PCB設計中專業(yè)英譯術語之基材
板兒妹0517
2018-4-28 11:18
PCB設計中專業(yè)英譯術語之基材
PCB設計中專業(yè)英譯術語之基材:
1. 基材:base material
2. 層壓板:laminate
3. 覆金屬箔基材:metal-clad bade material
4. 覆銅箔層壓板:copper-clad laminate (CCL)
5. 單面覆銅箔層壓板:single-sided copper-clad laminate
6. 雙面覆銅箔層壓板:double-sided copper-clad laminate
7. 復合層壓板:composite laminate
8. 薄層壓板:thin laminate
9. 金屬芯覆銅箔層壓板:metal core copper-clad laminate
10. 金屬基覆銅層壓板:metal base copper-clad laminate
11. 撓性覆銅箔絕緣薄膜:flexible copper-clad dielectric film
12. 基體材料:basis material
13. 預浸材料:prepreg
14. 粘結片:bonding sheet
15. 預浸粘結片:preimpregnated bonding sheer
16. 環(huán)氧玻璃基板:epoxy glass substrate
17. 加成法用層壓板:laminate for additive process
18. 預制內(nèi)層覆箔板:mass lamination panel
19. 內(nèi)層芯板:core material
20. 催化板材:catalyzed board ,coated catalyzed laminate
21. 涂膠催化層壓板:adhesive-coated catalyzed laminate
22. 涂膠無催層壓板:adhesive-coated uncatalyzed laminate
23. 粘結層:bonding layer
24. 粘結膜:film adhesive
25. 涂膠粘劑絕緣薄膜:adhesive coated dielectric film
26. 無支撐膠粘劑膜:unsupported adhesive film
27. 覆蓋層:cover layer (cover lay)
28. 增強板材:stiffener material
29. 銅箔面:copper-clad surface
30. 去銅箔面:foil removal surface
31. 層壓板面:unclad laminate surface
32. 基膜面:base film surface
33. 膠粘劑面:adhesive faec
34. 原始光潔面:plate finish
35. 粗面:matt finish
36. 縱向:length wise direction
37. 模向:cross wise direction
38. 剪切板:cut to size panel
39. 酚醛紙質(zhì)覆銅箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper CCL)
40. 環(huán)氧紙質(zhì)覆銅箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper CCL)
41. 環(huán)氧玻璃布基覆銅箔板:epoxide woven glass fabric copper-clad laminates
42. 環(huán)氧玻璃布紙復合覆銅箔板:epoxide cellulose paper core, glass cloth surfaces copper-clad laminates
43. 環(huán)氧玻璃布玻璃纖維復合覆銅箔板:epoxide non woven/woven glass reinforced copper-clad laminates
44. 聚酯玻璃布覆銅箔板:ployester woven glass fabric copper-clad laminates
45. 聚酰亞胺玻璃布覆銅箔板:polyimide woven glass fabric copper-clad laminates
46. 雙馬來酰亞胺三嗪環(huán)氧玻璃布覆銅箔板:bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates
47. 環(huán)氧合成纖維布覆銅箔板:epoxide synthetic fiber fabric copper-clad laminates
48. 聚四乙烯玻璃纖維覆銅箔板:teflon/fiber glass copper-clad laminates
49. 超薄型層壓板:ultra thin laminate
50. 陶瓷基覆銅箔板:ceramics base copper-clad laminates
51. 紫外線阻擋型覆銅箔板:UV blocking copper-clad laminates
