Arduino RC522 RFID庫文件源碼資料
WESF
2018-5-4 14:23
(25.32 KB, 下載次數(shù): 81)
2018-5-5 02:06 上傳
RFID實驗源程序如下:
----------------本例程僅供學習使用,未經(jīng)作者允許,不得用于其他用途。-----------
------------------------版權(quán)所有,仿冒必究!-----------------------------------
----------------1.開發(fā)環(huán)境:Arduino IDE-----------------------------------------
----------------2.測試使用開發(fā)板型號:Arduino Leonardo or Arduino UNO R3-------
----------------3.單片機使用晶振:16M------------------------------------------
----------------5.作者:神秘藏寶室---------------------------------------------
#include "RC522.h"
#include <SPI.h>
#define Relay 2
//4 bytes Serial number of card, the 5 bytes is verfiy bytes
unsigned char serNum[5];
void setup()
Serial.begin(9600);
Serial.print("Ilovemcu.taobao.com");
pinMode(Relay,OUTPUT);
SPI.begin();
pinMode(chipSelectPin,OUTPUT); // Set digital pin 10 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(chipSelectPin, LOW); // Activate the RFID reader
pinMode(NRSTPD,OUTPUT); // Set digital Reset , Not Reset and Power-down
MFRC522_Init(); //初始化RFID
void loop()
unsigned char status;
unsigned char str[MAX_LEN];
// Search card, return card types
status = MFRC522_Request(PICC_REQIDL, str);
if (status == MI_OK) //讀取到ID卡時候
// Show card type
//ShowCardType(str);
//Prevent conflict, return the 4 bytes Serial number of the card
status = MFRC522_Anticoll(str);
// str[0..3]: serial number of the card
// str[4]: XOR checksum of the SN.
memcpy(serNum, str, 5);
Serial.print("ID:");
ShowCardID(serNum);
// Check people associated with card ID
unsigned char* id = serNum;
if( id[0]==0xed && id[1]==0x34 && id[2]==0xfa && id[3]==0x95 )
digitalWrite(Relay,HIGH); //打開繼電器
Serial.println("The Host 1!");
else if(id[0]==0x4C && id[1]==0xB3 && id[2]==0x74 && id[3]==0x19)
digitalWrite(Relay,LOW); //繼電器
Serial.println("The Host 2!");
Serial.println("Stranger!");
MFRC522_Halt(); //command the card into sleep mode
delay(100);
lesson38.rar
(6.67 KB, 下載次數(shù): 82)
2018-5-4 14:22 上傳
cc19940410
2018-5-30 23:27
那個,我想問下為什么接入繼電器的時候處于高電平狀態(tài)?
tqlww
2021-12-1 08:26
請問有RFID頭文件嗎
