stm8 GPIO輸出芯片流水燈控制源程序 IAR寫的
小馬駒
2018-4-2 16:15
適合stm8初學者
流水燈控制
源程序
/* 添加庫函數頭文件 */
#include "stm8s.h"
#define LED1_ON() GPIO_WriteLow(GPIOD , GPIO_PIN_2) //LED1亮
#define LED2_ON() GPIO_WriteLow(GPIOC , GPIO_PIN_7) //LED2亮
#define LED3_ON() GPIO_WriteLow(GPIOC , GPIO_PIN_6) //LED3亮
#define LED4_ON() GPIO_WriteLow(GPIOC , GPIO_PIN_3) //LED4亮
#define LED1_OFF() GPIO_WriteHigh(GPIOD , GPIO_PIN_2) //LED1滅
#define LED2_OFF() GPIO_WriteHigh(GPIOC , GPIO_PIN_7) //LED2滅
#define LED3_OFF() GPIO_WriteHigh(GPIOC , GPIO_PIN_6) //LED3滅
#define LED4_OFF() GPIO_WriteHigh(GPIOC , GPIO_PIN_3) //LED4滅
**函數名稱:void delay(unsigned int ms) Name: void delay(unsigned int ms)
**功能描述:大概延時
**入口參數:unsigned int ms 輸入大概延時數值
**輸出:無
unsigned int x , y;
for(x = ms; x > 0; x--) /* 通過一定周期循環進行延時*/
for(y = 3000 ; y > 0 ; y--);
**函數名稱:void InitLED()
**功能描述:初始化LED函數
**入口參數:無
**輸出:無
void InitLED()
//設置PD2為快速推挽輸出 ,LED1
GPIO_Init(GPIOD , GPIO_PIN_2 , GPIO_MODE_OUT_PP_LOW_FAST);
//設置PC7為快速推挽輸出 ,LED2
GPIO_Init(GPIOC , GPIO_PIN_7 , GPIO_MODE_OUT_PP_LOW_FAST);
//設置PC6為快速推挽輸出 ,LED3
GPIO_Init(GPIOC , GPIO_PIN_6 , GPIO_MODE_OUT_PP_LOW_FAST);
//設置PC3為快速推挽輸出 ,LED4
GPIO_Init(GPIOC , GPIO_PIN_3 , GPIO_MODE_OUT_PP_LOW_FAST);
/* 主函數 */
int main(void)
//內部時鐘為1分頻 = 16Mhz
CLK_SYSCLKConfig(CLK_PRESCALER_HSIDIV1);
InitLED(); //調用LED初始化函數
LED1_ON(); //點亮LED1
LED2_ON(); //點亮LED2
LED3_ON(); //點亮LED3
LED4_ON(); //點亮LED4
delay(1000); //空跑大概延時
LED1_OFF(); //點滅LED1
LED2_OFF(); //點滅LED2
LED3_OFF(); //點滅LED3
LED4_OFF(); //點滅LED4
iar工程.7z
(264.06 KB, 下載次數: 30)
2022-12-16 04:49 上傳
