標題: 上傳一個顯示溫濕度的arduino代碼 [打印本頁]
作者: 醉鄉民謠    時間: 2018-4-15 11:54
double Fahrenheit(double celsius)
       return 1.8 * celsius + 32;
}   //攝氏溫度度轉化為華氏溫度
double Kelvin(double celsius)
       return celsius + 273.15;
}    //攝氏溫度轉化為開氏溫度
// 露點(點在此溫度時,空氣飽和并產生露珠)
// 參考:wahiduddin點net/calc/density_algorithms.htm
double dewPoint(double celsius, doublehumidity)   //humidity是濕度,celsius是攝氏溫度
       double A0= 373.15/(273.15 + celsius);
       double SUM = -7.90298 * (A0-1);
       SUM += 5.02808 * log10(A0);
       SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
       SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
       SUM += log10(1013.246);
       double VP = pow(10, SUM-3) * humidity;
       double T = log(VP/0.61078);   //temp var
       return (241.88 * T) / (17.558-T);
// 快速計算露點,速度是5dewPoint()(上面函數的結果)
double dewPointFast(double celsius, doublehumidity)
       double a = 17.271;
       double b = 237.7;
       double temp = (a * celsius) / (b + celsius) + log(humidity/100);
       double Td = (b * temp) / (a - temp);
       return Td;
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN 2
void setup()  //設置一些參數
Serial.begin(9600);
Serial.println("DHT11 TEST PROGRAM ");
Serial.print("LIBRARY VERSION: ");
Serial.println(DHT11LIB_VERSION);
Serial.println();
void loop()
Serial.println("\n"); //換行
  intchk = DHT11.read(DHT11PIN);
Serial.print("Read sensor: "); //讀取傳感器
switch (chk)
   case DHTLIB_OK:
                Serial.println("OK");
                break;
   case DHTLIB_ERROR_CHECKSUM:
                Serial.println("Checksumerror");
                break;
   case DHTLIB_ERROR_TIMEOUT:
                Serial.println("Time outerror");
                break;
   default:
                Serial.println("Unknownerror");
                break;
Serial.print("Humidity (%): ");
Serial.println((float)DHT11.humidity, 2);
Serial.print("Temperature (oC): ");
Serial.println((float)DHT11.temperature, 2);
Serial.print("Temperature (oF): ");
Serial.println(Fahrenheit(DHT11.temperature), 2);
Serial.print("Temperature (K): ");
Serial.println(Kelvin(DHT11.temperature), 2);
Serial.print("Dew Point (oC): ");
Serial.println(dewPoint(DHT11.temperature, DHT11.humidity));
Serial.print("Dew PointFast (oC): ");
Serial.println(dewPointFast(DHT11.temperature, DHT11.humidity));
delay(2000);
作者: 15616200407    時間: 2019-12-5 18:33
我運行了一下   錯誤是說沒有dht11.h 這個文件 怎么解決 剛接觸arduino什么都不懂...求教
