LIS2DW12驅動stm32源碼
liuxinwei12
2018-4-24 12:49
LIS2DW12驅動stm32源碼
RT。。。。。
/******************** (C) COPYRIGHT 2016 STMicroelectronics ********************
* File Name : LIS2DW12_ACC_driver.c
* Author : MEMS Application Team
* Version : v1.1
* Date : 11 May 2017
* Description : EKSTM32 main file
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* THIS SOFTWARE IS SPECIFICALLY DESIGNED FOR EXCLUSIVE USE WITH ST PARTS.
/* Includes ------------------------------------------------------------------*/
#include "LIS2DW12_ACC_driver.h"
#include "spi.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
/************** Generic Function *******************/
* Function Name : LIS2DW12_ACC_WriteReg
* Description : Generic Writing function. It must be fullfilled with either
* : I2C or SPI writing function
* Input : Register Address, ptr to buffer to be written,
* length of buffer
* Output : None
* Return : None
status_t LIS2DW12_ACC_WriteReg(void *handle, u8_t Reg, u8_t *Bufp, u16_t len)
/* Example
HAL_GPIO_WritePin(CS_DEV_GPIO_Port, CS_DEV_Pin, GPIO_PIN_RESET);
HAL_SPI_Transmit(&hspi2, &Reg, 1, 1000);
HAL_SPI_Transmit(&hspi2, Bufp, len, 1000);
HAL_GPIO_WritePin(CS_DEV_GPIO_Port, CS_DEV_Pin, GPIO_PIN_SET);
return MEMS_SUCCESS;
* Function Name : LIS2DW12_ACC_ReadReg
* Description : Generic Reading function. It must be fullfilled with either
* Input : Register Address, ptr to buffer to be read,
* length of buffer
* Output : None
* Return : None
status_t LIS2DW12_ACC_ReadReg(void *handle, u8_t Reg, u8_t *Bufp, u16_t len)
/* Example
uint8_t dummy = Reg|0x80;
HAL_SPI_Transmit(&hspi2, &dummy, 1, 1000);
HAL_SPI_Receive(&hspi2, Bufp, len, 1000);
/**************** Base Function *******************/
* Function Name : LIS2DW12_ACC_R_WhoAmI
* Description : Read WHO_AM_I_BIT
* Input : Pointer to u8_t
* Output : Status of WHO_AM_I_BIT
* Return : Status [MEMS_ERROR, MEMS_SUCCESS]
status_t LIS2DW12_ACC_R_WhoAmI(void *handle, u8_t *value)
if( !LIS2DW12_ACC_ReadReg(handle, LIS2DW12_ACC_WHO_AM_I_REG, (u8_t *)value , 1) )
return MEMS_ERROR;
*value &= LIS2DW12_ACC_WHO_AM_I_BIT_MASK; //coerce
*value = *value >> LIS2DW12_ACC_WHO_AM_I_BIT_POSITION; //mask
* Function Name : LIS2DW12_ACC_W_OutputDataRate
* Description : Write ODR
* Input : LIS2DW12_ACC_ODR_t
* Output : None
status_t LIS2DW12_ACC_W_OutputDataRate(void *handle, LIS2DW12_ACC_ODR_t newValue)
u8_t value;
if( !LIS2DW12_ACC_ReadReg(handle, LIS2DW12_ACC_CTRL1, &value, 1) )
return MEMS_ERROR;
value &= ~LIS2DW12_ACC_ODR_MASK;
value |= newValue;
if( !LIS2DW12_ACC_WriteReg(handle, LIS2DW12_ACC_CTRL1, &value, 1) )
return MEMS_ERROR;
* Function Name : LIS2DW12_ACC_R_OutputDataRate
* Description : Read ODR
* Input : Pointer to LIS2DW12_ACC_ODR_t
* Output : Status of ODR see LIS2DW12_ACC_ODR_t
status_t LIS2DW12_ACC_R_OutputDataRate(void *handle, LIS2DW12_ACC_ODR_t *value)
if( !LIS2DW12_ACC_ReadReg(handle, LIS2DW12_ACC_CTRL1, (u8_t *)value , 1) )
return MEMS_ERROR;
*value &= LIS2DW12_ACC_ODR_MASK; //mask
* Function Name : LIS2DW12_ACC_W_FullScaleSelection
* Description : Write FS
* Input : LIS2DW12_ACC_FS_t
* Output : None
status_t LIS2DW12_ACC_W_FullScaleSelection(void *handle, LIS2DW12_ACC_FS_t newValue)
u8_t value;
if( !LIS2DW12_ACC_ReadReg(handle, LIS2DW12_ACC_CTRL6, &value, 1) )
return MEMS_ERROR;
value &= ~LIS2DW12_ACC_FS_MASK;
value |= newValue;
if( !LIS2DW12_ACC_WriteReg(handle, LIS2DW12_ACC_CTRL6, &value, 1) )
return MEMS_ERROR;
* Function Name : LIS2DW12_ACC_R_FullScaleSelection
* Description : Read FS
* Input : Pointer to LIS2DW12_ACC_FS_t
* Output : Status of FS see LIS2DW12_ACC_FS_t
status_t LIS2DW12_ACC_R_FullScaleSelection(void *handle, LIS2DW12_ACC_FS_t *value)
if( !LIS2DW12_ACC_ReadReg(handle, LIS2DW12_ACC_CTRL6, (u8_t *)value , 1) )
return MEMS_ERROR;
*value &= LIS2DW12_ACC_FS_MASK; //mask
* Function Name : LIS2DW12_ACC_W_BlockDataUpdate
* Description : Write BDU
* Input : LIS2DW12_ACC_BDU_t
* Output : None
status_t LIS2DW12_ACC_W_BlockDataUpdate(void *handle, LIS2DW12_ACC_BDU_t newValue)
u8_t value;
if( !LIS2DW12_ACC_ReadReg(handle, LIS2DW12_ACC_CTRL2, &value, 1) )
return MEMS_ERROR;
value &= ~LIS2DW12_ACC_BDU_MASK;
value |= newValue;
if( !LIS2DW12_ACC_WriteReg(handle, LIS2DW12_ACC_CTRL2, &value, 1) )
return MEMS_ERROR;
* Function Name : LIS2DW12_ACC_R_BlockDataUpdate
* Description : Read BDU
* Input : Pointer to LIS2DW12_ACC_BDU_t
* Output : Status of BDU see LIS2DW12_ACC_BDU_t
status_t LIS2DW12_ACC_R_BlockDataUpdate(void *handle, LIS2DW12_ACC_BDU_t *value)
if( !LIS2DW12_ACC_ReadReg(handle, LIS2DW12_ACC_CTRL2, (u8_t *)value , 1) )
return MEMS_ERROR;
*value &= LIS2DW12_ACC_BDU_MASK; //mask
* Function Name : status_t LIS2DW12_ACC_Get_Acceleration(u8_t *buff)
* Description : Read Acceleration output register
* Input : pointer to [u8_t]
* Output : Acceleration buffer u8_t
status_t LIS2DW12_ACC_Get_Acceleration(void *handle, u8_t *buff)
u8_t i, j, k;
u8_t numberOfByteForDimension;
numberOfByteForDimension=6/3;
k=0;
for (i=0; i<3;i++ )
for (j=0; j<numberOfByteForDimension;j++ )
if( !LIS2DW12_ACC_ReadReg(handle, LIS2DW12_ACC_OUT_X_L+k, &buff[k], 1))
return MEMS_ERROR;
k++;
* Function Name : status_t LIS2DW12_ACC_Get_Temperature(u8_t *buff)
* Description : Read Temperature output register
* Output : Temperature buffer u8_t
status_t LIS2DW12_ACC_Get_Temperature(void *handle, u8_t *buff)
u8_t i, j, k;
numberOfByteForDimension=2/1;
k=0;
for (i=0; i<1;i++ )
if( !LIS2DW12_ACC_ReadReg(handle, LIS2DW12_ACC_OUT_T_L+k, &buff[k], 1))
return MEMS_ERROR;
k++;
/**************** Advanced Function *******************/
* Function Name : LIS2DW12_ACC_W_LowPowerModeSelection
* Description : Write LP_MODE
* Input : LIS2DW12_ACC_LP_MODE_t
* Output : None
status_t LIS2DW12_ACC_W_LowPowerModeSelection(void *handle, LIS2DW12_ACC_LP_MODE_t newValue)
u8_t value;
return MEMS_ERROR;
value &= ~LIS2DW12_ACC_LP_MODE_MASK;
value |= newValue;
return MEMS_ERROR;
* Function Name : LIS2DW12_ACC_R_LowPowerModeSelection
* Description : Read LP_MODE
* Input : Pointer to LIS2DW12_ACC_LP_MODE_t
* Output : Status of LP_MODE see LIS2DW12_ACC_LP_MODE_t
status_t LIS2DW12_ACC_R_LowPowerModeSelection(void *handle, LIS2DW12_ACC_LP_MODE_t *value)
return MEMS_ERROR;
*value &= LIS2DW12_ACC_LP_MODE_MASK; //mask
* Function Name : LIS2DW12_ACC_W_ModeSelection
* Description : Write MODE
* Input : LIS2DW12_ACC_MODE_t
* Output : None
status_t LIS2DW12_ACC_W_ModeSelection(void *handle, LIS2DW12_ACC_MODE_t newValue)
u8_t value;
return MEMS_ERROR;
value &= ~LIS2DW12_ACC_MODE_MASK;
value |= newValue;
return MEMS_ERROR;
* Function Name : LIS2DW12_ACC_R_ModeSelection
* Description : Read MODE
* Input : Pointer to LIS2DW12_ACC_MODE_t
* Output : Status of MODE see LIS2DW12_ACC_MODE_t
status_t LIS2DW12_ACC_R_ModeSelection(void *handle, LIS2DW12_ACC_MODE_t *value)
return MEMS_ERROR;
*value &= LIS2DW12_ACC_MODE_MASK; //mask
* Function Name : LIS2DW12_ACC_W_SPI_mode_selection
* Description : Write SIM
* Input : LIS2DW12_ACC_SIM_t
* Output : None
status_t LIS2DW12_ACC_W_SPI_mode_selection(void *handle, LIS2DW12_ACC_SIM_t newValue)
u8_t value;
return MEMS_ERROR;
value &= ~LIS2DW12_ACC_SIM_MASK;
value |= newValue;
return MEMS_ERROR;
* Function Name : LIS2DW12_ACC_R_SPI_mode_selection
* Description : Read SIM
* Input : Pointer to LIS2DW12_ACC_SIM_t
* Output : Status of SIM see LIS2DW12_ACC_SIM_t
status_t LIS2DW12_ACC_R_SPI_mode_selection(void *handle, LIS2DW12_ACC_SIM_t *value)
return MEMS_ERROR;
*value &= LIS2DW12_ACC_SIM_MASK; //mask
* Function Name : LIS2DW12_ACC_W_I2C_status
* Description : Write I2C_DISABLE
* Input : LIS2DW12_ACC_I2C_DISABLE_t
* Output : None
status_t LIS2DW12_ACC_W_I2C_status(void *handle, LIS2DW12_ACC_I2C_DISABLE_t newValue)
u8_t value;
return MEMS_ERROR;
value &= ~LIS2DW12_ACC_I2C_DISABLE_MASK;
value |= newValue;
return MEMS_ERROR;
* Function Name : LIS2DW12_ACC_R_I2C_status
* Description : Read I2C_DISABLE
* Input : Pointer to LIS2DW12_ACC_I2C_DISABLE_t
* Output : Status of I2C_DISABLE see LIS2DW12_ACC_I2C_DISABLE_t
status_t LIS2DW12_ACC_R_I2C_status(void *handle, LIS2DW12_ACC_I2C_DISABLE_t *value)
return MEMS_ERROR;
*value &= LIS2DW12_ACC_I2C_DISABLE_MASK; //mask
* Function Name : LIS2DW12_ACC_W_AutoIncrementedWithMultipleAccess
* Description : Write IF_ADD_INC
* Input : LIS2DW12_ACC_IF_ADD_INC_t
* Output : None
status_t LIS2DW12_ACC_W_AutoIncrementedWithMultipleAccess(void *handle, LIS2DW12_ACC_IF_ADD_INC_t newValue)
u8_t value;
return MEMS_ERROR;
value &= ~LIS2DW12_ACC_IF_ADD_INC_MASK;
value |= newValue;
return MEMS_ERROR;
* Function Name : LIS2DW12_ACC_R_AutoIncrementedWithMultipleAccess
* Description : Read IF_ADD_INC
* Input : Pointer to LIS2DW12_ACC_IF_ADD_INC_t
* Output : Status of IF_ADD_INC see LIS2DW12_ACC_IF_ADD_INC_t
status_t LIS2DW12_ACC_R_AutoIncrementedWithMultipleAccess(void *handle, LIS2DW12_ACC_IF_ADD_INC_t *value)
return MEMS_ERROR;
*value &= LIS2DW12_ACC_IF_ADD_INC_MASK; //mask
* Function Name : LIS2DW12_ACC_W_SoftReset
* Description : Write SOFT_RESET
* Input : LIS2DW12_ACC_SOFT_RESET_t
* Output : None
status_t LIS2DW12_ACC_W_SoftReset(void *handle, LIS2DW12_ACC_SOFT_RESET_t newValue)
u8_t value;
return MEMS_ERROR;
value &= ~LIS2DW12_ACC_SOFT_RESET_MASK;
value |= newValue;
return MEMS_ERROR;
* Function Name : LIS2DW12_ACC_R_SoftReset
* Description : Read SOFT_RESET
* Input : Pointer to LIS2DW12_ACC_SOFT_RESET_t
* Output : Status of SOFT_RESET see LIS2DW12_ACC_SOFT_RESET_t
status_t LIS2DW12_ACC_R_SoftReset(void *handle, LIS2DW12_ACC_SOFT_RESET_t *value)
return MEMS_ERROR;
*value &= LIS2DW12_ACC_SOFT_RESET_MASK; //mask
* Function Name : LIS2DW12_ACC_W_Reboot
* Description : Write BOOT
* Input : LIS2DW12_ACC_BOOT_t
* Output : None
status_t LIS2DW12_ACC_W_Reboot(void *handle, LIS2DW12_ACC_BOOT_t newValue)
u8_t value;
return MEMS_ERROR;
value &= ~LIS2DW12_ACC_BOOT_MASK;
value |= newValue;
return MEMS_ERROR;
* Function Name : LIS2DW12_ACC_R_Reboot
* Description : Read BOOT
* Input : Pointer to LIS2DW12_ACC_BOOT_t
* Output : Status of BOOT see LIS2DW12_ACC_BOOT_t
status_t LIS2DW12_ACC_R_Reboot(void *handle, LIS2DW12_ACC_BOOT_t *value)
return MEMS_ERROR;
*value &= LIS2DW12_ACC_BOOT_MASK; //mask
* Function Name : LIS2DW12_ACC_W_SingleLowPowerMode
* Description : Write SLP_MODE_1
* Input : LIS2DW12_ACC_SLP_MODE_1_t
* Output : None
status_t LIS2DW12_ACC_W_SingleLowPowerMode(void *handle, LIS2DW12_ACC_SLP_MODE_1_t newValue)
u8_t value;
if( !LIS2DW12_ACC_ReadReg(handle, LIS2DW12_ACC_CTRL3, &value, 1) )
return MEMS_ERROR;
value &= ~LIS2DW12_ACC_SLP_MODE_1_MASK;
value |= newValue;
if( !LIS2DW12_ACC_WriteReg(handle, LIS2DW12_ACC_CTRL3, &value, 1) )
return MEMS_ERROR;
* Function Name : LIS2DW12_ACC_R_SingleLowPowerMode
* Description : Read SLP_MODE_1
* Input : Pointer to LIS2DW12_ACC_SLP_MODE_1_t
* Output : Status of SLP_MODE_1 see LIS2DW12_ACC_SLP_MODE_1_t
status_t LIS2DW12_ACC_R_SingleLowPowerMode(void *handle, LIS2DW12_ACC_SLP_MODE_1_t *value)
if( !LIS2DW12_ACC_ReadReg(handle, LIS2DW12_ACC_CTRL3, (u8_t *)value , 1) )
return MEMS_ERROR;
*value &= LIS2DW12_ACC_SLP_MODE_1_MASK; //mask
* Function Name : LIS2DW12_ACC_W_SingleLowPowerModeSource
* Description : Write SLP_MODE_SEL
* Input : LIS2DW12_ACC_SLP_MODE_SEL_t
* Output : None
status_t LIS2DW12_ACC_W_SingleLowPowerModeSource(void *handle, LIS2DW12_ACC_SLP_MODE_SEL_t newValue)
u8_t value;
…………限于本文篇幅 余下代碼請從51黑下載附件…………
LIS2DW12_ver1.1.zip
(21.41 KB, 下載次數: 106)
2018-4-24 12:49 上傳
阿斯蒂芬大幅
2018-6-27 00:02
請問有沒有spi的程序
wdliming
2019-2-14 13:43
謝謝分享~~~~
hnlouji
2019-8-25 12:44
謝謝分享~~~~
