標題: STM32英文版ADC編程思路 [打印本頁]
作者: Cliff    時間: 2018-1-10 21:51
標題: STM32英文版ADC編程思路
STM32平臺完成一次ADC芯片的編程的過程對于一個菜鳥來說實在可怕
Power-up;
Delayto allow power supplies to settle and power-up reset to complete (minimum of 50µs);
Configurethe SPI interface of the stm32 to SPI mode 1 (CPOL = 0, CPHA = 1);
Ifthe CS pin is not tied low permanently, configure the stm32 GPIO connected toCS as an
output;
Configurethe stm32 GPIO connected to the DRDY pin as a falling edge triggered interrupt
input;
SetCS to the device low;
Delayfor a minimum of td(CSSC);
Sendthe RESET command (06h) to make sure the device is properly reset afterpower-up;
Delayfor a minimum of 50 µs + 32 · t(CLK);
Writethe respective register configuration with the WREG command (43h, 08h, 04h,10h, and 00h);
Asan optional sanity check, read back all configuration registers with the RREGcommand (23h);
Sendthe START/SYNC command (08h) to start converting in continuous conversion mode;
Delayfor a minimum of td(SCCS);
ClearCS to high (resets the serial interface);
Loop
Waitfor DRDY to transition low;
TakeCS low;
Send24 SCLK rising edges to read out conversion data on DOUT/DRDY;
ClearCS to high;
TakeCS low;
Sendthe POWERDOWN command (02h) to stop conversions and put the device in power-downmode;
ClearCS to high;
附錄一個菜鳥初次編程的ADC
ads1242.pdf
1.09 MB, 下載次數: 16, 下載積分: 黑幣 -5
你大可一試的ADC芯片
作者: wyh5360    時間: 2018-1-11 11:50
謝謝分享謝謝分享aaaaaaaaaa
作者: wyh5360    時間: 2018-1-11 11:51
謝謝分享謝謝分享樓主
