BL51 BANKED LINKER/LOCATER V6.22 - SN: Eval Version
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2009
"STARTUP.obj",
"1602.obj",
"MAIN.obj",
"dht11.obj"
TO "CX"
RAMSIZE(256)
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
SEGMENT: ?PR?LCDOPENCURSOR?1602
SEGMENT: ?PR?LCDCLOSECURSOR?1602
SEGMENT: ?PR?_INTTOSTRING?MAIN
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 083FH BYTE (103%) *
Program Size: data=76.4 xdata=0 code=2805
LINK/LOCATE RUN COMPLETE. 3 WARNING(S), 0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
MODULE: D:\KEIL\C51\LIB\C51S.LIB (-----)
LIMIT: 0800H BYTES
Target not created
我 的為什么不能創建成功 |
