標題: STM32F030C8配置使用NRF24L01 [打印本頁]
作者: IdeaMing 時間: 2018-3-19 16:54
STM32F030C8配置NRF24L01
前言:
工作使用到STM32F030,項目暫告一段落,空閑時間,調試一下基本的無線模塊。其實還是碰到了一些阻礙。雖然STM32F103會用了NRF24L10,可是到了STM32F030還是有些配置上的區別,為了加快各位研發人員的開發進度,避免浪費大量的時間在硬件平臺上,寫出個人代碼調試的經驗。個人水平有限,如有錯誤,還請指正。
提示:
使用內部RC時鐘,最大速度48MHz。
第一步:初始化端口/*******************************************************************************
*@brief 初始化端口 因為CSN用的PB12 CE 用的PA11所以兩個時鐘都要開
*@param None
*@retval None
****************************************************************Author:Liming**/
void NRF24L01_GPIO_Init(void)
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA|RCC_AHBPeriph_GPIOB,ENABLE);//使能端口A/B時鐘
GPIO_InitStructure.GPIO_Pin= SPI2_CE_PIN;
GPIO_InitStructure.GPIO_Mode= GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_Level_2;
GPIO_Init(SPI2_CE_PORT,&GPIO_InitStructure); //CE控制腳
GPIO_InitStructure.GPIO_Pin= SPI2_CSN_PIN;
GPIO_Init(SPI2_CSN_PORT,&GPIO_InitStructure); //CSN控制腳
GPIO_ResetBits(SPI2_CE_PORT,SPI2_CE_PIN);
GPIO_SetBits(SPI2_CSN_PORT,SPI2_CSN_PIN);
GPIO_InitStructure.GPIO_Pin = SPI2_SCK_PIN;
GPIO_InitStructure.GPIO_Mode= GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Speed= GPIO_Speed_Level_2;
GPIO_Init(SPI2_SCK_GPIO_PORT,&GPIO_InitStructure); //SPI 引腳
GPIO_InitStructure.GPIO_Pin = SPI2_MISO_PIN;
GPIO_Init(SPI2_MISO_GPIO_PORT,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = SPI2_MOSI_PIN;
GPIO_Init(SPI2_MOSI_GPIO_PORT,&GPIO_InitStructure);
GPIO_PinAFConfig(SPI2_SCK_GPIO_PORT, SPI2_SCK_SOURCE,SPI2_SCK_AF);
GPIO_PinAFConfig(SPI2_MISO_GPIO_PORT,SPI2_MISO_SOURCE, SPI2_MISO_AF);
GPIO_PinAFConfig(SPI2_MOSI_GPIO_PORT,SPI2_MOSI_SOURCE, SPI2_MOSI_AF);
第二步:初始化SPI/*******************************************************************************
*@brief 初始化SPI 因為NRF24L01SPI最大支持10M,所以分頻到6MHz
*@param None
*@retval None
void SPIx_Init(void)
SPI_InitTypeDefSPI_InitStruture;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);//使能SPI2時鐘
SPI_InitStruture.SPI_Direction= SPI_Direction_2Lines_FullDuplex;//SPI 設置為雙線雙向全雙工
SPI_InitStruture.SPI_Mode= SPI_Mode_Master;//設置為主SPI
SPI_InitStruture.SPI_DataSize = SPI_DataSize_8b;//SPI 發送接收8 位幀結構
SPI_InitStruture.SPI_CPOL =SPI_CPOL_Low;//時鐘懸空低
SPI_InitStruture.SPI_CPHA =SPI_CPHA_1Edge;//數據捕獲于第一個時鐘沿
SPI_InitStruture.SPI_BaudRatePrescaler= SPI_BaudRatePrescaler_8;//波特率預分頻值為8 48/8=6MHz
SPI_InitStruture.SPI_NSS= SPI_NSS_Soft;//內部 NSS 信號有SSI 位控制
SPI_InitStruture.SPI_FirstBit= SPI_FirstBit_MSB; //數據傳輸從 MSB 位開始
SPI_InitStruture.SPI_CRCPolynomial= 7; //CRC校驗計算式
SPI_Init(SPI2,&SPI_InitStruture); //應用到SPI1
SPI_RxFIFOThresholdConfig(SPI2, SPI_RxFIFOThreshold_QF);// 很重要的一句代碼
SPI_Cmd(SPI2,ENABLE);
第三步:基礎支持程序代碼/*******************************************************************************
*@brief SPIx 讀寫一個字節 這一步我使用F103的都不行
*@param TxData:要寫入的字節
*@retval tmp:讀取到的字節
uint8_t SPIx_ReadWriteByte(uint8_t TxData)
uint8_t tmp = 0x00;
/*Wait until the transmit buffer is empty */
while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) != SET)
/*Send the byte */
SPI_SendData8(SPI2, TxData);
/*Wait to receive a byte */
while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) != SET)
/*Return the byte read from the SPI bus */
tmp= SPI_ReceiveData8(SPI2);
/*Wait until the BSY flag is set */
while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
/*Return read Data */
return tmp;
*@brief 寫寄存器
*@param None
*@retval None
u8 NRF24L01_Write_Reg(u8 reg,u8 value)
u8status;
SPI_CSN_LOW; //使能SPI傳輸
status =SPIx_ReadWriteByte(reg);//發送寄存器號
SPIx_ReadWriteByte(value); //寫入寄存器的值
SPI_CSN_HIGH; //禁止SPI傳輸
return(status); //返回狀態值
*@brief 讀寄存器
*@param None
*@retval None
u8 NRF24L01_Read_Reg(u8 reg)
u8reg_val;
SPIx_ReadWriteByte(reg); //發送寄存器號
reg_val=SPIx_ReadWriteByte(0XFF);//讀取寄存器內容
return(reg_val); //返回狀態值
*@brief 讀多字節數據
*@param None
*@retval None
unsigned char NRF24L01_Read_Buf(unsigned charreg,unsigned char *pBuf,unsigned char len)
unsignedchar status,u8_ctr;
status=SPIx_ReadWriteByte(reg);//發送寄存器值(位置),并讀取狀態值
for(u8_ctr=0;u8_ctr<len;u8_ctr++)pBuf[u8_ctr]=SPIx_ReadWriteByte(0XFF);//讀出數據
SPI_CSN_HIGH; //關閉SPI傳輸
return status; //返回讀到的狀態值
*@brief 寫多字節數據
*@param None
*@retval None
unsigned char NRF24L01_Write_Buf(unsignedchar reg, unsigned char *pBuf, unsigned char len)
status = SPIx_ReadWriteByte(reg);//發送寄存器值(位置),并讀取狀態值
for(u8_ctr=0; u8_ctr<len;u8_ctr++)SPIx_ReadWriteByte(*pBuf++); //寫入數據
*@brief 發送一包數據
*@param None
*@retval None
void NRF24L01_TxPacket(unsigned char*txbuf)
unsignedchar sta;
SPI_CE_LOW;
NRF24L01_Write_Reg(FLUSH_TX,0X00); // 清理發送寄存器
NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//寫數據到TXBUF 32個字節
NRF24L01_Write_Reg(SPI_WRITE_REG + CONFIG, 0x0E); // 清理發送寄存器
NRF_STATUS = NRF_STATUS_TX;
SPI_CE_HIGH; //啟動發送
*@brief 接收一包數據
*@param None
*@retval None
unsigned char NRF24L01_RxPacket(u8 *rxbuf)
unsignedchar sta;
sta=NRF24L01_Read_Reg(STATUS); //讀取狀態寄存器的值
NRF24L01_Write_Reg(SPI_WRITE_REG+STATUS,sta);//清除TX_DS或MAX_RT中斷標志
if(sta&RX_OK)//接收到數據
NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//讀取數據
NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器
return1;
return0;//沒收到任何數據
*@brief 檢測NRF24L01是否存在 進入調試模式查看是否值正確
*@param None
*@retval 1失敗 0成功
uint8_t NRF24L01_Check(void)
uint8_tbuf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
uint8_tbuf1[5]={0,0,0,0,0};
uint8_ti,Temp;
NRF24L01_Write_Buf(SPI_WRITE_REG+TX_ADDR,buf,5);//寫入5個字節的地址.
NRF24L01_Read_Buf(TX_ADDR,buf1,5); //讀出寫入的地址
for(i=0;i<5;i++) //調試斷點打到這一行,查看buf1是否都是0XA5
if( buf1 != 0XA5 )break;
if(i! = 5 )return 1;//檢測24L01錯誤
return0; //檢測到24L01
*@brief 切換NRF24L01到接收模式 需要設置發送地址,
* 有些人自己調程序,老是說會斷,或者模式切換出問題,或許參考一下紅色部分的思路。
*@param None
*@retval None
void RX_Mode(void)
unsigned char status;
SPI_CE_LOW; //CE拉低,進入配置模式
status = NRF24L01_Read_Reg(STATUS);
NRF24L01_Write_Reg(SPI_WRITE_REG+STATUS,status);//清除中斷
NRF24L01_Write_Reg(SPI_WRITE_REG+SETUP_AW,0x01);//3字節地址
NRF24L01_Write_Reg(FLUSH_RX,0x00);//清除RX FIFO寄存器
/* 設置通道0接收地址*/
NRF24L01_Write_Buf(SPI_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDR_PIPE0,RX_ADR_WIDTH);
/* 設置通道1接收地址*/
NRF24L01_Write_Buf(SPI_WRITE_REG+RX_ADDR_P1,(u8*)RX_ADDR_PIPE1,RX_ADR_WIDTH);
NRF24L01_Write_Reg(SPI_WRITE_REG+RX_ADDR_P2, RX_ADDR_PIPE2);// 設置通道2接收地址
NRF24L01_Write_Reg(SPI_WRITE_REG+RX_ADDR_P3, RX_ADDR_PIPE3);// 設置通道3接收地址
NRF24L01_Write_Reg(SPI_WRITE_REG+RX_ADDR_P4, RX_ADDR_PIPE4);// 設置通道4接收地址
NRF24L01_Write_Reg(SPI_WRITE_REG+RX_ADDR_P5, RX_ADDR_PIPE5);// 設置通道5接收地址
NRF24L01_Write_Reg(SPI_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//選擇通道0的有效數據寬度
NRF24L01_Write_Reg(SPI_WRITE_REG+RX_PW_P1,RX_PLOAD_WIDTH);//選擇通道1的有效數據寬度
NRF24L01_Write_Reg(SPI_WRITE_REG+RX_PW_P2,RX_PLOAD_WIDTH);//選擇通道2的有效數據寬度
NRF24L01_Write_Reg(SPI_WRITE_REG+RX_PW_P3,RX_PLOAD_WIDTH);//選擇通道3的有效數據寬度
NRF24L01_Write_Reg(SPI_WRITE_REG+RX_PW_P4,RX_PLOAD_WIDTH);//選擇通道4的有效數據寬度
NRF24L01_Write_Reg(SPI_WRITE_REG+RX_PW_P5,RX_PLOAD_WIDTH);//選擇通道5的有效數據寬度
NRF24L01_Write_Reg(SPI_WRITE_REG+EN_AA,0x3F); //使能所有通道的自動應答
NRF24L01_Write_Reg(SPI_WRITE_REG+EN_RXADDR,0x3F);//使能所有通道的接收地址
NRF24L01_Write_Reg(SPI_WRITE_REG+RF_CH,0X00); //設置RF通信頻率
/*設置TX發射參數,0db增益,2Mbps,低噪聲增益開啟 */
NRF24L01_Write_Reg(SPI_WRITE_REG+RF_SETUP,0x0F);
/*配置基本工作模式的參數;PWR_UP,EN_CRC,16BIT_CRC,接收模式*/
NRF24L01_Write_Reg(SPI_WRITE_REG+CONFIG,0x3F);
NRF_STATUS = NRF_STATUS_RX;
SPI_CE_HIGH; //CE拉高,進入接收模式
*@brief 切換NRF24L01到發送模式 需要設置發送地址,
* 如果使能了自動應答還需要寫通道0的接收地址和發送地址相同。
*@param None
*@retval None
void TX_Mode(void)
SPI_CE_LOW;
NRF24L01_Write_Reg(SPI_WRITE_REG+STATUS,status);//清除RX FIFO寄存器
NRF24L01_Write_Reg(FLUSH_TX,0x00);//清除TX FIFO寄存器
/*寫TX節點地址*/
NRF24L01_Write_Buf(SPI_WRITE_REG+TX_ADDR,(u8*)TX_ADDR_PIPE0,TX_ADR_WIDTH);
/*設置TX節點地址,主要為了使能ACK*/
NRF24L01_Write_Buf(SPI_WRITE_REG+RX_ADDR_P0,(u8*)TX_ADDR_PIPE0,TX_ADR_WIDTH);
NRF24L01_Write_Reg(SPI_WRITE_REG+EN_AA,0x01); //使能通道0的自動應答
NRF24L01_Write_Reg(SPI_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址
/*設置自動重發間隔時間:500us+ 86us;最大自動重發次數:5次*/
NRF24L01_Write_Reg(SPI_WRITE_REG+SETUP_RETR,0x15);
NRF24L01_Write_Reg(SPI_WRITE_REG+RF_CH,0X00); //設置RF通道為40
/*配置基本工作模式的參數;PWR_UP,EN_CRC,16BIT_CRC,接收模式,開啟所有中斷*/
NRF24L01_Write_Reg(SPI_WRITE_REG+CONFIG,0x0E);
SPI_CE_HIGH;//CE為高,10us后啟動發送
到這里基本已經可以讀寫寄存器了,也就是NRF24L01已經調通了基本的發送和接受。遇到的問題或許還有中斷引腳的配置,畢竟STM32F0還是和STM32F1不一樣。另外一篇詳細講外部中斷的配置。
全部資料51hei下載地址:
STM32F030C8配置NRF24L01.pdf
(508.95 KB, 下載次數: 51)
2018-3-19 16:54 上傳
作者: 728996695 時間: 2020-7-7 17:34
請問有頭文件的定義嗎?
作者: 728996695 時間: 2020-7-7 17:39
請問有頭文件的定義函數嗎
作者: 728996695 時間: 2020-7-8 09:37
您好,請問您有STM32F030C8配置NRLF24L01的頭文件相關定義嘛
作者: IdeaMing 時間: 2020-7-8 13:15
抱歉,時間久遠不能找到當時的頭文件,你可能要稍微花點時間自己把頭文件補上。
nRF的那些定義都是一樣的,至于單片機的管腳,SPI2你可以看看是哪幾個管腳。
