4*4鍵盤源程序基于stm32
[打印本頁(yè)]
李毫杰
時(shí)間:
2018-1-5 22:54
4*4鍵盤源程序基于stm32
(6.27 KB, 下載次數(shù): 48)
2018-1-9 01:18 上傳
單片機(jī)源程序如下:
//通過(guò)GPIOA的0—7腳pa.0-pa.3接列,上拉輸入。pa.4-pa.7接行推挽輸出。無(wú)按鍵按下時(shí)pa.0-pa.3均為高電平,當(dāng)當(dāng)對(duì)應(yīng)按鍵按下時(shí)接通的列輸出低電平將其引腳拉低返回相應(yīng)鍵值。
//通過(guò)GPIOA的pa.8-pa.11引腳接通4輸入數(shù)碼管,當(dāng)對(duì)應(yīng)引腳按下時(shí)數(shù)碼管顯相應(yīng)的值,key1對(duì)應(yīng)數(shù)碼管顯0.......key16對(duì)應(yīng)顯f
#include "stm32f10x.h"
#include "delay.h"
#include "stm32f10x_it.h"
#include "4X4.h"
u16 key_Pressed ,key_val=0; //存放鍵值
u8 key_Map[] = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16}; /*******************************************
* Check_Key(),檢查按鍵,確認(rèn)鍵值
函數(shù)名稱:Check_Key
功 能:掃描鍵盤的IO端口,獲得鍵值
參 數(shù):無(wú)
返回值 :key_val
int Check_Key(void)
u16 row ,col,tmp1,tmp2;
tmp1 = 0x10;
for(row = 0;row < 4;row++) //行掃描
GPIOA->ODR|=0x00f0; //PA.4-PA.7輸出1
GPIOA->ODR -= tmp1; //Pa.4~p.7輸出四位中有一個(gè)為0
tmp1 <<=1;
if ((GPIOA->IDR & 0x0f) < 0x0f) //是否PAIN的PA.0~PA.3中有一位為0
tmp2 = 0x01; // tmp2用于檢測(cè)出那一位為0
for(col = 0;col < 4;col++) // 列檢測(cè)
if((GPIOA->IDR&tmp2) == 0x00) // 是否是該列,等于0為是
key_val = key_Map[row * 4 + col]; // 獲取鍵值
return(key_val); // 退出循環(huán)
tmp2 <<= 1; // tmp2右移1位
void GPIO_Inita(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //使能PA端口時(shí)鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; //PA.4——PA.11端口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度為50MHz
GPIO_Init(GPIOA, &GPIO_InitStructure); //根據(jù)設(shè)定參數(shù)初始化GPIOA.8
GPIO_SetBits(GPIOA,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); //PA.8 輸出高
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //LED1-->PD.2 端口配置, 推挽輸出
GPIO_Init(GPIOA, &GPIO_InitStructure); //推挽輸出 ,IO口速度為50MHz
GPIO_SetBits(GPIOA, GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3); //PD.2 輸出高
4X4.zip
(1.54 KB, 下載次數(shù): 27)
2018-1-5 22:53 上傳
點(diǎn)擊文件名下載附件
