電路圖如圖
對房間溫度濕度采集顯示,并且控制,啟動壓縮機
- 聲明:本程序僅供大家參考學習,未經(jīng)本人同意禁止用于商業(yè)用途。
- #include <reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- #include <intrins.h>
- typedef bit BOOL ;
- sbit io = P1^1 ;//(口線定義)
- sbit bee=P1^0;
- sbit rs = P2^5 ;
- sbit rw = P2^6 ;
- sbit ep = P2^7 ;
- bit flag_300ms ;
- sbit K1=P1^2;
- sbit K2=P1^3;
- sbit K3=P1^4;
- uchar yemian=0;//(定義變量)
- uchar flat=1;
- uchar data_byte;
- uchar RH,RL,TH,TL;
- uchar WenDu,ShiDu;//報警的溫度和濕度
- #include "eeprom52.h"
- /****************************延時程序****************************/
- void delay(uchar ms)
- { // 延時子程序
- uchar i ;
- while(ms--)
- for(i = 0 ; i<250;i++) ;
- void delay1()//延時10us
- uchar i;
- i--;
- i--;
- i--;
- i--;
- i--;
- i--;
- void longdelay(uchar s) //長延時
- while(s--)
- delay(20) ;
- /******************把數(shù)據(jù)保存到單片機內(nèi)部eeprom中******************/
- void write_eeprom()
- SectorErase(0x2000);
- byte_write(0x2000, WenDu);
- byte_write(0x2001, ShiDu);
- byte_write(0x2060, a_a);
- /******************把數(shù)據(jù)從單片機內(nèi)部eeprom中讀出來*****************/
- void read_eeprom()
- WenDu = byte_read(0x2000);
- ShiDu = byte_read(0x2001);
- a_a = byte_read(0x2060);
- /**************開機自檢eeprom初始化*****************/
- void init_eeprom()
- read_eeprom(); //先讀
- if(a_a != 2) //新的單片機初始單片機內(nèi)問eeprom
- WenDu = 30;
- ShiDu = 80;
- a_a = 2;
- write_eeprom();
- /********************報警程序部分*******************/
- void warn() //報警函數(shù)
- if(TH>=WenDu) //檢測的溫度高于設定溫度報警值
- bee=0; //報警
- if(RH>=ShiDu) //檢測的濕度高于設定的濕度值
- bee=0; //報警
- if( TH<WenDu && RH<ShiDu )
- bee=1; //停止報警
- /************************LCD模塊******************************************/
- BOOL lcd_bz()//測試LCD忙碌狀態(tài)
- BOOL result ;
- rs = 0 ;
- rw = 1 ;
- ep = 1 ;
- result = (BOOL)(P0 & 0x80) ;
- ep = 0 ;
- return result ;
- void write_cmd(uchar cmd)// 寫指令
- while(lcd_bz()) ;
- rs = 0 ;
- rw = 0 ;
- ep = 0 ;
- P0 = cmd ;
- ep = 1 ;
- ep = 0 ;
- void write_addr(uchar addr)//寫地址
- write_cmd(addr|0x80) ;
- void write_byte(uchar dat)//寫字節(jié)
- while(lcd_bz()) ;
- rs = 1 ;
- rw = 0 ;
- ep = 0 ;
- P0 = dat ;
- ep = 1 ;
- ep = 0 ;
- void lcd_init()// 初始化
- write_cmd(0x38) ;
- delay(1);
- write_cmd(0x08) ;
- delay(1);
- write_cmd(0x01) ;
- delay(1);
- write_cmd(0x06) ;
- delay(1);
- write_cmd(0x0c) ;
- delay(1);
- void display(uchar addr, uchar q)//在某一地址上顯示一字節(jié)
- delay(1) ;
- write_addr(addr) ;
- write_byte(q) ;
- delay(1) ;
- /*********************** DHT11測試模塊***************************************/
- void start()//開始信號
- io=1;
- delay1();
- io=0;
- delay(20);//>18ms
- io=1;
- delay1();//20-40us
- delay1();
- delay1();
- delay1();
- delay1();
- uchar receive_byte()//接收一個字節(jié)
- uchar i,temp,count;
- for(i=0;i<8;i++)
- temp=0;
- delay1();delay1();delay1();delay1();
- if(io==1)temp=1;
- count=2;
- while((io)&&count++);
- if(count==1)break;
- data_byte<<=1;
- data_byte|=temp;
- return data_byte;
- void receive()//接收數(shù)據(jù)
- uchar T_H,T_L,R_H,R_L,check,num_check;
- uchar count;
- start();//開始信號
- io=1;
- if(!io)//讀取DHT11響應信號
- R_H=receive_byte();
- R_L=receive_byte();
- T_H=receive_byte();
- T_L=receive_byte();
- check=receive_byte();
- io=0;//拉低延時50us
- delay1();delay1();delay1();delay1();delay1();
- io=1;
- num_check=R_H+R_L+T_H+T_L;
- if(num_check=check)
- RH=R_H;
- RL=R_L;
- TH=T_H;
- TL=T_L;
- check=num_check;
- void showw() // 問候語函數(shù)
- lcd_init(); //初始化
- delay(10);
- display(0x05,'W');
- display(0x06,'e');
- display(0x07,'l');
- display(0x08,'c');
- display(0x09,'o');
- display(0x0a,'m');
- display(0x0b,'e');
- delay(250); //短暫延時
- delay(250);
- delay(250);
- display(0x40,' ') ;
- display(0x41,'h');
- display(0x42,'e');
- /*************定時器0初始化程序***************/
- void time_init()
- EA = 1; //開總中斷
- TMOD = 0X01; //定時器0、定時器1工作方式1
- ET0 = 1; //開定時器0中斷
- TR0 = 1; //允許定時器0定時
- void key() //按鍵程序 選擇菜單模式
- if(!K1)
- delay(20);
- if(!K1)
- while(!K1)
- yemian++;
- flat++;
- if(yemian>=3) { yemian=0; }
- shezhi() //對里面的數(shù)值進行修改
- if(!K2)
- delay(50);
- if(!K2)
- if(yemian==1)
- WenDu+=1;
- if(WenDu>99) { WenDu=99; } //濕度上限加
- if(yemian==2)
- ShiDu+=1;
- if(ShiDu>99) { ShiDu=99; } //濕度下限加
- write_eeprom(); //保存數(shù)據(jù)
- if(!K3)
- delay(50);
- if(!K3)
- if(yemian==1)
- WenDu-=1; //濕度下限減
- if(WenDu<1) {WenDu=1; }
- if(yemian==2)
- ShiDu-=1; //濕度下限減
- if(ShiDu<1) { ShiDu=1; }
- /***************************主程序*********************************/
- void main()
- init_eeprom(); //讀eeprom數(shù)據(jù)
- time_init(); //初始化定時器
- showw(); //顯示問候語 和名字
- while(1)
- key();
- //====================yemian==0時 進入工作狀態(tài)=================================
- if(yemian==0)
- if(flat==1)
- flat=0;
- lcd_init(); //初始化
- display(0x00,'T') ; //Temp
- display(0x01,'e');
- display(0x02,'m');
- display(0x03,'p');
- display(0x04,':');
- display(0x08,0xdf); // 度
- display(0x09,'C');
- display(0x40,'H') ; //Humi
- display(0x41,'u');
- display(0x42,'m');
- display(0x43,'i');
- display(0x44,':');
- display(0x47,'%');
- display(0x48,'R');
- display(0x49,'H');
- display(0x0c,'T');
- display(0x0d,':');
- display(0x0e,WenDu/10+0x30); //報警溫度
- display(0x0f,WenDu%10+0x30);
- display(0x4c,'H');
- display(0x4d,':');
- display(0x4e,ShiDu/10+0x30); //報警濕度
- display(0x4f,ShiDu%10+0x30);
- if(flag_300ms == 1)
- flag_300ms = 0;
- receive();
- display(0x05,TH/10+0x30); //溫度顯示
- display(0x06,TH%10+0x30);
- display(0x45,RH/10+0x30); //濕度顯示
- display(0x46,RH%10+0x30);
- warn();
- //====================yemian==1 溫度設置===========================
- if(yemian==1) //溫度
2樓
