單片機(jī)紅外遙控系統(tǒng)代碼
[打印本頁(yè)]
11112zaq
時(shí)間:
2017-12-7 15:53
紅外遙控系統(tǒng)代碼
單片機(jī)源程序如下:
#include <reg52.h> //包含頭文件,一般情況不需要改動(dòng),頭文件包含特殊功能寄存器的定義
#include "1602.h"
#include "delay.h"
#include "stdio.h"
sbit IR=P3^2; //紅外接口標(biāo)志
全局變量聲明
unsigned char irtime;//紅外用全局變量
bit irpro_ok,irok;
unsigned char IRcord[4];
unsigned char irdata[33];
unsigned char TempData[16];
char code Tab[16]="0123456789ABCDEF";
//選定的紅外遙控器按鍵,鍵值為提前讀取的
unsigned char code LED_data[16][4]={
{0x00,0xff,0x16,0xe9},//0
{0x00,0xff,0x0C,0xf3},//1
{0x00,0xff,0x18,0xe7},//2
{0x00,0xff,0x5e,0xa1},//3
{0x00,0xff,0x08,0xf7},//4
{0x00,0xff,0x1c,0xe3},//5
{0x00,0xff,0x5a,0xa5},//6
{0x00,0xff,0x42,0xbd},//7
{0x00,0xff,0x52,0xad},//8
{0x00,0xff,0x4a,0xb5},//9
{0x00,0xff,0x45,0xba},//關(guān)閉
{0x00,0xff,0x46,0xb9},//Mode
{0x00,0xff,0x47,0xb8},//靜音
{0x00,0xff,0x44,0xbb},//下一首
{0x00,0xff,0x40,0xbf},//后退
{0x00,0xff,0x43,0xbc} //前進(jìn)
bit check_array(unsigned char *array1,unsigned char *array2,unsigned char len)
int i;
for(i=0;i<len;i++)
if(array1[i]!=array2[i])
break;//如果不等,結(jié)束循環(huán),此時(shí)i的值是小于5的
if(i==len) //相同返回1,不同返回0
return 1;
return 0;
unsigned char KEY_SCANF()
unsigned char KEY_i=0;
for(KEY_i=0;KEY_i<16;KEY_i++)
if(check_array(IRcord,LED_data[KEY_i],4)) //如果是選定的按鍵
return KEY_i;
return 20;
定時(shí)器0中斷處理
void tim0_isr (void) interrupt 1
irtime++; //用于計(jì)數(shù)2個(gè)下降沿之間的時(shí)間
外部中斷0中斷處理
void EX0_ISR (void) interrupt 0 //外部中斷0服務(wù)函數(shù)
static unsigned char i; //接收紅外信號(hào)處理
static bit startflag; //是否開(kāi)始處理標(biāo)志位
if(startflag)
if(irtime<63&&irtime>=33)//引導(dǎo)碼 TC9012的頭碼,9ms+4.5ms
i=0;
irdata[i]=irtime;//存儲(chǔ)每個(gè)電平的持續(xù)時(shí)間,用于以后判斷是0還是1
irtime=0;
i++;
if(i==33)
irok=1;
i=0;
irtime=0;
startflag=1;
定時(shí)器0初始化
void TIM0init(void)//定時(shí)器0初始化
TMOD=0x02;//定時(shí)器0工作方式2,TH0是重裝值,TL0是初值
TH0=0x00; //重載值
TL0=0x00; //初始化值
ET0=1; //開(kāi)中斷
TR0=1;
外部中斷0初始化
void EX0init(void)
IT0 = 1; //指定外部中斷0下降沿觸發(fā),INT0 (P3.2)
EX0 = 1; //使能外部中斷
EA = 1; //開(kāi)總中斷
鍵值處理
void Ir_work(void)
unsigned char temp[16],yyy;
TempData[0] = Tab[IRcord[0]/16]; //處理客戶碼
TempData[1] = Tab[IRcord[0]%16];
TempData[2] = '-';
TempData[3] = Tab[IRcord[1]/16]; //處理客戶碼
TempData[4] = Tab[IRcord[1]%16];
TempData[5] = '-';
TempData[6] = Tab[IRcord[2]/16]; //處理數(shù)據(jù)碼
TempData[7] = Tab[IRcord[2]%16];
TempData[8] = '-';
TempData[9] = Tab[IRcord[3]/16]; //處理數(shù)據(jù)反碼
TempData[10] = Tab[IRcord[3]%16];
LCD_Write_String(5,0,TempData);
yyy=KEY_SCANF();
if(yyy!=20)
sprintf(temp,"%d " ,(unsigned int)yyy);
LCD_Write_String(10,1,temp);
switch(yyy)
case 0: {P1=0X7F;P2=0XFF;};break;
case 1: {P1=0XBF;P2=0XFF;};break;
case 2: {P1=0XDF;P2=0XFF;};break;
case 3: {P1=0XEF;P2=0XFF;};break;
case 4: {P1=0XF7;P2=0XFF;};break;
case 5: {P1=0XFB;P2=0XFF;};break;
case 6: {P1=0XFD;P2=0XFF;};break;
case 7: {P1=0XFe;P2=0XFF;};break;
case 8: {P1=0XFF;P2=0XFE;};break;
case 9: {P1=0XFF;P2=0XFD;};break;
case 10: {P1=0XFF;P2=0XFB;};break;
case 11: {P1=0XFF;P2=0XF7;};break;
case 12: {P1=0XFF;P2=0XEF;};break;
case 13: {P1=0XFF;P2=0XDF;};break;
case 14: {P1=0XFF;P2=0XBF;};break;
case 15: {P1=0XFF;P2=0X7F;};break;
default: {P1=0XFF;P2=0XfF;};break;
LCD_Write_String(10,1,"Error!");
irpro_ok=0;//處理完成標(biāo)志
紅外碼值處理
void Ircordpro(void)//紅外碼值處理函數(shù)
unsigned char i, j, k;
unsigned char cord,value;
k=1;
for(i=0;i<4;i++) //處理4個(gè)字節(jié)
for(j=1;j<=8;j++) //處理1個(gè)字節(jié)8位
cord=irdata[k];
if(cord>7)//大于某值為1,這個(gè)和晶振有絕對(duì)關(guān)系,這里使用12M計(jì)算,此值可以有一定誤差
value|=0x80;
if(j<8)
value>>=1;
k++;
IRcord[i]=value;
value=0;
irpro_ok=1;//處理完畢標(biāo)志位置1
主函數(shù)
void main(void)
…………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
無(wú)線遙控系統(tǒng)代碼.rar
(59.74 KB, 下載次數(shù): 18)
2017-12-7 15:53 上傳
點(diǎn)擊文件名下載附件
微傻呀
時(shí)間:
2018-5-30 15:46
有msp430f6638的有嗎?分享一下吧謝謝
