求一個(gè)基于51單片機(jī)的匯編語言8路搶答器
ddddmpq
時(shí)間:
2017-12-27 19:09
2a2a
時(shí)間:
2018-7-3 11:34
OK EQU 20H ;搶答開始標(biāo)志位 RING EQU 22H ;響鈴標(biāo)志位 DATA0 EQU 36H ;搶答按鍵口數(shù)據(jù)存放地址 ORG 0000H AJMP MAIN ORG 0003H AJMP INTT0 ORG 000BH AJMP T0INT ORG 001BH AJMP T1INT ORG 0040H MAIN: MOV R1,#14H ;初設(shè)搶答時(shí)間為20s MOV R2,#1EH ;初設(shè)答題時(shí)間為30s MOV 38H,#3CH ;啟用錦囊時(shí)間從60s倒計(jì)時(shí) MOV TMOD,#11H ;設(shè)置未定時(shí)器/模式1 MOV TH0,#0F0H MOV TL0,#0FFH ;越高發(fā)聲頻率越高,越尖 MOV TH1,#3CH MOV TL1,#0B0H ;50ms為一次溢出中斷 SETB EA SETB ET0 SETB ET1 ;允許二個(gè)中斷,T0/T1 CLR OK CLR RING SETB TR1 SETB TR0 ;一開始就運(yùn)行定時(shí)器,以開始顯示FFF.如果想重新計(jì)數(shù),重置TH1/TL1就可以了 START: MOV DATA0,#0FFH ;初始化 MOV R5,#0BH MOV R4,#0BH MOV R3,#0BH ACALL DISPLAY ;未開始搶答時(shí)候顯示FFF JNB P3.3,SELSUB0 JNB P3.4,TZ3 ;倒計(jì)時(shí)調(diào)整 JB P3.0,NEXT ACALL DELAY JB P3.0,NEXT ;去抖動(dòng),如果"開始鍵"按下就向下執(zhí)行,否者跳到非法搶答查詢 SETB EX0 ;開放INT0 ACALL BARK ;按鍵發(fā)聲 MOV A,R1 MOV R6,A ;送R1->R6,因?yàn)镽1中保存了搶答時(shí)間 SETB OK ;搶答標(biāo)志位,在使用錦囊時(shí)用作判斷是搶答倒計(jì)時(shí)還是回答倒計(jì)時(shí) MOV R3,#0AH ;搶答只顯示計(jì)時(shí),滅號(hào)數(shù) AJMP COUNT ;進(jìn)入倒計(jì)時(shí)程序,"查詢有效搶答的程序"在COUNT里面 NEXT: JNB P1.0,FALSE1 JNB P1.1,FALSE2 JNB P1.2,FALSE3 JNB P1.3,FALSE4 JNB P1.4,FALSE5 JNB P1.5,FALSE6 JNB P1.6,TZ1 JNB P1.7,TZ2 AJMP START TZ1: AJMP FALSE7 TZ2: AJMP FALSE8 TZ3: AJMP SELSUB1 FALSE1: MOV R3,#01H AJMP ERROR FALSE2: MOV R3,#02H AJMP ERROR FALSE3: MOV R3,#03H AJMP ERROR FALSE4: MOV R3,#04H AJMP ERROR FALSE5: MOV R3,#05H AJMP ERROR FALSE6: MOV R3,#06H AJMP ERROR FALSE7: MOV R3,#07H AJMP ERROR FALSE8: MOV R3,#08H AJMP ERROR SELSUB0: MOV A,R1 MOV B,#0AH DIV AB MOV R5,A MOV R4,B MOV R3,#0AH ACALL DISPLAY ;先在兩個(gè)時(shí)間LED上顯示R1 JNB P3.5,INC0 ;P3.5為+1s鍵,如按下跳到INCO JNB P3.6,DEC0 ;P3.6為-1s鍵,如按下跳到DECO JNB P3.1,BACK0 ;P3.1為確定鍵,如按下跳到BACKO AJMP SELSUB0 INC0: MOV A,R1 CJNE A,#63H,ADD0 ;如果不是99,R2加1,如果加到99,R1就置0,重新加起。 MOV R1,#00H ACALL DELAY1 AJMP SELSUB0 ADD0: INC R1 ACALL DELAY1 AJMP SELSUB0 DEC0: MOV A,R1 JZ SETR1 ;如果R1為0, R1就置99, DEC R1 ACALL DELAY1 AJMP SELSUB0 SETR1: MOV R1,#63H ACALL DELAY1 AJMP SELSUB0 BACK0: AJMP START SELSUB1: MOV A,R2 MOV B,#0AH DIV AB MOV R5,A MOV R4,B MOV R3,#0AH ACALL DISPLAY JNB P3.5,INC1 JNB P3.6,DEC1 JNB P3.1,BACK1 AJMP SELSUB1 INC1: MOV A,R2 CJNE A,#63H,ADD1 MOV R2,#00H ACALL DELAY1 AJMP SELSUB1 ADD1: INC R2 ACALL DELAY1 AJMP SELSUB1 DEC1: MOV A,R2 JZ SETR2 DEC R2 ACALL DELAY1 AJMP SELSUB1 SETR2: MOV R2,#63H ACALL DELAY1 AJMP SELSUB1 BACK1: AJMP START REPEAT:MOV A,38h ;使用錦囊時(shí)重新計(jì)時(shí) MOV R6,A CLR RING ;當(dāng)?shù)褂?jì)時(shí)進(jìn)入最后5秒的時(shí)候,啟用錦囊能消除蜂鳴 COUNT:MOV R0,#00H ;重置定時(shí)器中斷次數(shù) MOV TH1,#3CH MOV TL1,#0B0H ;重置定時(shí)器 RECOUNT:MOV A,R6 ;R6保存了倒計(jì)時(shí)的時(shí)間,之前先將搶答時(shí)間或回答時(shí)間給R6 MOV B,#0AH DIV AB ;除十分出個(gè)位/十位 MOV 30H,A ;十位存于(30H) MOV 31H,B ;個(gè)位存于(31H) MOV R5,30H ;取十位 MOV R4,31H ;取個(gè)位 MOV A,R6 SUBB A,#07H JNC LARGER ;大于5s跳到LARGER,小于等于5s會(huì)提醒 MOV A,R0 CJNE A,#0AH,FULL ;1s中0.5s向下運(yùn)行 CLR RING AJMP CHECK FULL: CJNE A,#14H,CHECK ;下面是1s的情況,響并顯示號(hào)數(shù)并清R0,重新計(jì) SETB RING MOV A,R6 JZ QUIT ;計(jì)時(shí)完畢 MOV R0,#00H DEC R6 ;一秒標(biāo)志減1 AJMP CHECK LARGER: MOV A,R0 CJNE A,#14H,CHECK ;如果1s向下運(yùn)行,否者跳到"停/顯示" DEC R6 ;計(jì)時(shí)一秒R6自動(dòng)減1 MOV R0,#00H CHECK: JNB P3.1,QUIT ;如按下停止鍵退出 JNB OK,CHECKK ;只在回答倒計(jì)時(shí)才有效 AJMP NEXTT CHECKK:JNB P3.0,REPEAT ;判斷是否使用錦囊 NEXTT: ACALL DISPLAY JB OK,ACCOUT;如果是搶答倒計(jì)時(shí),如是則查詢搶答,否者跳過查詢繼續(xù)倒數(shù)(這里起到鎖搶答作用) AJMP RECOUNT ACCOUT:MOV A,DATA0 JNB ACC.0,TRUE1 JNB ACC.1,TRUE2 JNB ACC.2,TRUE3 JNB ACC.3,TRUE4 JNB ACC.4,TRUE5 JNB ACC.5,TRUE6 JNB ACC.6,TZ7 JNB ACC.7,TZ8 AJMP RECOUNT TZ7: AJMP TRUE7 TZ8: AJMP TRUE8 QUIT: CLR OK ;如果按下了"停止鍵"執(zhí)行的程序 CLR RING AJMP START TRUE1: ACALL BARK MOV A,R2 MOV R6,A ;搶答時(shí)間R2送R6 MOV R3,#01H CLR OK ;因?yàn)榇痤}的計(jì)時(shí)不再查詢搶答,所以就鎖了搶答 AJMP COUNT TRUE2:ACALL BARK MOV A,R2 MOV R6,A MOV R3,#02H CLR OK AJMP COUNT TRUE3:ACALL BARK MOV A,R2 MOV R6,A MOV R3,#03H CLR OK AJMP COUNT TRUE4:ACALL BARK MOV A,R2 MOV R6,A MOV R3,#04H CLR OK AJMP COUNT TRUE5: ACALL BARK MOV A,R2 MOV R6,A MOV R3,#05H CLR OK AJMP COUNT TRUE6: ACALL BARK MOV A,R2 MOV R6,A MOV R3,#06H CLR OK AJMP COUNT TRUE7: ACALL BARK MOV A,R2 MOV R6,A MOV R3,#07H CLR OK AJMP COUNT TRUE8: ACALL BARK MOV A,R2 MOV R6,A MOV R3,#08H CLR OK AJMP COUNT ERROR: MOV R0,#00H MOV TH1,#3CH MOV TL1,#0B0H MOV 34H,R3 ;犯規(guī)號(hào)數(shù)暫存與(34H) HERE: MOV A,R0 CJNE A,#06H,FLASH ;0.3s向下運(yùn)行->滅并停響 CLR RING MOV R3,#0AH MOV R4,#0AH MOV R5,#0AH ;三燈全滅 AJMP CHECK1 FLASH: CJNE A,#0CH,CHECK1 ;下面是0.8s的情況,響并顯示號(hào)數(shù)并清R0,重新計(jì) SETB RING MOV R0,#00H MOV R3,34H ;取回號(hào)數(shù) MOV R5,#0BH MOV R4,#0BH ;顯示FF和號(hào)數(shù) AJMP CHECK1 CHECK1: JNB P3.1,QUIT1 ACALL DISPLAY AJMP HERE QUIT1: CLR RING CLR OK AJMP START DISPLAY:MOV DPTR,#DAT1 ;查表顯示程序,利用P0口做段選碼口輸出/P2低三位做位選碼輸出 MOV A,R3 MOVC A,@A+DPTR MOV P2,#0feH MOV P0,A ACALL DELAY MOV DPTR,#DAT2 MOV A,R5 MOVC A,@A+DPTR MOV P2,#0fdH MOV P0,A ACALL DELAY MOV A,R4 MOVC A,@A+DPTR MOV P2,#0fbH MOV P0,A ACALL DELAY RET DAT1:DB 00h,06h,5bh,4fh,66h,6dh,7dh,07h,7fh,6fh,00H,71H ;"滅","1","2","3","4","5","6","7","8","9","滅","F" DAT2:DB 3fh,06h,5bh,4fh,66h,6dh,7dh,07h,7fh,6fh,00H,71H …………………… …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
