AWU的應(yīng)用 用庫函數(shù)完成的
//切記要開啟中斷 且在中斷函數(shù)中 AWU_GetFlagStatus(); 來清除中斷
void AWU_SET(void)
CLK_PeripheralClockConfig(CLK_PERIPHERAL_AWU, ENABLE);
AWU_Init(AWU_TIMEBASE_12S);
#ifdef _COSMIC_
@far @interrupt void AWU_IRQHandler(void)
#else
void AWU_IRQHandler(void) interrupt 1
#endif
IWDG應(yīng)用 直接操作寄存器完成的 在需要清狗的地方調(diào)用WDT_CLR()即可
void WDT_CLR(void )
IWDG->KR = IWDG_KEY_REFRESH;
void START_WDT(void )
IWDG->KR =0X55;//打開保護(hù)
IWDG->PR = IWDG_Prescaler_256;// 28Khz 256分頻
IWDG->RLR = 254;//重載寄存器設(shè)定 每當(dāng)喂狗時(shí) 此值就會(huì)重載
IWDG->KR = IWDG_KEY_REFRESH;//先喂一次
IWDG->KR = IWDG_KEY_ENABLE;//啟動(dòng)看門狗
、、==================WWDG============
WWDG-CR是向下的計(jì)數(shù)器,數(shù)到0x40就會(huì)復(fù)位,窗口的上限可以任你設(shè),最大7F,如果設(shè)成7F,幾乎就成了沒有窗口的看門狗了。 窗口的意思是假如你設(shè)是0x60,那么只有在0X60-0X40間可以喂狗,其它時(shí)間喂,狗就會(huì)復(fù)位你的單片機(jī),所以喂狗前要先判斷狗餓否。
typedef unsigned char uint8_t;
void WWDG_Init(uint8_t Counter, uint8_t WindowValue)
//assert_param(IS_WWDG_WINDOWLIMITVALUE_OK(WindowValue));
WWDG->WR =WWDG_WR_RESET_VALUE;
WWDG->CR =(uint8_t)((uint8_t)(WWDG_CR_WDGA | WWDG_CR_T6) |(uint8_t)Counter);
WWDG->WR =(uint8_t)((uint8_t)(~WWDG_CR_WDGA) & (uint8_t)(WWDG_CR_T6 |WindowValue));
#define BIT_MASK ((uint8_t)0x7F)
void WWDG_SetCounter(uint8_t Counter)
WWDG->CR = (uint8_t)(Counter &(uint8_t)BIT_MASK);
#define window_max 0x60
#define wwdg_reset0x70
void WWDG_CLR(void)
{//狗餓否
if ((WWDG->CR)&0x7f)<window_max)WWDG_SetCounter(wwdg_reset) ;
main()
{WWDG_Init(wwdg_reset,window_max );
{WWDG_CLR
