單片機DAC0832波形函數信號發生器proteus仿真與源程序
laoyingbi
2018-4-4 16:23
這個是一個基于單片機的波形與函數信號發生器的設計
Altium Designer畫的DAC0832信號發生器原理圖和PCB圖如下:(51hei附件中可下載工程文件)
(43.56 KB, 下載次數: 77)
2018-4-4 17:04 上傳
#include<reg52.h> //包含頭文件
#include<intrins.h>
#define uchar unsigned char //宏定義
sbit s1=P3^5; //定義按鍵的接口
sbit s2=P3^6;
sbit s3=P3^7;
sbit s4=P3^4;
sbit led0=P3^0;
sbit led1=P3^1;
sbit led2=P3^2;
sbit led3=P3^3;
sbit lcdrs=P2^7; //液晶控制位
sbit lcden=P2^6;
char num,boxing,u; //定義全局變量
int pinlv=100,bujin=1,bujin1=1;
uchar code table[]="0123456789"; //定義顯示的數組
uchar code table1[]="Fout= Wave form:";
unsigned long int m;
int a,b,h,num1;
//自定義字符
uchar code zifu[]={
0x0e,0x11,0x11,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x11,0x11,0x0e,0x00, //正弦波 0 1
0x00,0x07,0x04,0x04,0x04,0x04,0x1c,0x00,
0x00,0x1c,0x04,0x04,0x04,0x04,0x07,0x00, //矩形波 2 3
0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00,
0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00, //三角波 4 5
0x00,0x01,0x03,0x05,0x09,0x11,0x00,0x00, //鋸齒波 6
uchar code sin[64]={
135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
}; //正弦波取碼
uchar code juxing[64]={
255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
}; //矩形波取碼
uchar code sanjiao[64]={
0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
}; //三角波取碼
uchar code juchi[64]={
0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
}; //鋸齒波取碼
void delay(uint xms) //延時函數
int a,b;
for(a=xms;a>0;a--)
for(b=110;b>0;b--);
void write_com(uchar com) //寫命令函數
lcdrs=0;
P0=com;
delay(1);
lcden=1;
delay(1);
lcden=0;
void write_date(uchar date) //寫數據函數
lcdrs=1;
P0=date;
delay(1);
lcden=1;
delay(1);
lcden=0;
//自定義字符集
void Lcd_ram()
uint i,j,k=0,temp=0x40;
for(i=0;i<7;i++)
for(j=0;j<8;j++)
write_com(temp+j);
write_date(zifu[k]);
k++;
temp=temp+8;
void init_lcd() //初始化函數
uchar i;
lcden=0; //默認開始狀態為關使能端,見時序圖
Lcd_ram();
write_com(0x0f);
write_com(0x38); //顯示模式設置,默認為0x38,不用變。
write_com(0x01); //顯示清屏,將上次的內容清除,默認為0x01.
write_com(0x0c); //顯示功能設置0x0f為開顯示,顯示光標,光標閃爍;0x0c為開顯示,不顯光標,光標不閃
write_com(0x06); //設置光標狀態默認0x06,為讀一個字符光標加1.
write_com(0x80); //設置初始化數據指針,是在讀指令的操作里進行的
for(i=10;i<20;i++) //顯示初始化
write_date(table1[i]);
write_com(0x80+0x40);
for(i=0;i<9;i++)
write_com(0x80+10);
write_date(0);
write_date(1);
write_date(0);
write_date(1);
write_date(0);
write_date(1);
write_com(0x80+0x40+0x09);
write_date(' ');
write_date('1');
write_date('0');
write_date('.');
write_date('0');
write_date('H');
write_date('z');
void initclock() //時鐘初始化
TMOD=0x01;
TH0=a;
TL0=b;
EA=1;
ET0=1;
TR0=1;
void display() //顯示函數
uchar qian,bai,shi,ge;
qian=pinlv/1000;
bai=pinlv%1000/100;
shi=pinlv%1000%100/10;
ge=pinlv%1000%100%10;
if(qian==0)
write_date(' ');
write_date(table[qian]);
if(qian==0&&bai==0)
write_date(' ');
write_date(table[bai]);
write_date(table[shi]);
write_date('.');
write_date(table[ge]);
write_date('H');
write_date('z');
if(boxing==0)
write_com(0x80+10);
write_date(0);
write_date(1);
write_date(0);
write_date(1);
write_date(0);
write_date(1);
led3=1;
led0=0;
if(boxing==1)
write_com(0x80+10);
write_date(2);
write_date(3);
write_date(2);
write_date(3);
write_date(2);
write_date(3);
led0=1;
led1=0;
if(boxing==2)
write_com(0x80+10);
write_date(4);
write_date(5);
write_date(4);
write_date(5);
write_date(4);
write_date(5);
led1=1;
led2=0;
if(boxing==3)
write_com(0x80+10);
write_date(6);
write_date(6);
write_date(6);
write_date(6);
write_date(6);
write_date(6);
led2=1;
led3=0;
void keyscan() //鍵盤檢測函數
if(s1==0)
EA=0;
delay(2);
if(s1==0)
while(!s1);
pinlv+=bujin;
if(pinlv>1000)
pinlv=100;
display();
m=65536-(150000/pinlv);
a=m/256;
b=m%256;
EA=1;
if(s2==0)
delay(5);
if(s2==0)
EA=0;
while(!s2);
pinlv-=bujin;
if(pinlv<100)
pinlv=1000;
display();
a=m/256;
b=m%256;
EA=1;
if(s3==0)
delay(5);
if(s3==0)
EA=0;
while(!s3);
boxing++;
if(boxing>=4)
boxing=0;
display();
EA=1;
void bujindisplay()
uint bai,shi,ge;
bai=bujin1/100;
shi=bujin1%100/10;
ge=bujin1%100%10;
write_com(0x80+11);
if(bai==0)
write_date(' ');
write_date('.');
void bujinjiance()
if(s4==0)
delay(5);
if(s4==0)
while(!s4);
h++;
if(h==1)
write_com(0x01);
write_com(0x80);
write_date('S');delay(1); //step value
write_date('t');delay(1);
write_date('e');delay(1);
write_date('p');delay(1);
write_date(' ');delay(1);
write_date('v');delay(1);
write_date('a');delay(1);
write_date('l');delay(1);
write_date('u');delay(1);
write_date(':');delay(1);
bujin1=bujin;
bujindisplay();
if(h==2)
h=0;
bujin=bujin1;
init_lcd();
initclock();
display();
if(h==1)
if(s1==0)
delay(5);
if(s1==0)
while(!s1);
bujin1++;
if(bujin1>=101)
bujin1=1;
bujindisplay();
if(s2==0)
delay(5);
if(s2==0)
while(!s2);
bujin1--;
if(bujin1<=0)
…………限于本文篇幅 余下代碼請從51黑下載附件…………
(51.18 KB, 下載次數: 71)
2018-4-4 17:05 上傳
仿真及程序.zip
(106.25 KB, 下載次數: 282)
2018-4-4 16:23 上傳
電路的仿真和程序
