幫忙分析下代碼,藍橋杯stc15單片機的板子
風案件快遞
2018-3-3 20:13
#include<STC15F2K60S2.h>
#include<DS1302.H>
#include<DS18B20.h>
#include<KEY.H>
unsigned char shuma[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0xbf};
unsigned char disbuff[]={10,10,10,10,10,10,10,10};
unsigned char discom=0;
unsigned char keyzhi,Dtime=1,shi,fen,miao,suoyin=0;
unsigned char Kflag=1,Cflag=0,CFflag=0,Lflag=0x00;
unsigned char wendu[10];
void display()
P0=0xff;
P2=0xe0;
P0=0xff;
P2=0x1f;
P0=0x00;
P2=0xc0;
P0=(1<<discom);
P2=0x1f;
P0=0xff;
P2=0xe0;
P0=shuma[disbuff[discom]];
P2=0x1f;
if(++discom==8)
discom=0;
void comment()
P2=0xa0;
P0=0x00;
P2=0x1f;
P0=0xff;
P2=0x80;
P0=0xff;
P2=0x1f;
void Timer0Init() //1毫秒@11.0592MHz
AUXR |= 0x80; //定時器時鐘1T模式
TMOD &= 0xF0; //設(shè)置定時器模式
TL0 = 0xCD; //設(shè)置定時初值
TH0 = 0xD4; //設(shè)置定時初值
TF0 = 0; //清除TF0標志
TR0 = 1; //定時器0開始計時
EA=1;
ET0=1;
void Timer0() interrupt 1
static unsigned int tt=0,a=0,t=0;
display();
if(Cflag==1)
tt++;
if(tt==Dtime*1000)
tt=0;
wendu[a]=DS18B20read();
a++;
if(a==10)
a=0;
Cflag=0;
CFflag=1;
if(CFflag==1)
t++;
if(t==500)
t=0;
Lflag=~(Lflag);
comment();
Ds1302init();
Timer0Init();
AA1: disbuff[0]=10;
disbuff[1]=10;
disbuff[2]=10;
disbuff[3]=10;
disbuff[4]=10;
disbuff[5]=11;
disbuff[6]=Dtime/10;
disbuff[7]=Dtime%10;
keyzhi=keyscan();
switch(Kflag)
case 1:Dtime=1;break;
case 2:Dtime=5;break;
case 3:Dtime=30;break;
case 4:Dtime=60;break;
default:break;
if(keyzhi==4)
Kflag++;
if(Kflag==5)
Kflag=1;
if(keyzhi==5)
Cflag=1;
while(CFflag==0)
shi=Ds1302_Single_Byte_Read(0x85);
fen=Ds1302_Single_Byte_Read(0x83);
miao=Ds1302_Single_Byte_Read(0x81);
disbuff[0]=shi/16;
disbuff[1]=shi%16;
disbuff[3]=fen/16;
disbuff[4]=fen%16;
disbuff[6]=miao/16;
disbuff[7]=miao%16;
if(miao%2==0)
disbuff[2]=11;
disbuff[5]=11;
disbuff[2]=10;
disbuff[5]=10;
if(CFflag==1)
{ if(Lflag==0xff)
P0=0xff;
P2=0x80;
P0=0xfe;
P2=0x1f;
P0=0xff;
P2=0x80;
P0=0xff;
P2=0x1f;
disbuff[0]=11;
disbuff[1]=0;
disbuff[2]=0;
disbuff[3]=10;
disbuff[4]=10;
disbuff[5]=11;
disbuff[6]=wendu[0]/10;
disbuff[7]=wendu[0]%10;
keyzhi=keyscan();
if(keyzhi==6)
Lflag=0xcc;
P0=0xff;
P2=0x80;
P0=0xff;
P2=0x1f;
while(CFflag)
disbuff[0]=11;
disbuff[1]=0;
disbuff[2]=suoyin;
disbuff[3]=10;
disbuff[4]=10;
disbuff[5]=11;
disbuff[6]=wendu[suoyin]/10;
disbuff[7]=wendu[suoyin]%10;
keyzhi=keyscan();
if(keyzhi==6)
suoyin++;
if(suoyin==10)
suoyin=0;
if(keyzhi==7)
CFflag=0;
Lflag=0x00;
goto AA1;
風案件快遞
2018-3-3 20:15
寫帶有返回值的按鍵函數(shù),為啥在主函數(shù)里每次用一次都的調(diào)用一次啊
風案件快遞
2018-3-3 20:15
13122031726
2018-3-3 20:52
我的帖子你參考看看吧或者去我博客自己看看不行再聯(lián)系我,
熇熇熇
2018-3-3 20:58
當按鍵函數(shù)返回值變化時,也就是按鍵變動所產(chǎn)生的值并沒事實時給keyzhi賦值。故使用時需要不斷調(diào)用。
