標題: 自己寫的51單片機的計算器程序 [打印本頁]
作者: 紫色的天空 時間: 2017-12-23 12:52
標題: 自己寫的51單片機的計算器程序
#include<reg52.h>
#define ucharunsigned char
#define uintunsigned int
#define weixuan P1
#define duan P0
int qian,bai,shi,ge;
intnum1,num2,num,keyvalue,keyvalue1;
uchar codetable[11]={0x14,0xd7,0x4c,0x45,0x87,0x25,0x24,0x57,0x04,0x05,0xff};//定義數碼管的數值0-9,0xff為滅。
uchar wei[4]={0,0,0,0};定義位。
//uchardisbuffer[4]={0,11,11,11};
void delayms(uintxms)//延時函數
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
temp=0x01; 顯示函數
void display()
qian=num/1000;
bai=num%1000/100;
shi=num%100/10;
ge=num%10;
weixuan = ~wei[1] ;
duan=table[ge];
delayms(1);
duan=0xff;
weixuan = ~wei[2] ;
duan=table[shi];
delayms(1);
duan=0xff;
weixuan = ~wei[3];
duan=table[bai];
delayms(1);
duan=0xff;
weixuan = ~wei[4] ;
duan=table[qian];
delayms(1);
duan=0xff;
delayms(1);
void init() // 初始化函數
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TR0=1;
ET0=1;
EA=1;
unsigned char keyscan() //按鍵掃描函數
unsigned char keytemp,keyvalue;
keyvalue1 = 0;
P3=0x0f;
keytemp=P3;
if(keytemp!=0x0f)
delayms(5);
return 0xff;
P3=0x0f;
keytemp=P3;
if(keytemp!=0x0f)
switch(keytemp)
case 0x0e:keyvalue=0;
break;
case 0x0d:keyvalue=1;
break;
case 0x0b:keyvalue=2;
break;
case 0x07:keyvalue=3;
break;
P3=0xf0;
keytemp=P3;
switch(keytemp)
case0xe0:keyvalue1=keyvalue+0;
break;
case0xd0:keyvalue1=keyvalue+4;
break;
case0xb0:keyvalue1=keyvalue+8;
break;
case0x70:keyvalue1=keyvalue+12;
break;
if(keyvalue1<10) //按鍵位移 并且給按鍵賦值
wei[4]=wei[3]<<1;
wei[3]=wei[2]<<1;
wei[2]=wei[1]<<1;
wei[1]=wei[0];
num=num*10+keyvalue1;
while(P3 != 0xf0);
return keyvalue1;
void yunsuan() //運算并且分辨按鍵的值
static uchar fh;//
if(fh==0)
num1=num;
num2=num;
if(keyvalue1==11)
switch(fh)
case 1:num=num1+num2;
break;
case 2:num=num1-num2;
break;
case 3:num=num1*num2;
break;
case 4:num=num1/num2;
break;
wei[4]=8,wei[1]=1,wei[2]=2,wei[3]=4;
if(keyvalue1>11)
switch(keyvalue1)
case 12:fh=1;break;
case 13:fh=2;break;
case 14:fh=3;break;
case 15:fh=4;break;
num=0;
wei[4]=0,wei[1]=0,wei[2]=0,wei[3]=0;
if (keyvalue1==10)
num=0,num1=0,num2=0,wei[4]=0,wei[1]=0,wei[2]=0,wei[3]=0;fh=0;
keyvalue1 = 0;
main() //主函數
init();
keyscan();
yunsuan();
display();
作者: 荒蕪. 時間: 2020-7-10 11:25
能不能批注下每個代碼的意思呢,我有些不太懂
作者: HSCCSH 時間: 2020-7-25 08:06
最好配上仿真原理圖和注釋就好了,作為新手的我是一頭霧水。
