單片機+74hc165+Bee proteus仿真程序
立里
2017-12-30 10:03
Protues+74hc165+Bee
(20.42 KB, 下載次數: 61)
2017-12-30 23:33 上傳
#include "../inc/main.h"
// 參數定義
bool F_Timer01ms;
bool F_Timer02ms;
bool F_Timer10ms;
bool F_Time1_TimeOut;
uint8 P_TimerCount;
uint8 P_KeyValue;
Struct_BeeData BeeData;
Struct_SongData SongData;
uint16 P_TimerCountForBee;
// Function Name: void Setup_Timer(void)
// Function : setup timer0
// return value : void
//TMOD = 0xF0; //
//TH0 = (65536-TIME0)/256;
//TL0 = (65536-TIME0)%256;
//ET0 = 1; //
//EA = 1; //
//TR0 = 1; //
TMOD = 0x01 | 0x10;
// 定時器0用于播放一個音符的聲音
ET0 = 1;
// 定時器1用于計時一個音符的時間,然后切換下一個音符
ET1 = 1;
TR1 = 0;
// 定時器2用于1ms的計時
T2MOD = 0;
T2CON = 0;
TH2 = (65536-TIME2)/256;
TL2 = (65536-TIME2)%256;
ET2 = 1;
TR2 = 1;
// 開總中斷
EA = 1;
// Function Name: void main(void)
// Function : main function
void main(void)
HC165_CLK = 0;
HC165_INT = 0;
F_Timer01ms = 0;
F_Timer10ms = 0;
P_TimerCount = 0;
SongData.sFreq = 0;
Setup_Timer();
TF_Bee_Init_BeeData();
TF_Key_GetKeyValue();
TF_Song_Proccess();
// Function Name: void TF_Timer0(void)
// Function : timer0 interrupt
void TF_Timer0(void) interrupt 1
TR0 = 0;
TH0 = SongData.sTH;
TL0 = SongData.sTL;
BEE_OUTPUT = ~BEE_OUTPUT;
TR0 = 1;
// Function Name: void TF_Timer1(void)
// Function : Timer1 interrupt
void TF_Timer1(void) interrupt 3
TH1 = (65536-TIME1)/256;
TL1 = (65536-TIME1)%256;
// 定時時間到了就進行下一個音符并且準備下一個節拍
if(++SongData.sCount >= 3*SongData.sTime)
TR0 = 0;
TR1 = 0;
SongData.sCount = 0;
SongData.sFlag = true;
SongData.sIndex++;
// Function Name: void TF_Timer2(void)
// Function : Timer2 interrupt
void TF_Timer2(void) interrupt 5
F_Timer01ms = 1;
P_TimerCount++;
…………限于本文篇幅 余下代碼請從51黑下載附件…………
Protues+74hc165+Bee.zip
(108.18 KB, 下載次數: 51)
2017-12-30 10:03 上傳
protues
