附件是EV1527的用單片機解碼的詳細資料,歡迎下載參考!
2019-2-22 17:18 上傳
2019-2-22 17:16 上傳
2019-2-22 17:17 上傳
2019-2-22 17:17 上傳
- //#include "main.h"
- //#include "remote.h"
- //#include "key.h"
- #include "include.h"
- const uint PULSE_SHORT_MIN=PULSE_SHORT_MIN_TIME/8/4; //1。8ms
- const uint PULSE_SHORT_MAX=PULSE_SHORT_MAX_TIME/8/4; //3ms
- const uint PULSE_LONG_MIN=PULSE_SHORT_MIN_TIME/8/4*3;
- const uint PULSE_LONG_MAX=PULSE_SHORT_MAX_TIME/8/4*3;
- const uint PULSE_SYN_MAX=PULSE_SHORT_MAX_TIME/8/4*35;
- const uint PULSE_SYN_MIN=PULSE_SHORT_MIN_TIME/8/4*20;
- const uint DT=(uint)((PULSE_SHORT_MIN_TIME/8/4+PULSE_SHORT_MIN_TIME/8/4)*0.1/2);
- bank2 SharkFlagStruct SharkFlag={2};
- bank1 ulong PassWord[2]; //waste 2B ram; 20bit
- static bank1 RemindStateEnum RemindState=DOOR_OPEN;
- static bank1 uchar PressUnlock=0;
- static Timer16Struct GuardQuiet5s={0,1}; //延時5s進入警戒狀態;
- static bank1 AlarmGradeEnum AlarmGrade=Guard;
- static bank1 OpenStepEnum OpenStep=OPEN_REMIND;
- static EnergencyEnum Energency=PRESS_FIND;
- static bank1 bit SystemGuardChangeFirstTime=0;
- bank2 LearnStepEnum LearnStep=FRIST_DATA;
- bank2 Timer16Struct AlarmSharkTimer={0,0};
- bank1 Timer16Struct DoorOpenTimer={0,0};
- bank1 uchar AlarmNoub=0;
- bit remote_key_dither(ulong data)
- static bank1 ulong LastRemote;
- if(data==LastRemote)
- if(RemoteKey.Flag.FirstPress==1)
- RemoteKey.Flag.Press=1;
- RemoteKey.Flag.FirstPress=0;
- RemoteKey.Key=get_key(data);
- RemoteKey.Rec=data;
- RemotePressTimeOut.Interval=0;
- RemoteKey.Time.Interval=RemotePressTime.Interval;
- RemotePressTime.enable=1;
- RemotePressTimeOut.enable=1;
- LastRemote=data;
- //RemoteKey.Key=get_key(data);
- return 1;
- else
- //for error process;
- RemoteKey.Flag.Release=0;
- RemoteKey.Flag.Press=0;
- RemoteKey.Flag.FirstPress=1;
- RemotePressTime.Interval=0;
- LastRemote=data;
- return 0;
- ulong get_password(ulong data)
- //ulong pass;
- //pass=(data&0x00ffffff)>>4;
- //return(pass);
- return((data&0x00ffffff)>>4);
- uchar get_key(ulong data)
- ulong pd;
- uchar KeyValue;
- pd=data&0x0f;
- KeyValue=(uchar)(pd);
- if(KeyValue==0x08) return KEY_LOCK;
- else if(KeyValue==0x0c) return KEY_UNLOCK;
- else if(KeyValue==0x03) return KEY_QUIET;
- else if(KeyValue==0x0f) return KEY_FIND;
- #ifdef BOOT_EN
- else if(KeyValue==0x04) return KEY_BOOT;
- #endif
- else return KEY_UNKNOW;
- bit decode(ulong data)
- ulong Word;
- Word=get_password(data);
- if(PassWord[0]==Word||PassWord[1]==Word)
- return 1;
- else return 0;
- //void remind_shutdown(void)
- bit remind_shutdown(void)
- static bank1 Timer16Struct DelayTime=0;
- if(InState.SideDoor==DOOR_OPENED)
- RemindState=DOOR_OPEN;
- DelayTime.Interval=0;
- switch(RemindState)
- case DOOR_OPEN:
- RemindState=DOOR_CLOSE;
- break;
- case DOOR_CLOSE:
- if(InState.SideDoor==DOOR_CLOSED)
- RemindState=DELAY_5S;
- break;
- case DELAY_5S:
- if(DelayTime.Interval++>=REMIND_SHUT_DELAY_TIME)
- RemindState=REMIND;
- speak_act_precoss(0,0,0,RESET); //reset speak;
- break;
- case REMIND:
- flash_trun_signal(120/TIME_BASE,1400/TIME_BASE,3);
- if(speak_act_precoss(40/TIME_BASE,1480/TIME_BASE,3,SHORT))
- RemindState=DELAY_60S;
- flash_trun_signal(0,0,0);
- break;
- case DELAY_60S:
- if(DelayTime.Interval++>=REMIND_DELAY_60S)
- RemindState=CHANGE_STATE;
- break;
- case CHANGE_STATE:
- RemindState=STATE_END;
- if(Jump.SlefThorth)
- system_state_change(State,GUARD_QUIET,1);
- return 1;
- //PreState=State;
- //State=GUARD_QUIET;
- break;
- case STATE_END:
- break;
- default:break;
- return 0;
- bit alarm_led_long_light(uchar LightTime,uchar DrownTime)
- static Timer16Struct RunTime=0;
- if(LightTime==0)
- RunTime.Interval=0;
- ALARM_LED=0;
- else
- if(++RunTime.Interval<=LightTime*125)
- ALARM_LED=1;
- else if(RunTime.Interval<=125*(LightTime+DrownTime))
- ALARM_LED=0;
- else
- return 1;
- return 0;
- // Times :125ms //
- // Second: 1s //
- void flash_alarm_led(uchar Times,uchar Second)
- if(AlarmLed.Flag.ms125)
- AlarmLed.Flag.ms125=0;
- AlarmLed.Flag.Time++;
- if(AlarmLed.Flag.Time<=Times)
- ALARM_LED=!ALARM_LED;
- else if(AlarmLed.Flag.Time<=Times+Second*8) //2s
- ALARM_LED=0;
- else
- AlarmLed.Flag.Time=0;
- bit flash_alarm_led(uchar Times,uchar Second)
- //ALARM_LED=1;
- ALARM_LED=0;
- else
- return 1;
- return 0;
- void signal_led_alarm(AlarmGradeEnum state)
- if(state==Guard)
- flash_alarm_led(4,2);
- else if(state==Shaked)
- flash_alarm_led(6,2);
- else if(state==Opened)
- alarm_led_long_light(4,4);
- else if(state==Unchain)
- alarm_led_long_light(6,0);
- uchar flash_trun_signal(uint PulseTime1,uint Interval1,uchar Times1)
- static bank2 uint RunTime1=0;
- static bank2 uchar CTime1=0; //continuance time;
- Used.TrunSignal=1;
- if((PulseTime1==0)&&(Interval1==0))
- Used.TrunSignal=0;
- RunTime1=0;
- TRUN_SIGNAL=0;
- CTime1=0;
- return 1;
- else
- if(CTime1<Times1)
- if(++RunTime1<=PulseTime1)
- TRUN_SIGNAL=1;
- else if(RunTime1<=(PulseTime1+Interval1))
- TRUN_SIGNAL=0;
- else
- CTime1++;
- RunTime1=0;
- return 0;
- else
- CTime1=Times1;
- TRUN_SIGNAL=0;
- return 1;
- //PulseTime:喇叭鳴叫時間(20ms) //
- //Interval:喇叭不鳴叫時間(20ms) //
- //Time:持續時間20ms(LONG),次數(SHORT) //M
- //Para:參數 //
- //返回 0:還在鳴叫 1:已經結束 //
- bit speak_act_precoss(uchar PulseTime,uint Interval,uint Time,uchar Para)
- static bank1 uint RunTime=0;
- static bank1 ulong CTime=0; //continuance time;
- Used.Speaker=1;
- if(Para==LONG)
- if(++CTime<=Time*5)
- if(!Jump.Quiet)
- SPEAKER=1;
- return 0;
- else
- CTime=0;
- SPEAKER=0;
- return 1;
- else if(Para==SHORT)
- if(CTime<Time)
- if(++RunTime<=PulseTime)
- if(!Jump.Quiet)
- SPEAKER=1;
- else if(RunTime<=(PulseTime+Interval))
- SPEAKER=0;
- else
- CTime++;
- RunTime=0;
- return 0;
- else
- CTime=Time;
- SPEAKER=0;
- return 1;
- else if(Para==RESET)
- RunTime=0;
- SPEAKER=0;
- CTime=0;
- Used.Speaker=0;
- return 1;
- return 1;
- /////////////time:20ms//////////
- bit door_lock_process(uchar time,uchar operate)
- Used.Lock=1;
- if(time==0)
- RunTime=0;
- Used.Lock=0;
- else
- if(++RunTime<=time*5)
- if(operate==LOCK_ON)
- CCU1=CCU_OFF;
- CCU2=CCU_ON;
- else
- CCU1=CCU_ON;
- CCU2=CCU_OFF;
- return 0;
- else
- RunTime=time*5;
- CCU1=CCU_OFF;
- CCU2=CCU_OFF;
- return 1;
- return 1;
- Used.Lock=1;
- if(time==0)
- RunTime=0;
- Used.Lock=0;
- Flag.OpenOrCloseDoor=0;
- DoorOpenTimer.enable=0;
- DoorOpenTimer.Interval=0;
- CCU1=CCU_OFF;
- CCU2=CCU_OFF;
- else
- DoorOpenTimer.enable=1;
- Flag.OpenOrCloseDoor=1;
- if(Jump.Electromotion)
- CCU1=CCU_OFF;
- CCU2=CCU_ON;
- else
- CCU1=CCU_ON;
- CCU2=CCU_OFF;
- return 0;
- else
- RunTime=time*5;
- CCU1=CCU_OFF;
- CCU2=CCU_OFF;
- return 1;
- return 1;
- bit frameout_precoss(uint Interval)
- Used.Engine=1;
- if(Interval==0)
- RunTime=0;
- Used.Engine=0;
- ENGINE_OFF=0;
- else if(Interval==0xffff)
- ENGINE_OFF=1;
- else
- if(++RunTime<=Interval*125)
- ENGINE_OFF=1;
- return 0;
- else
- RunTime=Interval*125;
- ENGINE_OFF=0;
- return 1;
- void roadside_stop(void)
- //路邊停車
- if(!Used.TrunSignal)
- if(flash_trun_signal(500/TIME_BASE,500/TIME_BASE,18));
- //flash_trun_signal(0,0,0);
- else
- void door_opened_guard(void)
- static bank1 Timer16Struct Timer35s=0;
- frameout_precoss(0xffff);//一直讓引擎關閉
- switch(OpenStep)
- case OPEN_REMIND:
- //frameout_precoss(0xffff);
- flash_trun_signal(120/TIME_BASE,580/TIME_BASE,3);
- if(speak_act_precoss(40/TIME_BASE,660/TIME_BASE,3,SHORT))
- OpenStep=OPEN_DELAY_10S;
- Timer35s.Interval=0;
- break;
- case OPEN_DELAY_10S:
- if(++Timer35s.Interval>=10000/TIME_BASE)
- OpenStep=OPEN_ALARM;
- if(InState.SideDoor!=DOOR_OPENED)
- Flag.DoorOpenedGuard=0;
- break;
- case OPEN_ALARM:
- flash_trun_signal(500/TIME_BASE,500/TIME_BASE,240);
- if(speak_act_precoss(0,0,240000/TIME_BASE/5,LONG))
- OpenStep=OPEN_STOP;
- break;
- case OPEN_STOP:
- break;
- default:break;
- #ifdef BOOT_EN
- bit open_boot(uchar Interval)
- static bank1 BootTimer=0;
- if(Interval==0)
- BOOT=0;
- BootTimer=0;
- else
- if(++BootTimer<=Interval*5)
- BOOT=1;
- return 0;
- else
- BootTimer=Interval*5;
- BOOT=0;
- return 1;
- return 1;
- #endif
- void normal_process(void)
- static bank1 AutoRestoreStruct AutoRestore=0;
- if(Flag.SystemStateChange)
- AutoRestore.Flag.Shaked=0;
- AutoRestore.Flag.Opened=0;
- AutoRestore.Time.Interval=0;
- Flag.RememTouch=0;
- switch(PreState)
- case GUARD_SOUND:
- door_lock_process(500/TIME_BASE/5,LOCK_OFF);
- if(PressUnlock==0)
- speak_act_precoss(50/TIME_BASE,200/TIME_BASE,2,SHORT);
- if(flash_trun_signal(250/TIME_BASE,250/TIME_BASE,2))
- Flag.SystemStateChange=0;
- if(Jump.Electromotion) door_lock_process(0,0);
- break;
- case GUARD_QUIET:
- //if(speak_act_precoss(50/TIME_BASE,200/TIME_BASE,2,SHORT));
- break;
- case RUN:
- if(PressUnlock>0)
- else
- if(door_lock_process(500/TIME_BASE/5,LOCK_OFF))
- break;
- default:
- break;
- else
- if(RemoteKey.Flag.Press)
- switch(RemoteKey.Key)
- case KEY_LOCK:
- system_state_change(State,GUARD_SOUND,1);
- //break;
- return ;
- case KEY_QUIET:
- //break;
- return ;
- case KEY_FIND:
- system_state_change(State,FIND,1);
- //break;
- return ;
- case KEY_UNLOCK:
- if(++PressUnlock<=3)
- Flag.SystemStateChange=1;
- else
- PressUnlock=3;
- break;
- #ifdef BOOT_EN
- case KEY_BOOT:
- Flag.Boot=1;
- open_boot(0);
- break;
- #endif
- default:
- break;
- // 進入行駛
- #ifdef BOOT_EN
- if(Flag.Boot)
- Flag.Boot=0;
- open_boot(500/TIME_BASE/5);
- #endif
- if(InState.Acc)
- system_state_change(State,RUN,1);
- return ;
- //提醒設置防盜 for remind to shutdown
- //if(PreState==RUN)
- //remind_shutdown();
- if(PreState==RUN)
- Flag.FromRemindShutDown=remind_shutdown();
- //路邊停車
- roadside_stop();
- //for auto restore
- if(!InState.Shake)
- AutoRestore.Flag.Shaked=1;
- if(AlarmNoub>3) AlarmNoub=3;
- if(AlarmNoub>0)
- AlarmNoub=0;
- Flag.RememTouch=1;
- alarm_led_long_light(0,0);
- AutoRestore.Flag.Opened=1;
- AlarmGrade=Guard;
- if((!AutoRestore.Flag.Shaked)&&(!AutoRestore.Flag.Opened))
- if(PreState==GUARD_QUIET||PreState==GUARD_SOUND)
- if(AutoRestore.Time.Interval++>=AUTO_RESTORE_TIME)
- system_state_change(State,PreState,1);
- else AutoRestore.Time.Interval=0;
- //記憶觸發
- if(Flag.RememTouch)
- speak_act_precoss(50/TIME_BASE,950/TIME_BASE,1,SHORT);
- if(alarm_led_long_light(6,1))
- SIGNAL_LED=0;
- AlarmNoub=0;
- void guard_process(uchar Mode)
- if(GuardQuiet5s.Interval++>=5000/TIME_BASE)
- GuardQuiet5s.enable=0;
- GuardQuiet5s.Interval=0;
- Flag.BeginGuard=1;
- if(Flag.BeginGuard)
- if(Flag.DoorOpenedGuard)
- door_opened_guard();
- else
- if(AlarmSharkTimer.Interval==0)
- SharkFlag.Time=1;
- AlarmSharkTimer.enable=1;
- else if(AlarmSharkTimer.Interval<15000/TIME_BASE)
- SharkFlag.Time=2;
- else
- SharkFlag.Time=1;
- AlarmSharkTimer.Interval=0;
- if(Mode==QUIET_MODE)
- system_state_change(State,ALARM_QUIET,1);
- else if(Mode==SOUND_MODE)
- system_state_change(State,ALARM_SOUND,1);
- if(InState.SideDoor==DOOR_OPENED||InState.Acc||InState.Brake)
- system_state_change(State,ALARM_DOOR_OPENED,1);
- void guard_quiet_process(void)
- // 5s later into the guard mode
- signal_led_alarm(AlarmGrade);
- if(!Flag.GuardEngineOFF)
- if(PreState!=FIND)
- Flag.GuardEngineOFF=1;
- if(frameout_precoss(40))
- else Flag.GuardEngineOFF=1;
- if(!Flag.FromRemindShutDown)
- door_lock_process(500/TIME_BASE/5,LOCK_ON);
- if(flash_trun_signal(500/TIME_BASE,200/TIME_BASE,1))
- else Flag.SystemStateChange=0;
- Flag.BeginGuard=0;
- /////////////////////////////////當進入防盜系統的時候 如果門未關好 提醒用戶關門////////////////
- if(SystemGuardChangeFirstTime)
- Flag.DoorOpenedGuard=1;
- OpenStep=OPEN_REMIND;
- else
- SystemGuardChangeFirstTime=0;
- AlarmSharkTimer.enable=0;
- else
- guard_process(QUIET_MODE);
- case KEY_LOCK:
- break;
- case KEY_UNLOCK:
- ALARM_LED=0;
- system_state_change(State,NORMAL,1);
- break;
- case KEY_FIND:
- break;
- case KEY_QUIET:
- Flag.GuardEngineOFF=0;
- frameout_precoss(0);
- break;
- #ifdef BOOT_EN
- case KEY_BOOT:
- Flag.Boot=1;
- open_boot(0);
- break;
- #endif
- default:break;
- void guard_sound_process(void)
- //flash_alarm_led(4,2);
- speak_act_precoss(50/TIME_BASE,200/TIME_BASE,1,SHORT);
- GuardQuiet5s.enable=1;
- else Flag.DoorOpenedGuard=0;
- else
- guard_process(SOUND_MODE);
- case KEY_LOCK:
- break;
- case KEY_UNLOCK:
- ALARM_LED=0;
- break;
- case KEY_FIND:
- break;
- case KEY_QUIET:
- break;
- default:break;
- void find_process(void)
- flash_trun_signal(500/TIME_BASE,500/TIME_BASE,5);
- if(speak_act_precoss(0,0,5000/TIME_BASE/5,LONG))
- system_state_change(State,PreState,0);
- case KEY_LOCK:
- break;
- case KEY_UNLOCK:
- break;
- case KEY_FIND:
- break;
- case KEY_QUIET:
- default:break;
- typedef struct
- unsigned char Lock:1;
- unsigned char Unlock:1;
- unsigned char Help:1;
- unsigned char Call:1;
- unsigned char DoorOpened:1;
- unsigned char State:2;
- }RunStruct;
- void run_process(void)
- static bank1 RunStruct Run=0;
- ///////////15s后自動鎖門////////
- static Timer16Struct AutoLock=0;
- AlarmNoub=0;
- Run.State=0;
- AutoLock.Interval=0;
- Run.DoorOpened=0;
- switch(Run.State)
- case 0:
- if(InState.SideDoor)
- Run.DoorOpened=1;
- if(!InState.SideDoor&&Run.DoorOpened)
- Run.State=0;
- Run.DoorOpened=0;
- if(++AutoLock.Interval>=15000/TIME_BASE)
- Run.State=1;
- break;
- case 1:
- if(InState.Brake)
- Run.Lock=1;
- Run.State=2;
- break;
- case 2:
- Run.DoorOpened=1;
- Run.State=0;
- Run.DoorOpened=0;
- break;
- default:
- Run.State=2;
- break;
- case KEY_LOCK:
- Run.Unlock=0;
- Run.Lock=1;
- door_lock_process(0,0);
- break;
- case KEY_UNLOCK:
- Run.Lock=0;
- Run.Unlock=1;
- break;
- case KEY_FIND:
- if(RemoteKey.Time.Interval>=1500/TIME_BASE)
- system_state_change(State,ALARM_HELP,1);
- break;
- case KEY_QUIET:
- Energency=PRESS_FIND;
- system_state_change(State,ALARM_ENERGENCY,1);
- break;
- default:break;
- roadside_stop();
- if(!InState.Acc)
- //PreState=State;
- //State=NORMAL;
- if(Run.Unlock)
- Run.Unlock=0;
- else if(Run.Lock)
- if(door_lock_process(500/TIME_BASE/5,LOCK_ON))
- Run.Lock=0;
- void alarm_down_opened_process(void)
- //alarm_led_long_light(4,4);
- if(AlarmNoub++>=3) AlarmNoub=3;
- if(AlarmGrade<=Opened)
- AlarmGrade=Opened;
- frameout_precoss(60);
- flash_trun_signal(500/TIME_BASE,500/TIME_BASE,26);
- if(speak_act_precoss(0,0,26000/TIME_BASE/5,LONG))
- case KEY_LOCK:
- break;
- case KEY_UNLOCK:
- system_state_change(PreState,NORMAL,1);
- break;
- case KEY_FIND:
- break;
- case KEY_QUIET:
- default:break;
- void shark_alarm(uchar Mode)
- if(AlarmGrade<=Shaked)
- AlarmGrade=Shaked;
- if(SharkFlag.Time==1)
- //if(frameout_precoss(60));
- if(Mode==SOUND_MODE)
- if(speak_act_precoss(50/TIME_BASE,950/TIME_BASE,5,SHORT));
- if(flash_trun_signal(500/TIME_BASE,500/TIME_BASE,5))
- else if(SharkFlag.Time==2)
- if(frameout_precoss(61));
- if(speak_act_precoss(0,0,27000/TIME_BASE/5,LONG));
- if(flash_trun_signal(500/TIME_BASE,500/TIME_BASE,26))
- system_state_change(PreState,ALARM_DOOR_OPENED,1);
- void alarm_quiet_process(void)
- //if(Flag.SystemStateChange)
- //Flag.SystemStateChange=0;
- //if(AlarmNoub++>=3) AlarmNoub=3;
- //if(AlarmGrade<=Shaked)
- //AlarmGrade=Shaked;
- shark_alarm(QUIET_MODE);
- case KEY_LOCK:
- break;
- case KEY_UNLOCK:
- break;
- case KEY_FIND:
- break;
- case KEY_QUIET:
- default:break;
- void alarm_sound_process(void)
- //signal_led_alarm(AlarmGrade);
- shark_alarm(SOUND_MODE);
- //if(InState.SideDoor==DOOR_OPENED)
- //if(InState.SideDoor==DOOR_OPENED||InState.Acc||InState.Brake)
- //system_state_change(PreState,ALARM_DOOR_OPENED,1);
- case KEY_LOCK:
- break;
- case KEY_UNLOCK:
- break;
- case KEY_FIND:
- break;
- case KEY_QUIET:
- default:break;
- void alarm_energency(void)
- static Timer16Struct Timer8S=0;
- switch(Energency)
- case PRESS_FIND:
- if(flash_trun_signal(4000/TIME_BASE,0,1))
- case KEY_LOCK:
- break;
- case KEY_UNLOCK:
- break;
- case KEY_FIND:
- if(RemoteKey.Time.Interval>=600/TIME_BASE)
- Energency=TRUN_FLASH;
- if(speak_act_precoss(0,0,0,RESET));
- break;
- case KEY_QUIET:
- default:break;
- break;
- case TRUN_FLASH:
- if(flash_trun_signal(500/TIME_BASE,500/TIME_BASE,33));
- if(speak_act_precoss(0,0,33000/TIME_BASE/5,LONG))
- Energency=DELAY_8S;
- Timer8S.Interval=0;
- case KEY_UNLOCK:
- break;
- default:break;
- break;
- case DELAY_8S:
- if(++Timer8S.Interval>=8000/TIME_BASE)
- case KEY_UNLOCK:
- break;
- default:break;
EV1527編碼解碼.rar
(1.37 MB, 下載次數: 602)
2019-2-22 12:26 上傳
下載積分: 黑幣 -5
