標(biāo)題: 共享我的51hei開發(fā)板數(shù)碼顯示程序-1 [打印本頁]
作者: hhcc    時(shí)間: 2011-1-22 03:16
買了很久的板子了,一直沒時(shí)間玩 ,今天搞到03:13,終于靠自己寫出了一個(gè)數(shù)碼顯示程序,他可以在51hei開發(fā)板上輪流顯示數(shù)字和字母.
#include<reg52.h>
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar code we[]={
0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
sbit dula=P2^6;
sbit wela=P2^7;
uchar num,du,num1;
//設(shè)置計(jì)數(shù)器
//選取計(jì)數(shù)方式1
 TMOD = 0x11;
//給計(jì)數(shù)器寫初值
 TH0 = (65536-10000)/256;
 TL0 = (65536-10000)%256;
//操作單片機(jī)
//開啟CPU中斷
 EA = 1;
//開啟定時(shí)器T0位中斷
 ET0 = 1;
//開啟計(jì)數(shù)器
 TR0 = 1;
//操作數(shù)碼管
   if(du==100)
    du=0;
    num++;
    if(num<16)
    dula=1;
    P0=table[num];
    dula=0;
    if(num==16)
     num=0;
    if(num1<2)
    wela=1;
    P0=we[num1];
    wela=0;
    num1++;
    if(num1==2)
     num1=0;
//中斷函數(shù)
void time () interrupt 1
//自變量自加
du++;
作者: hhcc    時(shí)間: 2011-1-22 03:24
這個(gè)是靜態(tài)顯示程序
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
uchar cnt;
uchar num;
uchar jf;
void light (uchar num);
//設(shè)置工作方式1
 TMOD = 0x11;
//給計(jì)數(shù)器賦初值
 TH0 = 0;
 TL0 = 0;
//對(duì)單片機(jī)操作
//開啟CPU中斷
 EA = 1;
//開啟定時(shí)器T0位中斷
 ET0 = 1;
//啟動(dòng)計(jì)數(shù)器
 TR0 = 1;
//點(diǎn)亮數(shù)碼管。每次+1
 wela=1;
 P0=0xc0;
 wela=0;
  if(cnt<16)
   light(cnt);
  else cnt = 0;
//  uchar c;
// wela=1;
// P0=0xc0;
// wela=0;
// for(c=1;c<6;c++)
 dula=1;
 P0=table[num];
 dula=0;
//中斷函數(shù)
 //變量自加
 if (jf<8)
   jf++;
   TH0 =0;
   TL0 = 0;
 if (jf==8)
   jf=0;
           //裝載初值
   TH0 = 94;
   TL0 = 224;
   //到定值通知主函數(shù)
   cnt=cnt+1;
