單片機密碼鎖仿真圖和源碼
咿咿
2018-5-6 17:08
單片機密碼鎖仿真圖和源碼
密碼鎖仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
(17.35 KB, 下載次數: 45)
2018-5-6 18:11 上傳
(17.59 KB, 下載次數: 36)
2018-5-6 18:11 上傳
//包含頭文件
#include <REG51.h>
#include<intrins.h>
//宏定義
#define LCM_Data P0 //將P0口定義為LCM_Data
//1602的控制腳
sbit lcd1602_rs=P2^5;
sbit lcd1602_rw=P2^6;
sbit lcd1602_en=P2^7;
sbit Scl=P3^4; //24C02串行時鐘
sbit Sda=P3^5; //24C02串行數據
sbit ALAM = P2^1; //報警
sbit KEY = P3^6; //開鎖
bit pass=0; //密碼正確標志
bit ReInputEn=0; //重置輸入允許標志
bit s3_keydown=0; //3秒按鍵標志位
bit key_disable=0; //鎖定鍵盤標志
unsigned char countt0,second; //t0中斷計數器,秒計數器
void Delay5Ms(void); //聲明延時函數
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7}; //控盤掃描控制表
//液晶顯示數據數組
unsigned char code start_line[] = {"password: "};
unsigned char code name[] = {"===Coded Lock==="}; //顯示名稱
unsigned char code Correct[] = {" correct "}; //輸入正確
unsigned char code Error[] = {" error "}; //輸入錯誤
unsigned char code codepass[] = {" pass "};
unsigned char code LockOpen[] = {" open "}; //OPEN
unsigned char code SetNew[] = {"SetNewWordEnable"};
unsigned char code Input[] = {"input: "}; //INPUT
unsigned char code ResetOK[] = {"ResetPasswordOK "};
unsigned char code initword[] = {"Init password..."};
unsigned char code Er_try[] = {"error,try again!"};
unsigned char code again[] = {"input again "};
unsigned char InputData[6]; //輸入密碼暫存區
unsigned char CurrentPassword[6]={1,3,1,4,2,0}; //管理員密碼(只可在程序中修改)
unsigned char TempPassword[6];
unsigned char N=0; //密碼輸入位數記數
unsigned char ErrorCont; //錯誤次數計數
unsigned char CorrectCont; //正確輸入計數
unsigned char ReInputCont; //重新輸入計數
unsigned char code initpassword[6]={0,0,0,0,0,0}; //輸入管理員密碼后將密碼初始為000000
//=====================5ms延時==============================
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//===================400ms延時==============================
void Delay400Ms(void)
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
//================================24C02========================================================
void mDelay(uint t) //延時
uchar i;
while(t--)
for(i=0;i<125;i++)
void Nop(void) //空操作
_nop_(); //僅作延時用一條語句大約1us
_nop_();
_nop_();
_nop_();
/*****24c02程序參照24c02時序圖*****/
/*起始條件*/
void Start(void)
Sda=1;
Scl=1;
Nop();
Sda=0;
Nop();
/*停止條件*/
void Stop(void)
Sda=0;
Scl=1;
Nop();
Sda=1;
Nop();
/*應答位*/
void Ack(void)
Sda=0;
Nop();
Scl=1;
Nop();
Scl=0;
/*反向應答位*/
void NoAck(void)
Sda=1;
Nop();
Scl=1;
Nop();
Scl=0;
/*發送數據子程序,Data為要求發送的數據*/
void Send(uchar Data)
uchar BitCounter=8;
uchar temp;
do
temp=Data; //將待發送數據暫存temp
Scl=0;
Nop();
if((temp&0x80)==0x80) //將讀到的數據&0x80
Sda=1;
Sda=0;
Scl=1;
temp=Data<<1; //數據左移
Data=temp; //數據左移后重新賦值Data
BitCounter--; //該變量減到0時,數據也就傳送完成了
while(BitCounter); //判斷是否傳送完成
Scl=0;
/*讀一字節的數據,并返回該字節值*/
uchar Read(void)
uchar temp=0;
uchar temp1=0;
uchar BitCounter=8;
Sda=1;
do
Scl=0;
Nop();
Scl=1;
Nop();
if(Sda) //數據位是否為1
temp=temp|0x01; //為1 temp的最低位為1(|0x01,就是將最低位變為1)
else //如果為0
temp=temp&0xfe; //temp最低位為0(&0xfe(11111110)最低位就是0)
if(BitCounter-1) //BitCounter減1后是否為真
temp1=temp<<1; //temp左移
temp=temp1;
BitCounter--; //BitCounter減到0時,數據就接收完了
while(BitCounter); //判斷是否接收完成
return(temp);
void WrToROM(uchar Data[],uchar Address,uchar Num)
uchar i;
uchar *PData;
PData=Data;
for(i=0;i<Num;i++)
Start();
Send(0xa0);
Ack();
Send(Address+i);
Ack();
Send(*(PData+i));
Ack();
Stop();
mDelay(20);
void RdFromROM(uchar Data[],uchar Address,uchar Num)
uchar i;
uchar *PData;
PData=Data;
for(i=0;i<Num;i++)
Start();
Send(0xa0);
Ack();
Send(Address+i);
Ack();
Start();
Send(0xa1);
Ack();
*(PData+i)=Read();
Scl=0;
NoAck();
Stop();
//=======================================LCD1602====================================================
#define yi 0x80 //LCD第一行的初始位置,因為LCD1602字符地址首位D7恒定為1(100000000=80)
#define er 0x80+0x40 //LCD第二行初始位置(因為第二行第一個字符位置地址是0x40)
//----------------延時函數,后面經常調用----------------------
void delay(uint xms)//延時函數,有參函數
uint x,y;
for(x=xms;x>0;x--)
for(y=110;y>0;y--);
//--------------------------寫指令---------------------------
void write_1602com(uchar com)//****液晶寫入指令函數****
lcd1602_rs=0;//數據/指令選擇置為指令
lcd1602_rw=0; //讀寫選擇置為寫
P0=com;//送入數據
delay(1);
lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準備
delay(1);
lcd1602_en=0;//en由高變低,產生下降沿,液晶執行命令
//-------------------------寫數據-----------------------------
void write_1602dat(uchar dat)//***液晶寫入數據函數****
lcd1602_rs=1;//數據/指令選擇置為數據
P0=dat;//送入數據
delay(1);
lcd1602_en=1; //en置高電平,為制造下降沿做準備
delay(1);
lcd1602_en=0; //en由高變低,產生下降沿,液晶執行命令
//-------------------------初始化-------------------------
void lcd_init(void)
write_1602com(0x38);//設置液晶工作模式,意思:16*2行顯示,5*7點陣,8位數據
write_1602com(0x0c);//開顯示不顯示光標
write_1602com(0x06);//整屏不移動,光標自動右移
write_1602com(0x01);//清顯示
//==============將按鍵值編碼為數值=========================
unsigned char coding(unsigned char m)
unsigned char k;
switch(m)
case (0x11): k=1;break;
case (0x21): k=2;break;
case (0x41): k=3;break;
case (0x81): k='A';break;
case (0x12): k=4;break;
case (0x22): k=5;break;
case (0x42): k=6;break;
case (0x82): k='B';break;
case (0x14): k=7;break;
case (0x24): k=8;break;
case (0x44): k=9;break;
case (0x84): k='C';break;
case (0x18): k='*';break;
case (0x28): k=0;break;
case (0x48): k='#';break;
case (0x88): k='D';break;
return(k);
//=====================按鍵檢測并返回按鍵值===============================
unsigned char keynum(void)
unsigned char row,col,i;
P1=0xf0;
if((P1&0xf0)!=0xf0)
Delay5Ms();
Delay5Ms();
if((P1&0xf0)!=0xf0)
row=P1^0xf0; //確定行線
i=0;
P1=a[i]; //精確定位
while(i<4)
if((P1&0xf0)!=0xf0)
col=~(P1&0xff); //確定列線
break; //已定位后提前退出
i++;
P1=a[i];
return 0;
while((P1&0xf0)!=0xf0);
return (row|col); //行線與列線組合后返回
else return 0; //無鍵按下時返回0
//=======================一聲提示音,表示有效輸入========================
void OneAlam(void)
ALAM=0;
Delay5Ms();
ALAM=1;
//========================二聲提示音,表示操作成功========================
void TwoAlam(void)
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
//========================三聲提示音,表示錯誤========================
void ThreeAlam(void)
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
//=======================顯示提示輸入=========================
void DisplayChar(void)
unsigned char i;
if(pass==1)
//DisplayListChar(0,1,LockOpen);
write_1602com(er); //在二行開始顯示
for(i=0;i<16;i++)
write_1602dat(LockOpen[i]); //顯示open 開鎖成功
if(N==0)
//DisplayListChar(0,1,Error);
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(Error[i]); //顯示錯誤
//DisplayListChar(0,1,start_line);
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(start_line[i]);//顯示開始輸入
//========================重置密碼==================================================
void ResetPassword(void)
unsigned char i;
unsigned char j;
if(pass==0)
pass=0;
DisplayChar(); //顯示錯誤
ThreeAlam(); //沒開鎖時按下重置密碼報警3聲
else //開鎖狀態下才能進行密碼重置程序
if(ReInputEn==1) //開鎖狀態下,ReInputEn置1,重置密碼允許
if(N==6) //輸入6位密碼
ReInputCont++; //密碼次數計數
if(ReInputCont==2) //輸入兩次密碼
for(i=0;i<6;)
if(TempPassword[i]==InputData[i]) //將兩次輸入的新密碼作對比
i++;
else //如果兩次的密碼不同
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(Error[j]); //顯示錯誤Error
ThreeAlam(); //錯誤提示
pass=0; //關鎖
ReInputEn=0; //關閉重置功能,
ReInputCont=0;
DisplayChar();
break;
if(i==6)
//DisplayListChar(0,1,ResetOK);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(ResetOK[j]); //密碼修改成功,顯示
TwoAlam(); //操作成功提示
WrToROM(TempPassword,0,6); //將新密碼寫入24C02存儲
ReInputEn=0;
ReInputCont=0;
CorrectCont=0;
else //輸入一次密碼時
OneAlam();
//DisplayListChar(0, 1, again); //顯示再次輸入一次
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(again[j]); //顯示再輸入一次
for(i=0;i<6;i++)
TempPassword[i]=InputData[i]; //將第一次輸入的數據暫存起來
N=0; //輸入數據位數計數器清零
//=======================輸入密碼錯誤超過三過,報警并鎖死鍵盤======================
void Alam_KeyUnable(void)
P1=0x00;
ALAM=~ALAM; //蜂鳴器一直閃爍鳴響
Delay5Ms();
//=======================取消所有操作============================================
void Cancel(void)
unsigned char i;
unsigned char j;
//DisplayListChar(0, 1, start_line);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(start_line[j]); //顯示開機輸入密碼界面
TwoAlam(); //提示音
for(i=0;i<6;i++)
InputData[i]=0; //將輸入密碼清零
KEY=1; //關閉鎖
ALAM=1; //報警關
pass=0; //密碼正確標志清零
ReInputEn=0; //重置輸入充許標志清零
ErrorCont=0; //密碼錯誤輸入次數清零
CorrectCont=0; //密碼正確輸入次數清零
ReInputCont=0; //重置密碼輸入次數清零
s3_keydown=0;
key_disable=0; //鎖定鍵盤標志清零
N=0; //輸入位數計數器清零
//==========================確認鍵,并通過相應標志位執行相應功能===============================
void Ensure(void)
unsigned char i,j;
RdFromROM(CurrentPassword,0,6); //從24C02里讀出存儲密碼
if(N==6)
if(ReInputEn==0) //重置密碼功能未開啟
for(i=0;i<6;)
if(CurrentPassword[i]==InputData[i]) //判斷輸入密碼和24c02中的密碼是否相同
i++; //相同一位 i就+1
else //如果有密碼不同
ErrorCont++; //錯誤次數++
if(ErrorCont==3) //錯誤輸入計數達三次時,報警并鎖定鍵盤
write_1602com(er);
for(i=0;i<16;i++)
do
Alam_KeyUnable();
while(1);
else //錯誤次數小于3次時,鎖死鍵盤3秒,然后重新可以輸入
TR0=1; //開啟定時
key_disable=1; //鎖定鍵盤
pass=0; //pass位清零
break; //跳出
if(i==6) //密碼輸入對時
CorrectCont++; //輸入正確變量++
if(CorrectCont==1) //正確輸入計數,當只有一次正確輸入時,開鎖
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(LockOpen[j]); //顯示open開鎖畫面
TwoAlam(); //操作成功提示音
KEY=0; //開鎖
pass=1; //置正確標志位
TR0=1; //開啟定時
for(j=0;j<6;j++) //將輸入清除
InputData[i]=0; //開鎖后將輸入位清零
else //當兩次正確輸入時,開啟重置密碼功能
//DisplayListChar(0,1,SetNew);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(SetNew[j]); //顯示重置密碼界面
TwoAlam(); //操作成功提示
ReInputEn=1; //允許重置密碼輸入
CorrectCont=0; //正確計數器清零
else //=========================當第一次使用或忘記密碼時可以用131420對其密碼初始化============
if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
WrToROM(initpassword,0,6); //強制將初始密碼寫入24C02存儲
//DisplayListChar(0,1,initword); //顯示初始化密碼
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(initword[j]); //顯示初始化密碼
TwoAlam(); //成功提示音
Delay400Ms(); //延時400ms
TwoAlam(); //成功提示音
N=0; //輸入位數計數器清零
else //密碼輸入錯誤
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(Error[j]); //顯示錯誤信息
ThreeAlam(); //錯誤提示音
pass=0;
else //當已經開啟重置密碼功能時,而按下開鎖鍵,
//DisplayListChar(0,1,Er_try);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(Er_try[j]); //錯誤,請重新輸入
else //密碼沒有輸入到6位時,按下確認鍵時
write_1602com(er);
for(j=0;j<16;j++)
pass=0;
N=0; //將輸入數據計數器清零,為下一次輸入作準備
//==============================主函數===============================
void main(void)
unsigned char KEY,NUM;
unsigned char i,j;
P1=0xFF; //P1口復位
TMOD=0x11; //定義工作方式
TL0=0xB0;
TH0=0x3C; //定時器賦初值
EA=1; //打開中斷總開關
ET0=1; //打開中斷允許開關
TR0=0; //打開定時器開關
Delay400Ms(); //啟動等待,等LCM講入工作狀態
lcd_init(); //LCD初始化
write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
for(i=0;i<16;i++)
write_1602dat(name[i]);//向液晶屏寫開機畫面
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(start_line[i]);//寫輸入密碼等待界面
write_1602com(er+9); //設置光標位置
write_1602com(0x0f); //設置光標為閃爍
Delay5Ms(); //延時片刻(可不要)
N=0; //初始化數據輸入位數
while(1) //進入循環
if(key_disable==1) //鎖定鍵盤標志為1時
Alam_KeyUnable(); //報警鍵盤鎖
ALAM=1; //關報警
KEY=keynum(); //讀按鍵的位置碼
if(KEY!=0) //當有按鍵按下時
second=0; //秒清零
else //沒有鎖定鍵盤時
NUM=coding(KEY); //根據按鍵的位置將其編碼,編碼值賦值給NUM
switch(NUM) //判斷按鍵值
case ('A'): ; break;
case ('B'): ; break;
case ('C'):
for(i=0;i<16;i++)
if(N>=1) N--; OneAlam(); //按鍵提示音
//DisplayOneChar(6+N,1,'*');
for(j=N;j<16;j++)
write_1602com(er+6+j);
write_1602dat(' ');
…………限于本文篇幅 余下代碼請從51黑下載附件…………
密碼鎖2.zip
(66.84 KB, 下載次數: 40)
2018-5-6 17:07 上傳
我要學51
2018-5-13 00:18
為什么仿真的時候LCD沒有反應啊?
我要學51
2018-5-13 00:18
為什么仿真的時候LCD沒有反應啊?
1443351061
2018-5-18 15:56
這個仿真的結果怎么樣啊
草棚
2018-5-18 17:58
為什么仿真不出來
