查看: 5427|回復: 2
求高手畫程序流程圖
ID:39694 發表于 2012-5-4 15:44 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include <intrins.h>
#define WRITE_SECOND       0x80
#define WRITE_MINUTE       0x82
#define WRITE_HOUR         0x84
#define READ_SECOND        0x81
#define READ_MINUTE        0x83
#define READ_HOUR          0x85
#define WRITE_PROTECT      0x8E
#define READ_YEAR          0x8D
#define READ_MONTH         0x89
#define READ_SUN           0x87
#define WRITE_YEAR         0x8C
#define WRITE_MONTH        0x88
#define WRITE_SUN          0x86
sbit DQ=P3^0;           //定義接口
sbit CE=P3^1;
sbit SCLK=P3^2;
sbit DIO=P3^3;
sbit ACC_7=ACC^7;
uchar code shuzi[10][16]={
{0x00,0x00,0x00,0x1C,0x36,0x63,0x63,0x63,0x63,0x63,0x63,0x63,0x36,0x1C,0x00,0x00},/*"0",0*/
{0x00,0x00,0x00,0x0C,0x0F,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x3F,0x00,0x00},/*"1",1*/
{0x00,0x00,0x00,0x3E,0x63,0x63,0x63,0x30,0x30,0x18,0x0C,0x06,0x63,0x7F,0x00,0x00},/*"2",2*/
{0x00,0x00,0x00,0x3E,0x63,0x63,0x30,0x1C,0x30,0x60,0x60,0x63,0x33,0x1E,0x00,0x00},/*"3",3*/
{0x00,0x00,0x00,0x30,0x38,0x3C,0x36,0x36,0x33,0x33,0x7F,0x30,0x30,0x7C,0x00,0x00},/*"4",4*/
{0x00,0x00,0x00,0x7F,0x03,0x03,0x03,0x1F,0x37,0x60,0x60,0x63,0x33,0x1E,0x00,0x00},/*"5",5*/
{0x00,0x00,0x00,0x3C,0x36,0x03,0x03,0x1F,0x37,0x63,0x63,0x63,0x36,0x1C,0x00,0x00},/*"6",6*/
{0x00,0x00,0x00,0x7F,0x33,0x33,0x18,0x18,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x00,0x00},/*"7",7*/
{0x00,0x00,0x00,0x3E,0x63,0x63,0x63,0x36,0x1C,0x36,0x63,0x63,0x63,0x3E,0x00,0x00},/*"8",8*/
{0x00,0x00,0x00,0x1C,0x36,0x63,0x63,0x63,0x76,0x7C,0x60,0x60,0x36,0x1E,0x00,0x00},/*"9",9*/
uchar code wenzi1[8][16]={
{0x18,0xF8,0x8C,0x8C,0x86,0xFB,0x99,0x98,0x98,0x98,0xFF,0x80,0x80,0x80,0x80,0x80},
{0xF0,0x30,0x30,0x30,0xF0,0x30,0x30,0x30,0xF0,0x30,0x18,0x18,0x0C,0x06,0x03,0x00},
{0x00,0xFC,0x0C,0x0C,0x0C,0x0C,0xFC,0x0C,0x0C,0x0C,0x0C,0x0C,0xFC,0x0C,0x00,0x00},
{0x00,0x00,0x3F,0x33,0xF3,0x33,0x3F,0xF3,0xB3,0xB3,0x3F,0x00,0x00,0x00,0x00,0x00},
{0x98,0xB8,0x18,0x0C,0x0C,0x06,0x03,0xFD,0x30,0x30,0x30,0x30,0x18,0x8C,0x06,0x03},
{0x38,0x0F,0x0C,0xCC,0xFF,0xCC,0x6E,0x7E,0x3F,0x3F,0x0D,0x0C,0x0C,0x0C,0xCC,0x7C},
{0xC0,0x80,0xFE,0x66,0x66,0xFE,0x66,0xE6,0x06,0xF6,0x66,0xC6,0x86,0xC3,0x73,0x1D},
{0x00,0xF8,0x18,0xD8,0x18,0x18,0xF8,0x18,0xD8,0xD8,0xD8,0xD8,0xCC,0x0C,0x06,0x03},
uchar code wenzi2[8][16]={
{0x00,0x3F,0x01,0x01,0x01,0x1F,0x01,0x01,0x01,0x01,0x7F,0x01,0x01,0x01,0x01,0x01},/*"年",0*/
{0x0F,0x0C,0x0C,0x0C,0x0F,0x0C,0x0C,0x0C,0x0F,0x0C,0x0C,0x0C,0x0C,0x0F,0x06,0x00},/*"月",1*/
{0x00,0x0F,0x0C,0x0C,0x0C,0x0C,0x0F,0x0C,0x0C,0x0C,0x0C,0x0C,0x0F,0x0C,0x00,0x00},/*"日",2*/
{0x0C,0x0C,0x0C,0x0C,0x7F,0x0C,0x0C,0x0C,0x0D,0x0D,0x0C,0x0C,0x0C,0x0C,0x0F,0x06},/*"時",3*/
{0x01,0x01,0x03,0x06,0x0E,0x1C,0x78,0x37,0x06,0x06,0x06,0x06,0x06,0x07,0x03,0x00},/*"分",4*/
{0x06,0x06,0x06,0x1E,0x37,0x66,0x66,0x06,0x66,0x66,0x30,0x18,0x0C,0x07,0x01,0x00},/*"秒",5*/
{0x00,0x01,0x7F,0x06,0x06,0x3F,0x06,0x07,0x00,0x1F,0x0C,0x06,0x03,0x0E,0x78,0x30},/*"度",6*/
{0x00,0x7F,0x63,0x6F,0x63,0x63,0x7F,0x60,0x6F,0x6C,0x6C,0x6F,0x6C,0x60,0x78,0x30},/*"周",0*/
uchar code xinq1[7][16]={
{0x00,0xF8,0x18,0x18,0x18,0x18,0xF8,0x18,0x18,0x18,0x18,0x18,0xF8,0x18,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x00,0x00,0x00},
{0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0xFC,0x00,0x00,0x00,0x00,0x00,0xFE,0x00,0x00},
{0x00,0xFE,0x66,0x66,0x66,0x66,0x66,0x66,0x36,0x36,0x1E,0x0E,0x06,0xFE,0x06,0x00},
{0x00,0xFE,0xC0,0xC0,0xC0,0xC0,0xC0,0xFC,0x60,0x60,0x60,0x60,0x60,0xFF,0x00,0x00},
{0x60,0xC0,0x80,0x80,0xFF,0x00,0x00,0x60,0xE0,0x60,0x30,0x30,0x18,0x0C,0x06,0x00},
uchar code xinq2[7][16]={
{0x00,0x1F,0x18,0x18,0x18,0x18,0x1F,0x18,0x18,0x18,0x18,0x18,0x1F,0x18,0x00,0x00},/*"日",6*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x60,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"一",0*/
{0x00,0x18,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0xFF,0x00,0x00,0x00},/*"二",1*/
{0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00},/*"三",2*/
{0x00,0x7F,0x63,0x63,0x63,0x63,0x63,0x63,0x63,0x7E,0x60,0x60,0x60,0x7F,0x60,0x00},/*"四",3*/
{0x00,0x3F,0x00,0x00,0x00,0x00,0x0C,0x1F,0x0C,0x0C,0x0C,0x0C,0x6C,0xFF,0x00,0x00},/*"五",4*/
{0x00,0x01,0x03,0x01,0xFF,0x00,0x00,0x03,0x06,0x0C,0x18,0x38,0x70,0x70,0x30,0x00},/*"六",5*/
uint temp,num;
void delay(uint t)
for(;t>0;t--);
void ys(uint z)//延時z毫秒
 uint x,y;
 for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void Init_Ds18b20(void)     //DS18B20初始化send reset and initialization command
DQ = 1;
delay(10);                     //DQ復位,不要也可行。
DQ = 0;                    //單片機拉低總線
delay(80);                //精確延時,維持至少480us
DQ = 1;                    //釋放總線,即拉高了總線
delay(20);                //此處延時有足夠,確保能讓DS18B20發出存在脈沖。
uchar Read_One_Byte()       //讀取一個字節的數據read a byte date
                            //讀數據時,數據以字節的最低有效位先從總線移出
uchar i   = 0;
uchar dat = 0;
for(i=8;i>0;i--)
   DQ = 0;                  //將總線拉低,要在1us之后釋放總線
                           //單片機要在此下降沿后的15us內讀數據才會有效。
   _nop_();                 //至少維持了1us,表示讀時序開始
   dat >>= 1;               //讓從總線上讀到的位數據,依次從高位移動到低位。
   DQ = 1;                  //釋放總線,此后DS18B20會控制總線,把數據傳輸到總線上                //延時7us,此處參照推薦的讀時序圖,盡量把控制器采樣時間放到讀時序后的15us內的最后部分
   if(DQ)                   //控制器進行采樣
    dat |= 0x80;            //若總線為1,即DQ為1,那就把dat的最高位置1;若為0,則不進行處理,保持為0
   delay(8);               //此延時不能少,確保讀時序的長度60us。
return (dat);
void Write_One_Byte(uchar dat)
uchar i = 0;
for(i=8;i>0;i--)
   DQ = 0;                        //拉低總線
   _nop_();                       //至少維持了1us,表示寫時序(包括寫0時序或寫1時序)開始
   DQ = dat&0x01;                 //從字節的最低位開始傳輸
                                 //指令dat的最低位賦予給總線,必須在拉低總線后的15us內,
                                 //因為15us后DS18B20會對總線采樣。
   delay(10);                     //必須讓寫時序持續至少60us
   DQ = 1;                        //寫完后,必須釋放總線,
   dat >>= 1;
   delay(8);
uint Get_Tmp()                   //獲取溫度get the temperature
float tt;
uchar a,b;
Init_Ds18b20();                //初始化
Write_One_Byte(0xcc);          //忽略ROM指令
Write_One_Byte(0x44);          //溫度轉換指令
Write_One_Byte(0xbe);          //讀暫存器指令
a = Read_One_Byte();           //讀取到的第一個字節為溫度LSB
b = Read_One_Byte();           //讀取到的第一個字節為溫度MSB
temp = b;                      //先把高八位有效數據賦于temp
temp <<= 8;                    //把以上8位數據從temp低八位移到高八位
temp = temp|a;                //兩字節合成一個整型變量
tt = temp*0.0625;              //得到真實十進制溫度值
                                //因為DS18B20可以精確到0.0625度
                                //所以讀回數據的最低位代表的是0.0625度
temp = tt*10+0.5;               //放大十倍
                                //這樣做的目的將小數點后第一位也轉換為可顯示數字
                                //同時進行一個四舍五入操作。
return temp;
void Write1302 (uchar addr,dat)  //地址、數據發送子程序
 uchar i,temp;
    CE=0;                             //CE 引腳為低,數據傳送 中止
    SCLK=0;                           //清零時鐘總線
    CE=1;                          //CE 引腳為高,邏輯控制有效
    for(i=8;i>0;i--)     //循環8次移位  發送地址
     SCLK=0;
        temp=addr;
        DIO=(bit)(temp&0x01);             //每次傳輸低字節
        addr>>=1;                        //右移一位
        SCLK=1;
 for(i=8;i>0;i-- )   //發送數據
     SCLK=0;
        temp=dat;
        dat>>=1;
        SCLK=1;
    CE = 0;
uchar Read1302(uchar addr) //數據讀取子程序
         uchar i,temp,dat1,dat2;
         CE=0;
         SCLK=0;
         CE = 1;
         for ( i=8; i>0; i-- )                  //循環8次移位 發送地址
           SCLK=0;
           temp=addr;
           addr>>=1;                         //右移一位
           SCLK=1;
         //讀取數據
          ACC_7=DIO;
          SCLK = 1;
         ACC>>=1;
          SCLK = 0;
          CE=0;
          dat1=ACC;
          dat2=dat1/16;                                       //數據進制轉換
          dat1=dat1%16;                                     //十六進制轉十進制
          dat1=dat1+dat2*10;
          return (dat1);
void dushij()
 uchar i,j,xin,yue,ri,m;
 uint nian;
 nian=2012;
 temp=Get_Tmp();
 ri=Read1302(READ_SUN);
 yue=Read1302(READ_MONTH);
 nian=Read1302(READ_YEAR);
 if(yue==1)
 m=13;
 if(yue==2)
 m=14;
 if(yue>2)
 m=yue;
 xin=((nian%100)+((nian%100)/4)+((nian/100)/4)-(2*(nian/100))+((26*(m+1))/10)+ri-1)%7;
 for(i=0;i<230;i++)
  for(j=0;j<3;j++)
   for(num=0;num<16;num++)
    if(num+i<16)
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=shuzi[Read1302(READ_YEAR)/10][num+i];
     P2=shuzi[Read1302(READ_YEAR)%10][num+i];
     ys(2);
    else if((num+i>=16)&(num+i<32))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=wenzi1[0][num+i-16];
     P2=wenzi2[0][num+i-16];
     ys(2);
    else if((num+i>=32)&(num+i<48))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=shuzi[Read1302(READ_MONTH)/10][num+i-32];
     P2=shuzi[Read1302(READ_MONTH)%10][num+i-32];
     ys(2);
    else if((num+i>=48)&(num+i<64))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=wenzi1[1][num+i-48];
     P2=wenzi2[1][num+i-48];
     ys(2);
    else if((num+i>=64)&(num+i<80))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=shuzi[Read1302(READ_SUN)/10][num+i-64];
     P2=shuzi[Read1302(READ_SUN)%10][num+i-64];
     ys(2);
    else if((num+i>=80)&(num+i<96))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=wenzi1[2][num+i-80];
     P2=wenzi2[2][num+i-80];
     ys(2);
    else if((num+i>=96)&(num+i<112))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=shuzi[Read1302(READ_HOUR)/10][num+i-96];
     P2=shuzi[Read1302(READ_HOUR)%10][num+i-96];
     ys(2);
    else if((num+i>=112)&(num+i<128))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=wenzi1[3][num+i-112];
     P2=wenzi2[3][num+i-112];
     ys(2);
    else  if((num+i>=128)&(num+i<144))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=shuzi[Read1302(READ_MINUTE)/10][num+i-128];
     P2=shuzi[Read1302(READ_MINUTE)%10][num+i-128];
     ys(2);
    else if((num+i>=144)&(num+i<160))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=wenzi1[4][num+i-144];
     P2=wenzi2[4][num+i-144];
     ys(2);
    else if((num+i>=160)&(num+i<176))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=wenzi1[7][num+i-160];
     P2=wenzi2[7][num+i-160];
     ys(2);
    else if((num+i>=176)&(num+i<192))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=xinq1[xin][num+i-176];
     P2=xinq2[xin][num+i-176];
     ys(2);
    else if((num+i>=192)&(num+i<208))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=shuzi[temp/100][num+i-192];
     P2=shuzi[temp%100/10][num+i-192];
     ys(2);
    else if((num+i>=208)&(num+i<224))
     P0=0X00;
     P2=0X00;
     P1=num;
     P0=wenzi1[6][num+i-208];
     P2=wenzi2[6][num+i-208];
     ys(2);
     P0=0X00;
     P2=0X00;
     P1=num;
     ys(2);
 dushij();
ID:18852 發表于 2012-5-7 14:53 | 只看該作者
畫流程圖有沒有獎金呀 ???
ID:18852 發表于 2012-5-7 14:54 | 只看該作者
畫流程圖有沒有獎金呀 ???
QQ 85385639 可以聯系我
