標(biāo)題: 單片機(jī)煙霧傳感器報警實驗程序 [打印本頁]
作者: liusisi    時間: 2017-12-19 18:28
產(chǎn)品概述
Z-MQ-01模組采用MQ-2氣體傳感器配合8位高性價比單片機(jī), 內(nèi)部已做 AD 采集, 用戶只需串口讀數(shù)據(jù)即可,方便使用。該模組對液化氣、丙烷、氫氣的靈敏度高,對天然氣和其它可燃蒸汽的檢測也很理想。
單片機(jī)源程序如下:
  1. #include<reg52.h>
  2. #define  buf_len 9
  3. unsigned char temp[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  4. unsigned char write_buf[buf_len] = {0xff,0x01,0x86,0x00,0x00,0x00,0x00,0x00,0x79};
  5. char read_buf[buf_len] = {0};
  6. unsigned char uart_len = 0;
  7. unsigned char uart_RX_num = 0;
  8. void delay_ms(int ntime)
  9. {
  10.         int i;
  11.         while(ntime--)
  12.                 for(i = 0; i<120; i++);
  13. }
  14. void uart_init(void)
  15. {
  16.         TMOD=0x20;                 //用來定時器設(shè)置
  17.         TH1=0xfd;                 //設(shè)置初值 9600=(2的SMOD次方/32)*(TI溢出率)=(1/32)*(11059200/12)/(256-X)
  18.         TL1=0xfd;
  19.         TR1=1;                         //開啟定時器1
  20.         SM0=0;                         //設(shè)置串行口工作方式
  21.         SM1=1;
  22.         REN=1;                 //允許串行接收位
  23.         EA=1;                  //開啟總中斷
  24.         ES=1;                        //開啟串口中斷
  25.         //ES = 1;
  26. }
  27. void main(void)
  28. {
  29.         unsigned int i =0;
  30.         unsigned int oldcount = 0;
  31.         unsigned char flag = 1;
  32.         unsigned char g,s,b;
  33.         uart_init();
  34.         P1 = 0x00;
  35.         P0 = 0x00;
  36.
  37.
  38.         while(1)
  39.         {
  40.                 if(flag)
  41.                 {
  42.                         flag = 0;
  43.                         ES=0;          //關(guān)閉串口中斷
  44.                         for(i=0; i<9; i++)
  45.                         {
  46.                                 SBUF = write_buf[i];                         //發(fā)送數(shù)據(jù)a到SBUF,即將單片機(jī)的數(shù)據(jù)發(fā)送到計算機(jī)
  47.                                 while(!TI);                //發(fā)送數(shù)據(jù)后,TI自動置1
  48.                                 TI=0;                        //TI置0,才能進(jìn)行下次發(fā)送
  49.                         }
  50.                         ES=1;                        //打開中斷
  51.                 }
  52.                 i = 100;
  53.                 while(i--)
  54.                 {
  55.                         P1 = 0x01;
  56.                         P0 = temp[g];
  57.                         delay_ms(5) ;
  58.                         P1 = 0x02;
  59.                         P0 = temp[s];
  60.                         delay_ms(5);
  61.                         P1 = 0x04;
  62.                         P0 = temp[b];
  63.                         delay_ms(5);
  64.                 }
  65.                 if(uart_RX_num)
  66.                 {
  67.                         if(uart_RX_num == oldcount)
  68.                         {
  69.                                 ES=0;          //關(guān)閉串口中斷
  70.                                 for(i=0; i<buf_len; i++)
  71.                                 {
  72.                                         SBUF = read_buf[i];                         //發(fā)送數(shù)據(jù)a到SBUF,即將單片機(jī)的數(shù)據(jù)發(fā)送到計算機(jī)
  73.                                         while(!TI);                //發(fā)送數(shù)據(jù)后,TI自動置1
  74.                                         TI=0;                        //TI置0,才能進(jìn)行下次發(fā)送
  75.                                 }
  76.
  77.                                 g =  (read_buf[3]%16);
  78.                                 s =  (read_buf[3]/16);
  79.                                 b =  (read_buf[2]%16);
  80.                                 ES=1;                        //打開中斷
  81.                                 flag = 1;
  82.                         }
  83.                         else
  84.                                 oldcount = uart_RX_num;
  85.                 }
  86. ……………………
  87. …………限于本文篇幅 余下代碼請從51黑下載附件…………
煙霧傳感器.zip (230.68 KB, 下載次數(shù): 111)
作者: 517072274    時間: 2018-5-31 20:07
666666
作者: ggt    時間: 2018-12-21 20:04
666666可以
作者: 單片機(jī)不歸路    時間: 2019-4-20 19:25
樓主的程序相當(dāng)及時,煙霧傳感器的控制程序網(wǎng)上比較少,此處應(yīng)當(dāng)有掌聲
作者: itsufan    時間: 2020-5-7 16:25
謝謝分享,學(xué)習(xí)學(xué)習(xí)
作者: 228972436    時間: 2020-5-8 10:16
有顯示濃度的嗎
