值X0=256-250=6
TL0=0x06;
TR0=1; //啟動T0
ET0=1; //開啟定時器T0中斷允許
EA=1; //開啟中斷總控制
yearh=20;
yearl=6;
month=7;
day=21;
hour=12; //初始值為12:00:00
if(P0_0==0) //掃描秒鐘按鈕
for(i=5;i>0;i--) //按鈕抖動消除
for(j=248;j>0;j--); //計時
if(P0_0==0)
second++;
if(second==60)
second=0;
dispbuf[0]=second%10;
dispbuf[1]=second/10;
while(P0_0==0);
if(P0_1==0) //掃描分鐘按鈕
for(i=5;i>0;i--)
for(j=248;j>0;j--);
if(P0_1==0)
minite++;
if(minite==60)
minite=0;
dispbuf[3]=minite%10;
dispbuf[4]=minite/10;
while(P0_1==0);
if(P0_2==0) //掃描時鐘按鈕
for(i=5;i>0;i--)
for(j=248;j>0;j--);
if(P0_2==0)
hour++;
if(hour==24)
hour=0;
dispbuf[6]=hour%10;
dispbuf[7]=hour/10;
while(P0_2==0);
if(P0_3==0)
for(i=5;i>0;i--)
for(j=248;j>0;j--);
if(P0_3==0)
day++;
if(month==2&&((yearl==0&&yearh%4==0)||(yearl!=0&&yearl%4==0))&&day==30)day=1;
else if(month==2&&day==29)day=1;
else if((month==4||month==6||month==9||month==11)&&day==31)day=1;
else if(day==32)day=1;
dispbym[0]=day%10;
dispbym[1]=day/10;
while(P0_3==0);
if(P0_4==0)
for(i=5;i>0;i--)
for(j=248;j>0;j--);
if(P0_4==0)
month++;
if(month==13)month=1;
dispbym[2]=month%10;
dispbym[3]=month/10;
while(P0_4==0);
if(P0_5==0)
for(i=5;i>0;i--)
for(j=248;j>0;j--);
if(P0_5==0)
yearl++;
if(yearl==100)
yearl=0;
yearh++;
if(yearh==100)yearh=20;
dispbym[4]=yearl%10;
dispbym[5]=yearl/10;
dispbym[6]=yearh%10;
dispbym[7]=yearh/10;
while(P0_5==0);
void t0(void)interrupt 1 using 0 //t0的中斷程序
mstcnt++;
if(mstcnt==8) //8次250us為2ms,即每隔2ms掃描一個數碼管
mstcnt=0;
P1=dispcode[dispbuf[dispbitcnt]];
P2=dispcode[dispbym[dispbitcnt]];
P3=0xff;
P3=dispbitcode[dispbitcnt]; //管子的選擇
dispbitcnt++;
if(dispbitcnt==8)
dispbitcnt=0;
tcnt++;
if(tcnt==4000) //定時器的定時計數,4000次250us為1秒
tcnt=0;
second++;
if(second==60) //從秒到時層層嵌套,程序較為精練
second=0;
minite++;
if(minite==60)
minite=0;
hour++;
if(hour==24)
hour=0;
day++;
if(day==1)
month++;
if(month==13)
month=1;
yearl++;
if(yearl==100)
yearl=0;
yearh++;
if(yearh==100)
yearh=20;
dispbuf[0]=second%10; //送顯示數據
dispbuf[6]=hour%10;
dispbuf[7]=hour/10;
dispbym[0]=day%10;
dispbym[1]=day/10;
51單片機數碼管顯示萬年歷proteus仿真.rar
2018-5-10 11:15 上傳
91.81 KB, 下載次數: 3, 下載積分: 黑幣 -5
