樓主: 直德
P1C16F73單片機spwm逆變器源程序與PCB原理圖等全套資料
PIC單片機逆變器程序,73逆變,74顯示,帶硬件和軟件設計資料
電路原理圖(附件中有清晰的大圖):
Altium Designer畫的PIC16f73逆變器硬件原理圖和PCB圖如下:(51hei附件中可下載工程文件)
  1. ; original File = C:\Users\前俊電子\Desktop\PIC16F73-2KW主板程序.txt
  2.     processor 16F73
  3.     #include <P16F73.INC>
  4.     __config _CP_ALL & _BODEN_OFF & _PWRTE_OFF & _WDT_OFF & _HS_OSC ; 0x3FAA
  5. ;   __idlocs 0xFF, 0xFF, 0xFF, 0xFF
  6. ; RAM-Variable
  7. LRAM_0x20 equ 0x20
  8. LRAM_0x22 equ 0x22
  9. LRAM_0x25 equ 0x25
  10. LRAM_0x26 equ 0x26
  11. LRAM_0x27 equ 0x27
  12. LRAM_0x29 equ 0x29
  13. LRAM_0x30 equ 0x30
  14. LRAM_0x31 equ 0x31
  15. LRAM_0x32 equ 0x32
  16. LRAM_0x33 equ 0x33
  17. LRAM_0x34 equ 0x34
  18. LRAM_0x35 equ 0x35
  19. LRAM_0x36 equ 0x36
  20. LRAM_0x37 equ 0x37
  21. LRAM_0x38 equ 0x38
  22. LRAM_0x39 equ 0x39
  23. LRAM_0x3A equ 0x3A
  24. LRAM_0x3C equ 0x3C
  25. LRAM_0x3D equ 0x3D
  26. LRAM_0x3E equ 0x3E
  27. LRAM_0x3F equ 0x3F
  28. LRAM_0x40 equ 0x40
  29. LRAM_0x41 equ 0x41
  30. LRAM_0x42 equ 0x42
  31. LRAM_0x43 equ 0x43
  32. LRAM_0x44 equ 0x44
  33. LRAM_0x45 equ 0x45
  34. LRAM_0x46 equ 0x46
  35. LRAM_0x47 equ 0x47
  36. LRAM_0x48 equ 0x48
  37. LRAM_0x49 equ 0x49
  38. LRAM_0x4A equ 0x4A
  39. LRAM_0x4B equ 0x4B
  40. LRAM_0x4C equ 0x4C
  41. LRAM_0x4D equ 0x4D
  42. LRAM_0x4E equ 0x4E
  43. LRAM_0x4F equ 0x4F
  44. LRAM_0x50 equ 0x50
  45. LRAM_0x51 equ 0x51
  46. LRAM_0x52 equ 0x52
  47. LRAM_0x53 equ 0x53
  48. LRAM_0x54 equ 0x54
  49. LRAM_0x55 equ 0x55
  50. LRAM_0x56 equ 0x56
  51. LRAM_0x57 equ 0x57
  52. LRAM_0x58 equ 0x58
  53. LRAM_0x59 equ 0x59
  54. LRAM_0x5A equ 0x5A
  55. LRAM_0x5B equ 0x5B
  56. LRAM_0x5C equ 0x5C
  57. LRAM_0x5D equ 0x5D
  58. LRAM_0x5E equ 0x5E
  59. LRAM_0x5F equ 0x5F
  60. LRAM_0x61 equ 0x61
  61. LRAM_0x62 equ 0x62
  62. LRAM_0x63 equ 0x63
  63. LRAM_0x64 equ 0x64
  64. LRAM_0x65 equ 0x65
  65. LRAM_0x66 equ 0x66
  66. LRAM_0x67 equ 0x67
  67. LRAM_0x68 equ 0x68
  68. LRAM_0x69 equ 0x69
  69. LRAM_0x6A equ 0x6A
  70. LRAM_0x6B equ 0x6B
  71. LRAM_0x6C equ 0x6C
  72. LRAM_0x6D equ 0x6D
  73. LRAM_0x6E equ 0x6E
  74. LRAM_0x71 equ 0x71
  75. LRAM_0x74 equ 0x74
  76. LRAM_0x77 equ 0x77
  77. LRAM_0x79 equ 0x79
  78. LRAM_0x7B equ 0x7B
  79. LRAM_0x7D equ 0x7D
  80. LRAM_0x7E equ 0x7E
  81. LRAM_0x7F equ 0x7F
  82. ; Program
  83.     Org 0x0000
  84. ;   Reset-Vector
  85.     CLRF PCLATH          ; !!Bank Program-Page-Select
  86.     GOTO LADR_0x0010     ; !!Bank!! 0x0010 - 0x0810
  87.     ADDLW 0xFF
  88.     ADDLW 0xFF
  89. ;   Interrupt-Vector
  90.     GOTO LADR_0x04E7     ; !!Bank!! 0x04E7 - 0x0CE7
  91.     ADDLW 0xFF
  92.     ADDLW 0xFF
  93.     ADDLW 0xFF
  94.     ADDLW 0xFF
  95.     ADDLW 0xFF
  96.     ADDLW 0xFF
  97.     ADDLW 0xFF
  98.     ADDLW 0xFF
  99.     ADDLW 0xFF
  100.     ADDLW 0xFF
  101.     ADDLW 0xFF
  102. LADR_0x0010
  103.     BCF INTCON,GIE
  104.     BCF STATUS,IRP
  105.     BCF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  106.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  107.     MOVLW 0x02
  108.     MOVWF TMR1L          ; !!Bank!! TMR1L - PCON - PMDATH - Unimplemented
  109.     MOVLW 0x8F
  110.     MOVWF TMR0           ; !!Bank!! TMR0 - OPTION_REG - TMR0 - OPTION_REG
  111.     MOVLW 0x00
  112.     MOVWF ADCON0         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  113.     MOVLW 0xFF
  114.     MOVWF PORTA          ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  115.     MOVLW 0x00
  116.     MOVWF PORTB          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  117.     MOVLW 0xF0
  118.     MOVWF PORTC          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  119.     MOVLW 0xF9
  120.     MOVWF T2CON          ; !!Bank!! T2CON - PR2 - Unimplemented - Unimplemented
  121.     BCF PIR1,1           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  122.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  123.     MOVLW 0x00
  124.     MOVWF CCP1CON        ; !!Bank!! CCP1CON - Unimplemented - Unimplemented - Unimplemented
  125.     MOVLW 0x00
  126.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  127.     MOVLW 0x00
  128.     MOVWF CCP2CON        ; !!Bank!! CCP2CON - Unimplemented - Unimplemented - Unimplemented
  129.     MOVLW 0x00
  130.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  131.     CLRF T2CON           ; !!Bank!! T2CON - PR2 - Unimplemented - Unimplemented
  132.     BSF T2CON,2          ; !!Bank!! T2CON - PR2 - Unimplemented - Unimplemented
  133.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  134.     MOVLW 0xFF
  135.     MOVWF PORTA          ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  136.     MOVLW 0xBB
  137.     MOVWF PORTB          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  138.     MOVLW 0x39
  139.     MOVWF PORTC          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  140.     MOVLW 0xFF
  141.     MOVWF LRAM_0x36
  142.     BSF PORTB,1          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  143.     BSF PORTB,6          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  144.     BSF PORTB,5          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  145.     BSF PORTB,7          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  146.     BSF PORTB,0          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  147. LADR_0x003C
  148.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  149.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  150.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  151.     BSF PORTC,7          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  152.     NOP
  153.     NOP
  154.     BTFSC PORTC,7        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  155.     GOTO LADR_0x003C     ; !!Bank!! 0x003C - 0x083C
  156.     NOP
  157.     NOP
  158.     DECFSZ LRAM_0x36,F
  159.     GOTO LADR_0x003C     ; !!Bank!! 0x003C - 0x083C
  160.     MOVLW 0xFF
  161.     MOVWF LRAM_0x36
  162. LADR_0x004A
  163.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  164.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  165.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  166.     BSF PORTC,7          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  167.     NOP
  168.     NOP
  169.     BTFSS PORTC,7        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  170.     GOTO LADR_0x004A     ; !!Bank!! 0x004A - 0x084A
  171.     NOP
  172.     NOP
  173.     DECFSZ LRAM_0x36,F
  174.     GOTO LADR_0x004A     ; !!Bank!! 0x004A - 0x084A
  175.     MOVLW 0xFF
  176.     MOVWF LRAM_0x36
  177.     CLRF LRAM_0x30
  178.     CLRF LRAM_0x31
  179.     CLRF LRAM_0x32
  180.     CLRF LRAM_0x33
  181.     CLRF LRAM_0x34
  182.     CLRF LRAM_0x36
  183.     CLRF LRAM_0x37
  184.     CLRF LRAM_0x38
  185.     CLRF LRAM_0x39
  186.     CLRF LRAM_0x3A
  187.     CLRF LRAM_0x3C
  188.     CLRF LRAM_0x3D
  189.     CLRF LRAM_0x3E
  190.     CLRF LRAM_0x3F
  191.     CLRF LRAM_0x40
  192.     CLRF LRAM_0x41
  193.     CLRF LRAM_0x42
  194.     CLRF LRAM_0x43
  195.     CLRF LRAM_0x44
  196.     CLRF LRAM_0x45
  197.     CLRF LRAM_0x46
  198.     CLRF LRAM_0x47
  199.     CLRF LRAM_0x48
  200.     CLRF LRAM_0x49
  201.     CLRF LRAM_0x4A
  202.     CLRF LRAM_0x4B
  203.     CLRF LRAM_0x4C
  204.     CLRF LRAM_0x4D
  205.     CLRF LRAM_0x4E
  206.     CLRF LRAM_0x4F
  207.     CLRF LRAM_0x50
  208.     CLRF LRAM_0x52
  209.     CLRF LRAM_0x53
  210.     CLRF LRAM_0x54
  211.     CLRF LRAM_0x55
  212.     CLRF LRAM_0x6B
  213.     CLRF LRAM_0x6C
  214.     MOVLW 0xFF
  215.     MOVWF LRAM_0x6A
  216.     MOVLW 0x50
  217.     MOVWF LRAM_0x56
  218.     MOVLW 0xFF
  219.     MOVWF LRAM_0x57
  220.     MOVLW 0xFF
  221.     MOVWF LRAM_0x58
  222.     MOVLW 0xFF
  223.     MOVWF LRAM_0x59
  224.     MOVLW 0x9D
  225.     MOVWF LRAM_0x5A
  226.     MOVLW 0x01
  227.     MOVWF LRAM_0x61
  228.     MOVLW 0x28
  229.     MOVWF LRAM_0x5B
  230.     BCF LRAM_0x63,0
  231.     BCF LRAM_0x63,1
  232.     BCF LRAM_0x63,2
  233.     MOVLW 0x00
  234.     MOVWF LRAM_0x64
  235.     MOVLW 0x40
  236.     MOVWF LRAM_0x65
  237.     MOVLW 0x28
  238.     MOVWF LRAM_0x5C
  239.     MOVLW 0x00
  240.     MOVWF LRAM_0x5D
  241. LADR_0x0098
  242.     MOVLW 0xA0
  243.     ADDWF LRAM_0x5D,W
  244.     MOVWF FSR
  245.     MOVLW 0x00
  246.     MOVWF INDF
  247.     MOVLW 0xD0
  248.     ADDWF LRAM_0x5D,W
  249.     MOVWF FSR
  250.     MOVLW 0x20
  251.     MOVWF INDF
  252.     INCF LRAM_0x5D,F
  253.     DECFSZ LRAM_0x5C,F
  254.     GOTO LADR_0x0098     ; !!Bank!! 0x0098 - 0x0898
  255.     NOP
  256.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  257.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  258.     BCF INTCON,PEIE
  259.     BCF INTCON,GIE
  260.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  261.     BCF LRAM_0x37,0
  262.     BSF LRAM_0x38,0
  263.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  264.     NOP
  265.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  266.     NOP
  267. LADR_0x00B1
  268.     NOP
  269.     BCF PORTB,1          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  270.     BSF PORTB,5          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  271.     BCF PORTC,0          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  272.     NOP
  273.     BTFSS LRAM_0x6A,6
  274.     GOTO LADR_0x00C6     ; !!Bank!! 0x00C6 - 0x08C6
  275.     NOP
  276.     BSF PORTC,6          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  277.     NOP
  278.     NOP
  279.     BTFSS PORTC,6        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  280.     GOTO LADR_0x00C1     ; !!Bank!! 0x00C1 - 0x08C1
  281.     CLRF LRAM_0x6B
  282.     BSF LRAM_0x6A,6
  283.     GOTO LADR_0x00D3     ; !!Bank!! 0x00D3 - 0x08D3
  284. LADR_0x00C1
  285.     DECFSZ LRAM_0x6B,F
  286.     GOTO LADR_0x00D3     ; !!Bank!! 0x00D3 - 0x08D3
  287.     CLRF LRAM_0x6B
  288.     BCF LRAM_0x6A,6
  289.     GOTO LADR_0x00D3     ; !!Bank!! 0x00D3 - 0x08D3
  290. LADR_0x00C6
  291.     BSF PORTC,6          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  292.     NOP
  293.     NOP
  294.     BTFSC PORTC,6        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  295.     GOTO LADR_0x00CE     ; !!Bank!! 0x00CE - 0x08CE
  296.     CLRF LRAM_0x6B
  297.     BCF LRAM_0x6A,6
  298.     GOTO LADR_0x00D3     ; !!Bank!! 0x00D3 - 0x08D3
  299. LADR_0x00CE
  300.     DECFSZ LRAM_0x6B,F
  301.     GOTO LADR_0x00D3     ; !!Bank!! 0x00D3 - 0x08D3
  302.     CLRF LRAM_0x6B
  303.     BSF LRAM_0x6A,6
  304.     GOTO LADR_0x00D3     ; !!Bank!! 0x00D3 - 0x08D3
  305. LADR_0x00D3
  306.     NOP
  307.     BTFSS LRAM_0x6A,5
  308.     GOTO LADR_0x00E6     ; !!Bank!! 0x00E6 - 0x08E6
  309.     NOP
  310.     BSF PORTC,5          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  311.     NOP
  312.     NOP
  313.     BTFSS PORTC,5        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  314.     GOTO LADR_0x00E0     ; !!Bank!! 0x00E0 - 0x08E0
  315.     CLRF LRAM_0x6C
  316.     BSF LRAM_0x6A,5
  317.     BSF PORTB,0          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  318.     GOTO LADR_0x00F5     ; !!Bank!! 0x00F5 - 0x08F5
  319. LADR_0x00E0
  320.     DECFSZ LRAM_0x6C,F
  321.     GOTO LADR_0x00F5     ; !!Bank!! 0x00F5 - 0x08F5
  322.     CLRF LRAM_0x6C
  323.     BCF LRAM_0x6A,5
  324.     BCF PORTB,0          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  325.     GOTO LADR_0x00F5     ; !!Bank!! 0x00F5 - 0x08F5
  326. LADR_0x00E6
  327.     BSF PORTC,5          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  328.     NOP
  329.     NOP
  330.     BTFSC PORTC,5        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  331.     GOTO LADR_0x00EF     ; !!Bank!! 0x00EF - 0x08EF
  332.     CLRF LRAM_0x6C
  333.     BCF LRAM_0x6A,5
  334.     BCF PORTB,0          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  335.     GOTO LADR_0x00F5     ; !!Bank!! 0x00F5 - 0x08F5
  336. LADR_0x00EF
  337.     DECFSZ LRAM_0x6C,F
  338.     GOTO LADR_0x00F5     ; !!Bank!! 0x00F5 - 0x08F5
  339.     CLRF LRAM_0x6C
  340.     BSF LRAM_0x6A,5
  341.     BSF PORTB,0          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  342.     GOTO LADR_0x00F5     ; !!Bank!! 0x00F5 - 0x08F5
  343. LADR_0x00F5
  344.     NOP
  345.     GOTO LADR_0x0109     ; !!Bank!! 0x0109 - 0x0909
  346.     NOP
  347.     DECFSZ LRAM_0x57,F
  348.     GOTO LADR_0x0109     ; !!Bank!! 0x0109 - 0x0909
  349.     MOVLW 0xFF
  350.     MOVWF LRAM_0x57
  351.     DECFSZ LRAM_0x58,F
  352.     GOTO LADR_0x0109     ; !!Bank!! 0x0109 - 0x0909
  353.     MOVLW 0xFF
  354.     MOVWF LRAM_0x58
  355.     DECFSZ LRAM_0x59,F
  356.     GOTO LADR_0x0109     ; !!Bank!! 0x0109 - 0x0909
  357.     MOVLW 0xFF
  358.     MOVWF LRAM_0x59
  359.     DECFSZ LRAM_0x5A,F
  360.     GOTO LADR_0x0109     ; !!Bank!! 0x0109 - 0x0909
  361.     MOVLW 0xFF
  362.     MOVWF LRAM_0x5A
  363.     GOTO LADR_0x0010     ; !!Bank!! 0x0010 - 0x0810
  364. LADR_0x0109
  365.     MOVLW 0xFF
  366.     MOVWF LRAM_0x54
  367.     BSF PORTC,4          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  368.     NOP
  369.     NOP
  370.     BTFSS PORTC,4        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  371.     GOTO LADR_0x0114     ; !!Bank!! 0x0114 - 0x0914
  372.     MOVLW 0xFF
  373.     MOVWF LRAM_0x53
  374.     MOVWF LRAM_0x55
  375.     GOTO LADR_0x0147     ; !!Bank!! 0x0147 - 0x0947
  376. LADR_0x0114
  377.     DECFSZ LRAM_0x53,F
  378.     GOTO LADR_0x0147     ; !!Bank!! 0x0147 - 0x0947
  379.     NOP
  380. LADR_0x0117
  381.     NOP
  382.     CLRF LRAM_0x54
  383. LADR_0x0119
  384.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  385.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  386.     BCF INTCON,PEIE
  387.     BCF INTCON,GIE
  388.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  389.     MOVLW 0x00
  390.     MOVWF T1CON          ; !!Bank!! T1CON - Unimplemented - Unimplemented - Unimplemented
  391.     MOVLW 0x00
  392.     MOVWF TMR1L          ; !!Bank!! TMR1L - PCON - PMDATH - Unimplemented
  393.     MOVLW 0x8B
  394.     MOVWF TMR1H          ; !!Bank!! TMR1H - Unimplemented - PMADRH - Unimplemented
  395.     NOP
  396.     BCF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  397.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  398.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  399.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  400.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  401.     BCF PORTB,5          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  402.     NOP
  403.     MOVLW 0x00
  404.     MOVWF CCP1CON        ; !!Bank!! CCP1CON - Unimplemented - Unimplemented - Unimplemented
  405.     MOVLW 0x00
  406.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  407.     MOVLW 0x00
  408.     MOVWF CCP2CON        ; !!Bank!! CCP2CON - Unimplemented - Unimplemented - Unimplemented
  409.     MOVLW 0x00
  410.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  411.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  412.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  413.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  414.     BSF PORTC,7          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  415.     NOP
  416.     NOP
  417.     BTFSC PORTC,7        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  418.     GOTO LADR_0x0117     ; !!Bank!! 0x0117 - 0x0917
  419.     NOP
  420.     DECFSZ LRAM_0x54,F
  421.     GOTO LADR_0x0119     ; !!Bank!! 0x0119 - 0x0919
  422. LADR_0x013F
  423.     BSF PORTC,7          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  424.     NOP
  425.     NOP
  426.     BTFSS PORTC,7        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  427.     GOTO LADR_0x013F     ; !!Bank!! 0x013F - 0x093F
  428.     NOP
  429.     NOP
  430.     GOTO LADR_0x0010     ; !!Bank!! 0x0010 - 0x0810
  431. LADR_0x0147
  432.     NOP
  433.     BSF PORTC,7          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  434.     NOP
  435.     NOP
  436.     BTFSS PORTC,7        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  437.     GOTO LADR_0x0150     ; !!Bank!! 0x0150 - 0x0950
  438.     MOVLW 0xFF
  439.     MOVWF LRAM_0x36
  440.     GOTO LADR_0x016F     ; !!Bank!! 0x016F - 0x096F
  441. LADR_0x0150
  442.     DECFSZ LRAM_0x36,F
  443.     GOTO LADR_0x016F     ; !!Bank!! 0x016F - 0x096F
  444.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  445.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  446.     BCF INTCON,PEIE
  447.     BCF INTCON,GIE
  448.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  449.     BCF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  450.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  451.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  452.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  453.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  454.     NOP
  455.     MOVLW 0x00
  456.     MOVWF CCP1CON        ; !!Bank!! CCP1CON - Unimplemented - Unimplemented - Unimplemented
  457.     MOVLW 0x00
  458.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  459.     MOVLW 0x00
  460.     MOVWF CCP2CON        ; !!Bank!! CCP2CON - Unimplemented - Unimplemented - Unimplemented
  461.     MOVLW 0x00
  462.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  463. LADR_0x0165
  464.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  465.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  466.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  467.     BSF PORTC,7          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  468.     NOP
  469.     NOP
  470.     BTFSS PORTC,7        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  471.     GOTO LADR_0x0165     ; !!Bank!! 0x0165 - 0x0965
  472.     NOP
  473.     GOTO LADR_0x0010     ; !!Bank!! 0x0010 - 0x0810
  474. LADR_0x016F
  475.     NOP
  476.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  477.     MOVLW 0xC1
  478.     MOVWF ADCON0         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  479.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  480.     BSF ADCON0,2         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  481. LADR_0x0175
  482.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  483.     BTFSC ADCON0,2       ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  484.     GOTO LADR_0x0175     ; !!Bank!! 0x0175 - 0x0975
  485.     MOVF ADRES,W         ; !!Bank!! ADRES - Unimplemented - Unimplemented - Unimplemented
  486.     ADDWF LRAM_0x30,F
  487.     MOVF STATUS,W
  488.     MOVWF LRAM_0x35
  489.     RRF LRAM_0x30,F
  490.     BTFSS LRAM_0x35,0
  491.     GOTO LADR_0x0181     ; !!Bank!! 0x0181 - 0x0981
  492.     BSF LRAM_0x30,7
  493.     GOTO LADR_0x0183     ; !!Bank!! 0x0183 - 0x0983
  494. LADR_0x0181
  495.     BCF LRAM_0x30,7
  496.     GOTO LADR_0x0183     ; !!Bank!! 0x0183 - 0x0983
  497. LADR_0x0183
  498.     NOP
  499.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  500.     MOVLW 0xC9
  501.     MOVWF ADCON0         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  502.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  503.     BSF ADCON0,2         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  504. LADR_0x0189
  505.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  506.     BTFSC ADCON0,2       ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  507.     GOTO LADR_0x0189     ; !!Bank!! 0x0189 - 0x0989
  508.     MOVF ADRES,W         ; !!Bank!! ADRES - Unimplemented - Unimplemented - Unimplemented
  509.     ADDWF LRAM_0x31,F
  510.     MOVF STATUS,W
  511.     MOVWF LRAM_0x35
  512.     RRF LRAM_0x31,F
  513.     BTFSS LRAM_0x35,0
  514.     GOTO LADR_0x0195     ; !!Bank!! 0x0195 - 0x0995
  515.     BSF LRAM_0x31,7
  516.     GOTO LADR_0x0197     ; !!Bank!! 0x0197 - 0x0997
  517. LADR_0x0195
  518.     BCF LRAM_0x31,7
  519.     GOTO LADR_0x0197     ; !!Bank!! 0x0197 - 0x0997
  520. LADR_0x0197
  521.     NOP
  522.     MOVLW 0xD1
  523.     MOVWF ADCON0         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  524.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  525.     BSF ADCON0,2         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  526. LADR_0x019C
  527.     BTFSC ADCON0,2       ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  528.     GOTO LADR_0x019C     ; !!Bank!! 0x019C - 0x099C
  529.     MOVF ADRES,W         ; !!Bank!! ADRES - Unimplemented - Unimplemented - Unimplemented
  530.     ADDWF LRAM_0x32,F
  531.     MOVF STATUS,W
  532.     MOVWF LRAM_0x35
  533.     RRF LRAM_0x32,F
  534.     BTFSS LRAM_0x35,0
  535.     GOTO LADR_0x01A7     ; !!Bank!! 0x01A7 - 0x09A7
  536.     BSF LRAM_0x32,7
  537.     GOTO LADR_0x01A9     ; !!Bank!! 0x01A9 - 0x09A9
  538. LADR_0x01A7
  539.     BCF LRAM_0x32,7
  540.     GOTO LADR_0x01A9     ; !!Bank!! 0x01A9 - 0x09A9
  541. LADR_0x01A9
  542.     NOP
  543.     MOVLW 0xD9
  544.     MOVWF ADCON0         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  545.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  546.     BSF ADCON0,2         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  547. LADR_0x01AE
  548.     BTFSC ADCON0,2       ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  549.     GOTO LADR_0x01AE     ; !!Bank!! 0x01AE - 0x09AE
  550.     MOVF ADRES,W         ; !!Bank!! ADRES - Unimplemented - Unimplemented - Unimplemented
  551.     ADDWF LRAM_0x33,F
  552.     MOVF STATUS,W
  553.     MOVWF LRAM_0x35
  554.     RRF LRAM_0x33,F
  555.     BTFSS LRAM_0x35,0
  556.     GOTO LADR_0x01B9     ; !!Bank!! 0x01B9 - 0x09B9
  557.     BSF LRAM_0x33,7
  558.     GOTO LADR_0x01BB     ; !!Bank!! 0x01BB - 0x09BB
  559. LADR_0x01B9
  560.     BCF LRAM_0x33,7
  561.     GOTO LADR_0x01BB     ; !!Bank!! 0x01BB - 0x09BB
  562. LADR_0x01BB
  563.     NOP
  564.     MOVLW 0xE1
  565.     MOVWF ADCON0         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  566.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  567.     BSF ADCON0,2         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  568. LADR_0x01C0
  569.     BTFSC ADCON0,2       ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  570.     GOTO LADR_0x01C0     ; !!Bank!! 0x01C0 - 0x09C0
  571.     MOVF ADRES,W         ; !!Bank!! ADRES - Unimplemented - Unimplemented - Unimplemented
  572.     ADDWF LRAM_0x34,F
  573.     MOVF STATUS,W
  574.     MOVWF LRAM_0x35
  575.     RRF LRAM_0x34,F
  576.     BTFSS LRAM_0x35,0
  577.     GOTO LADR_0x01CB     ; !!Bank!! 0x01CB - 0x09CB
  578.     BSF LRAM_0x34,7
  579.     GOTO LADR_0x01CD     ; !!Bank!! 0x01CD - 0x09CD
  580. LADR_0x01CB
  581.     BCF LRAM_0x34,7
  582.     GOTO LADR_0x01CD     ; !!Bank!! 0x01CD - 0x09CD
  583. LADR_0x01CD
  584.     NOP
  585.     BTFSC LRAM_0x37,0
  586.     GOTO LADR_0x01E9     ; !!Bank!! 0x01E9 - 0x09E9
  587.     NOP
  588.     BSF PORTB,6          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  589.     BCF PORTB,7          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  590.     BTFSS LRAM_0x6A,6
  591.     GOTO LADR_0x027B     ; !!Bank!! 0x027B - 0x0A7B
  592.     NOP
  593.     BTFSC LRAM_0x38,0
  594.     GOTO LADR_0x0247     ; !!Bank!! 0x0247 - 0x0A47
  595.     NOP
  596.     MOVLW 0x46
  597.     SUBWF LRAM_0x30,W
  598.     BTFSS STATUS,C
  599.     GOTO LADR_0x01E0     ; !!Bank!! 0x01E0 - 0x09E0
  600.     MOVLW 0xFF
  601.     MOVWF LRAM_0x49
  602.     GOTO LADR_0x01E4     ; !!Bank!! 0x01E4 - 0x09E4
  603. LADR_0x01E0
  604.     DECFSZ LRAM_0x49,F
  605.     GOTO LADR_0x01E4     ; !!Bank!! 0x01E4 - 0x09E4
  606.     NOP
  607.     GOTO LADR_0x027B     ; !!Bank!! 0x027B - 0x0A7B
  608. LADR_0x01E4
  609.     NOP
  610.     BTFSC LRAM_0x38,1
  611.     GOTO LADR_0x02B8     ; !!Bank!! 0x02B8 - 0x0AB8
  612.     NOP
  613.     GOTO LADR_0x036A     ; !!Bank!! 0x036A - 0x0B6A
  614. LADR_0x01E9
  615.     BSF PORTB,7          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  616.     BTFSS LRAM_0x6A,6
  617.     GOTO LADR_0x01FE     ; !!Bank!! 0x01FE - 0x09FE
  618.     MOVLW 0x4E
  619.     SUBWF LRAM_0x30,W
  620.     BTFSS STATUS,C
  621.     GOTO LADR_0x01FE     ; !!Bank!! 0x01FE - 0x09FE
  622.     NOP
  623.     DECFSZ LRAM_0x49,F
  624.     GOTO LADR_0x0202     ; !!Bank!! 0x0202 - 0x0A02
  625.     MOVLW 0xFF
  626.     MOVWF LRAM_0x49
  627.     DECFSZ LRAM_0x4C,F
  628.     GOTO LADR_0x0202     ; !!Bank!! 0x0202 - 0x0A02
  629.     NOP
  630.     MOVLW 0xFF
  631.     MOVWF LRAM_0x6D
  632.     MOVLW 0x60
  633.     MOVWF LRAM_0x6E
  634.     NOP
  635.     GOTO LADR_0x0208     ; !!Bank!! 0x0208 - 0x0A08
  636. LADR_0x01FE
  637.     MOVLW 0xFF
  638.     MOVWF LRAM_0x49
  639.     MOVLW 0x80
  640.     MOVWF LRAM_0x4C
  641. LADR_0x0202
  642.     NOP
  643.     BTFSC LRAM_0x3A,0
  644.     GOTO LADR_0x03BC     ; !!Bank!! 0x03BC - 0x0BBC
  645.     NOP
  646.     GOTO LADR_0x04B4     ; !!Bank!! 0x04B4 - 0x0CB4
  647.     NOP
  648. LADR_0x0208
  649.     NOP
  650.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  651.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  652.     BCF INTCON,PEIE
  653.     BCF INTCON,GIE
  654.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  655.     BSF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  656.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  657.     MOVLW 0x00
  658.     MOVWF CCP1CON        ; !!Bank!! CCP1CON - Unimplemented - Unimplemented - Unimplemented
  659.     MOVLW 0x00
  660.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  661.     MOVLW 0x00
  662.     MOVWF CCP2CON        ; !!Bank!! CCP2CON - Unimplemented - Unimplemented - Unimplemented
  663.     MOVLW 0x00
  664.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  665.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  666.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  667.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  668.     BCF LRAM_0x37,0
  669.     BSF LRAM_0x38,0
  670.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  671.     NOP
  672.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  673.     NOP
  674.     DECFSZ LRAM_0x6D,F
  675.     GOTO LADR_0x0208     ; !!Bank!! 0x0208 - 0x0A08
  676.     NOP
  677.     MOVLW 0xFF
  678.     MOVWF LRAM_0x6D
  679.     DECFSZ LRAM_0x6E,F
  680.     GOTO LADR_0x0208     ; !!Bank!! 0x0208 - 0x0A08
  681.     MOVLW 0xFF
  682.     MOVWF LRAM_0x6D
  683.     MOVLW 0xFF
  684.     MOVWF LRAM_0x6E
  685. LADR_0x022C
  686.     BCF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  687.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  688.     MOVLW 0x00
  689.     MOVWF CCP1CON        ; !!Bank!! CCP1CON - Unimplemented - Unimplemented - Unimplemented
  690.     MOVLW 0x00
  691.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  692.     MOVLW 0x00
  693.     MOVWF CCP2CON        ; !!Bank!! CCP2CON - Unimplemented - Unimplemented - Unimplemented
  694.     MOVLW 0x00
  695.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  696.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  697.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  698.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  699.     NOP
  700.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  701.     NOP
  702.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  703.     NOP
  704.     DECFSZ LRAM_0x6D,F
  705.     GOTO LADR_0x022C     ; !!Bank!! 0x022C - 0x0A2C
  706.     NOP
  707.     MOVLW 0xFF
  708.     MOVWF LRAM_0x6D
  709.     DECFSZ LRAM_0x6E,F
  710.     GOTO LADR_0x022C     ; !!Bank!! 0x022C - 0x0A2C
  711.     NOP
  712.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  713. LADR_0x0247
  714.     NOP
  715.     BCF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  716.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  717.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  718.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  719.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  720.     DECFSZ LRAM_0x3E,F
  721.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  722.     MOVLW 0x46
  723.     SUBWF LRAM_0x30,W
  724.     BTFSS STATUS,C
  725.     GOTO LADR_0x027B     ; !!Bank!! 0x027B - 0x0A7B
  726.     MOVLW 0x04
  727.     MOVWF LRAM_0x3E
  728.     BCF LRAM_0x37,0
  729.     BCF LRAM_0x38,0
  730.     BSF LRAM_0x38,1
  731.     MOVLW 0x00
  732.     MOVWF LRAM_0x3C
  733.     MOVLW 0x80
  734.     MOVWF LRAM_0x3D
  735.     MOVLW 0x00
  736.     MOVWF LRAM_0x68
  737.     MOVLW 0xFF
  738.     MOVWF LRAM_0x69
  739. LADR_0x0260
  740.     BSF PORTA,4          ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  741.     NOP
  742.     BTFSC PORTA,4        ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  743.     GOTO LADR_0x0260     ; !!Bank!! 0x0260 - 0x0A60
  744.     NOP
  745. LADR_0x0265
  746.     BSF PORTA,4          ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  747.     NOP
  748.     BTFSS PORTA,4        ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  749.     GOTO LADR_0x0265     ; !!Bank!! 0x0265 - 0x0A65
  750.     NOP
  751. LADR_0x026A
  752.     BSF PORTA,4          ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  753.     NOP
  754.     BTFSC PORTA,4        ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  755.     GOTO LADR_0x026A     ; !!Bank!! 0x026A - 0x0A6A
  756.     NOP
  757. LADR_0x026F
  758.     BSF PORTA,4          ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  759.     NOP
  760.     BTFSS PORTA,4        ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  761.     GOTO LADR_0x026F     ; !!Bank!! 0x026F - 0x0A6F
  762.     NOP
  763. LADR_0x0274
  764.     BSF PORTA,4          ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  765.     NOP
  766.     BTFSC PORTA,4        ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  767.     GOTO LADR_0x0274     ; !!Bank!! 0x0274 - 0x0A74
  768.     BCF LRAM_0x39,0
  769.     BSF LRAM_0x39,1
  770.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  771. LADR_0x027B
  772.     NOP
  773.     BSF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  774.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  775.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  776.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  777.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  778.     BSF LRAM_0x37,0
  779.     BSF LRAM_0x3A,0
  780.     BSF LRAM_0x3F,1
  781.     BCF LRAM_0x3F,0
  782.     BCF LRAM_0x3F,2
  783.     MOVLW 0x01
  784.     MOVWF T1CON          ; !!Bank!! T1CON - Unimplemented - Unimplemented - Unimplemented
  785.     MOVLW 0xFE
  786.     MOVWF TMR1H          ; !!Bank!! TMR1H - Unimplemented - PMADRH - Unimplemented
  787.     MOVLW 0x0B
  788.     MOVWF TMR1L          ; !!Bank!! TMR1L - PCON - PMDATH - Unimplemented
  789.     MOVLW 0x01
  790.     MOVWF LRAM_0x61
  791.     MOVLW 0x28
  792.     MOVWF LRAM_0x5B
  793.     BCF LRAM_0x63,0
  794.     BCF LRAM_0x63,1
  795.     BCF LRAM_0x63,2
  796.     MOVLW 0x00
  797.     MOVWF LRAM_0x64
  798.     MOVLW 0x28
  799.     MOVWF LRAM_0x5C
  800.     MOVLW 0x00
  801.     MOVWF LRAM_0x5D
  802. LADR_0x0299
  803.     MOVLW 0xA0
  804.     ADDWF LRAM_0x5D,W
  805.     MOVWF FSR
  806.     MOVLW 0x00
  807.     MOVWF INDF
  808.     MOVLW 0xD0
  809.     ADDWF LRAM_0x5D,W
  810.     MOVWF FSR
  811.     MOVLW 0x20
  812.     MOVWF INDF
  813.     INCF LRAM_0x5D,F
  814.     DECFSZ LRAM_0x5C,F
  815.     GOTO LADR_0x0299     ; !!Bank!! 0x0299 - 0x0A99
  816.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  817.     NOP
  818.     MOVLW 0x3C
  819.     MOVWF CCP1CON        ; !!Bank!! CCP1CON - Unimplemented - Unimplemented - Unimplemented
  820.     MOVLW 0x00
  821.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  822.     MOVLW 0x3C
  823.     MOVWF CCP2CON        ; !!Bank!! CCP2CON - Unimplemented - Unimplemented - Unimplemented
  824.     MOVLW 0x00
  825.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  826.     NOP
  827.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  828.     BSF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  829.     BSF INTCON,PEIE
  830.     BSF INTCON,GIE
  831.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  832.     NOP
  833.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  834. LADR_0x02B8
  835.     MOVLW 0x94
  836.     SUBWF LRAM_0x32,W
  837.     BTFSS STATUS,C
  838.     GOTO LADR_0x02C8     ; !!Bank!! 0x02C8 - 0x0AC8
  839.     NOP
  840.     DECFSZ LRAM_0x4B,F
  841.     GOTO LADR_0x02CA     ; !!Bank!! 0x02CA - 0x0ACA
  842.     BCF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  843.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  844.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  845.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  846.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  847.     BCF LRAM_0x37,0
  848.     BCF LRAM_0x38,0
  849.     BCF LRAM_0x38,1
  850.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  851. LADR_0x02C8
  852.     MOVLW 0xFF
  853.     MOVWF LRAM_0x4B
  854. LADR_0x02CA
  855.     NOP
  856.     BCF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  857.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  858.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  859.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  860.     NOP
  861.     DECFSZ LRAM_0x3E,F
  862.     GOTO LADR_0x0309     ; !!Bank!! 0x0309 - 0x0B09
  863.     MOVLW 0x04
  864.     MOVWF LRAM_0x3E
  865.     MOVLW 0x99
  866.     SUBWF LRAM_0x33,W
  867.     BTFSS STATUS,C
  868.     GOTO LADR_0x02DA     ; !!Bank!! 0x02DA - 0x0ADA
  869.     NOP
  870.     GOTO LADR_0x0247     ; !!Bank!! 0x0247 - 0x0A47
  871. LADR_0x02DA
  872.     MOVLW 0x8A
  873.     SUBWF LRAM_0x32,W
  874.     BTFSS STATUS,C
  875.     GOTO LADR_0x02E0     ; !!Bank!! 0x02E0 - 0x0AE0
  876.     NOP
  877.     GOTO LADR_0x02E8     ; !!Bank!! 0x02E8 - 0x0AE8
  878. LADR_0x02E0
  879.     MOVLW 0x33
  880.     SUBWF LRAM_0x33,W
  881.     BTFSS STATUS,C
  882.     GOTO LADR_0x02E6     ; !!Bank!! 0x02E6 - 0x0AE6
  883.     NOP
  884.     GOTO LADR_0x02E8     ; !!Bank!! 0x02E8 - 0x0AE8
  885. LADR_0x02E6
  886.     NOP
  887.     GOTO LADR_0x02F9     ; !!Bank!! 0x02F9 - 0x0AF9
  888. LADR_0x02E8
  889.     MOVLW 0x01
  890.     SUBWF LRAM_0x3C,F
  891.     BTFSC STATUS,C
  892.     GOTO LADR_0x0309     ; !!Bank!! 0x0309 - 0x0B09
  893.     MOVLW 0xFF
  894.     MOVWF LRAM_0x3C
  895.     MOVLW 0x01
  896.     SUBWF LRAM_0x3D,F
  897.     MOVLW 0x8B
  898.     SUBWF LRAM_0x3D,W
  899.     BTFSC STATUS,C
  900.     GOTO LADR_0x0309     ; !!Bank!! 0x0309 - 0x0B09
  901.     MOVLW 0x00
  902.     MOVWF LRAM_0x3C
  903.     MOVLW 0x8B
  904.     MOVWF LRAM_0x3D
  905.     GOTO LADR_0x0309     ; !!Bank!! 0x0309 - 0x0B09
  906. LADR_0x02F9
  907.     MOVLW 0x01
  908.     ADDWF LRAM_0x3C,F
  909.     BTFSS STATUS,C
  910.     GOTO LADR_0x0309     ; !!Bank!! 0x0309 - 0x0B09
  911.     MOVLW 0x01
  912.     ADDWF LRAM_0x3D,F
  913.     MOVLW 0xC5
  914.     SUBWF LRAM_0x3D,W
  915.     BTFSS STATUS,C
  916.     GOTO LADR_0x0309     ; !!Bank!! 0x0309 - 0x0B09
  917.     NOP
  918.     MOVLW 0xFF
  919.     MOVWF LRAM_0x3C
  920.     MOVLW 0xC4
  921.     MOVWF LRAM_0x3D
  922.     GOTO LADR_0x0309     ; !!Bank!! 0x0309 - 0x0B09
  923. LADR_0x0309
  924.     BTFSS LRAM_0x39,0
  925.     GOTO LADR_0x033B     ; !!Bank!! 0x033B - 0x0B3B
  926.     NOP
  927.     NOP
  928.     BTFSC LRAM_0x39,1
  929.     GOTO LADR_0x0327     ; !!Bank!! 0x0327 - 0x0B27
  930.     NOP
  931.     BTFSS LRAM_0x68,5
  932.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  933.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  934.     NOP
  935.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  936.     NOP
  937.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  938.     NOP
  939.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  940.     NOP
  941.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  942.     NOP
  943.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  944.     NOP
  945.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  946.     NOP
  947.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  948.     NOP
  949.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  950.     BCF LRAM_0x68,5
  951.     BSF LRAM_0x39,0
  952.     BSF LRAM_0x39,1
  953.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  954. LADR_0x0327
  955.     BSF PORTA,4          ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  956.     NOP
  957.     NOP
  958.     BTFSC PORTA,4        ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  959.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  960.     MOVLW 0x01
  961.     MOVWF T1CON          ; !!Bank!! T1CON - Unimplemented - Unimplemented - Unimplemented
  962.     MOVF LRAM_0x3D,W
  963.     MOVWF TMR1H          ; !!Bank!! TMR1H - Unimplemented - PMADRH - Unimplemented
  964.     MOVF LRAM_0x3C,W
  965.     MOVWF TMR1L          ; !!Bank!! TMR1L - PCON - PMDATH - Unimplemented
  966.     NOP
  967.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  968.     BSF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  969.     BSF INTCON,PEIE
  970.     BSF INTCON,GIE
  971.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  972.     BCF LRAM_0x39,0
  973.     BCF LRAM_0x39,1
  974.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  975. LADR_0x033B
  976.     NOP
  977.     BTFSC LRAM_0x39,1
  978.     GOTO LADR_0x0356     ; !!Bank!! 0x0356 - 0x0B56
  979.     NOP
  980.     BTFSS LRAM_0x68,5
  981.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  982.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  983.     NOP
  984.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  985.     NOP
  986.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  987.     NOP
  988.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  989.     NOP
  990.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  991.     NOP
  992.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  993.     NOP
  994.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  995.     NOP
  996.     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  997.     NOP
  998.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  999.     BCF LRAM_0x68,5
  1000.     BCF LRAM_0x39,0
  1001.     BSF LRAM_0x39,1
  1002.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  1003. LADR_0x0356
  1004.     BSF PORTA,4          ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  1005.     NOP
  1006.     NOP
  1007.     BTFSS PORTA,4        ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  1008.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  1009.     MOVLW 0x01
  1010.     MOVWF T1CON          ; !!Bank!! T1CON - Unimplemented - Unimplemented - Unimplemented
  1011.     MOVF LRAM_0x3D,W
  1012.     MOVWF TMR1H          ; !!Bank!! TMR1H - Unimplemented - PMADRH - Unimplemented
  1013.     MOVF LRAM_0x3C,W
  1014.     MOVWF TMR1L          ; !!Bank!! TMR1L - PCON - PMDATH - Unimplemented
  1015.     NOP
  1016.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1017.     BSF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1018.     BSF INTCON,PEIE
  1019.     BSF INTCON,GIE
  1020.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1021.     BSF LRAM_0x39,0
  1022.     BCF LRAM_0x39,1
  1023.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  1024. LADR_0x036A
  1025.     MOVLW 0x9E
  1026.     SUBWF LRAM_0x32,W
  1027.     BTFSS STATUS,C
  1028.     GOTO LADR_0x0394     ; !!Bank!! 0x0394 - 0x0B94
  1029.     NOP
  1030.     DECFSZ LRAM_0x4D,F
  1031.     GOTO LADR_0x0396     ; !!Bank!! 0x0396 - 0x0B96
  1032.     NOP
  1033. LADR_0x0372
  1034.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1035.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1036.     BCF INTCON,PEIE
  1037.     BCF INTCON,GIE
  1038.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1039.     MOVLW 0x00
  1040.     MOVWF T1CON          ; !!Bank!! T1CON - Unimplemented - Unimplemented - Unimplemented
  1041.     MOVLW 0x00
  1042.     MOVWF TMR1L          ; !!Bank!! TMR1L - PCON - PMDATH - Unimplemented
  1043.     MOVLW 0x8B
  1044.     MOVWF TMR1H          ; !!Bank!! TMR1H - Unimplemented - PMADRH - Unimplemented
  1045.     BSF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1046.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1047.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1048.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1049.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1050.     NOP
  1051.     BSF PORTC,7          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1052.     NOP
  1053.     NOP
  1054.     BTFSS PORTC,7        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1055.     GOTO LADR_0x038B     ; !!Bank!! 0x038B - 0x0B8B
  1056.     MOVLW 0xFF
  1057.     MOVWF LRAM_0x36
  1058.     GOTO LADR_0x0372     ; !!Bank!! 0x0372 - 0x0B72
  1059. LADR_0x038B
  1060.     DECFSZ LRAM_0x36,F
  1061.     GOTO LADR_0x0372     ; !!Bank!! 0x0372 - 0x0B72
  1062. LADR_0x038D
  1063.     BSF PORTC,7          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1064.     NOP
  1065.     NOP
  1066.     BTFSS PORTC,7        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1067.     GOTO LADR_0x038D     ; !!Bank!! 0x038D - 0x0B8D
  1068.     NOP
  1069.     GOTO LADR_0x0010     ; !!Bank!! 0x0010 - 0x0810
  1070. LADR_0x0394
  1071.     MOVLW 0xFF
  1072.     MOVWF LRAM_0x4D
  1073. LADR_0x0396
  1074.     MOVLW 0x80
  1075.     SUBWF LRAM_0x32,W
  1076.     BTFSC STATUS,C
  1077.     GOTO LADR_0x03A0     ; !!Bank!! 0x03A0 - 0x0BA0
  1078.     NOP
  1079.     DECFSZ LRAM_0x4B,F
  1080.     GOTO LADR_0x03A2     ; !!Bank!! 0x03A2 - 0x0BA2
  1081.     BCF LRAM_0x37,0
  1082.     BSF LRAM_0x38,0
  1083.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  1084. LADR_0x03A0
  1085.     MOVLW 0xFF
  1086.     MOVWF LRAM_0x4B
  1087. LADR_0x03A2
  1088.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1089.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1090.     BCF INTCON,PEIE
  1091.     BCF INTCON,GIE
  1092.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1093.     MOVLW 0x00
  1094.     MOVWF T1CON          ; !!Bank!! T1CON - Unimplemented - Unimplemented - Unimplemented
  1095.     MOVLW 0x00
  1096.     MOVWF TMR1L          ; !!Bank!! TMR1L - PCON - PMDATH - Unimplemented
  1097.     MOVLW 0x8B
  1098.     MOVWF TMR1H          ; !!Bank!! TMR1H - Unimplemented - PMADRH - Unimplemented
  1099.     NOP
  1100.     BCF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1101.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1102.     MOVLW 0x00
  1103.     MOVWF CCP1CON        ; !!Bank!! CCP1CON - Unimplemented - Unimplemented - Unimplemented
  1104.     MOVLW 0x00
  1105.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  1106.     MOVLW 0x00
  1107.     MOVWF CCP2CON        ; !!Bank!! CCP2CON - Unimplemented - Unimplemented - Unimplemented
  1108.     MOVLW 0x00
  1109.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  1110.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1111.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1112.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1113.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  1114. LADR_0x03BC
  1115.     BSF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1116.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1117.     NOP
  1118.     MOVLW 0xCC
  1119.     SUBWF LRAM_0x34,W
  1120.     BTFSS STATUS,C
  1121.     GOTO LADR_0x03DE     ; !!Bank!! 0x03DE - 0x0BDE
  1122. LADR_0x03C3
  1123.     NOP
  1124.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1125.     MOVLW 0x00
  1126.     MOVWF CCP1CON        ; !!Bank!! CCP1CON - Unimplemented - Unimplemented - Unimplemented
  1127.     MOVLW 0x00
  1128.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  1129.     MOVLW 0x00
  1130.     MOVWF CCP2CON        ; !!Bank!! CCP2CON - Unimplemented - Unimplemented - Unimplemented
  1131.     MOVLW 0x00
  1132.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  1133.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1134.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1135.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1136.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1137.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1138.     BCF INTCON,PEIE
  1139.     BCF INTCON,GIE
  1140.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1141.     BSF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1142.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1143.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1144.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1145.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1146.     BSF LRAM_0x3A,7
  1147.     BSF LRAM_0x37,0
  1148.     BCF LRAM_0x3A,0
  1149.     GOTO LADR_0x04B4     ; !!Bank!! 0x04B4 - 0x0CB4
  1150. LADR_0x03DE
  1151.     MOVLW 0x66
  1152.     SUBWF LRAM_0x34,W
  1153.     BTFSS STATUS,C
  1154.     GOTO LADR_0x03EE     ; !!Bank!! 0x03EE - 0x0BEE
  1155.     NOP
  1156.     DECFSZ LRAM_0x4F,F
  1157.     GOTO LADR_0x03F2     ; !!Bank!! 0x03F2 - 0x0BF2
  1158.     MOVLW 0xFF
  1159.     MOVWF LRAM_0x4F
  1160.     DECFSZ LRAM_0x50,F
  1161.     GOTO LADR_0x03F2     ; !!Bank!! 0x03F2 - 0x0BF2
  1162.     NOP
  1163.     BSF LRAM_0x3A,7
  1164.     BSF LRAM_0x37,0
  1165.     BCF LRAM_0x3A,0
  1166.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  1167. LADR_0x03EE
  1168.     MOVLW 0xFF
  1169.     MOVWF LRAM_0x4F
  1170.     MOVLW 0x64
  1171.     MOVWF LRAM_0x50
  1172. LADR_0x03F2
  1173.     BSF PORTB,6          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1174.     BTFSS LRAM_0x6A,5
  1175.     GOTO LADR_0x0401     ; !!Bank!! 0x0401 - 0x0C01
  1176.     MOVLW 0x62
  1177.     SUBWF LRAM_0x32,W
  1178.     BTFSC STATUS,C
  1179.     GOTO LADR_0x0401     ; !!Bank!! 0x0401 - 0x0C01
  1180.     NOP
  1181.     DECFSZ LRAM_0x4A,F
  1182.     GOTO LADR_0x0403     ; !!Bank!! 0x0403 - 0x0C03
  1183.     NOP
  1184.     BCF LRAM_0x3A,7
  1185.     BSF LRAM_0x37,0
  1186.     BCF LRAM_0x3A,0
  1187.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  1188. LADR_0x0401
  1189.     MOVLW 0xFF
  1190.     MOVWF LRAM_0x4A
  1191. LADR_0x0403
  1192.     BTFSS LRAM_0x63,0
  1193.     GOTO LADR_0x00B1     ; !!Bank!! 0x00B1 - 0x08B1
  1194.     NOP
  1195.     BCF LRAM_0x63,0
  1196.     DECFSZ LRAM_0x65,F
  1197.     GOTO LADR_0x00B1     ; !!Bank!! 0x00B1 - 0x08B1
  1198.     MOVLW 0xA0
  1199.     MOVWF LRAM_0x56
  1200.     GOTO LADR_0x0410     ; !!Bank!! 0x0410 - 0x0C10
  1201.     DECFSZ LRAM_0x56,F
  1202.     GOTO LADR_0x0410     ; !!Bank!! 0x0410 - 0x0C10
  1203.     NOP
  1204.     GOTO LADR_0x03C3     ; !!Bank!! 0x03C3 - 0x0BC3
  1205. LADR_0x0410
  1206.     MOVLW 0x02
  1207.     MOVWF LRAM_0x65
  1208.     MOVLW 0xD0
  1209.     SUBWF LRAM_0x31,W
  1210.     BTFSC STATUS,C
  1211.     GOTO LADR_0x0430     ; !!Bank!! 0x0430 - 0x0C30
  1212.     MOVLW 0xC0
  1213.     SUBWF LRAM_0x31,W
  1214.     BTFSS STATUS,C
  1215.     GOTO LADR_0x0472     ; !!Bank!! 0x0472 - 0x0C72
  1216.     MOVLW 0xC8
  1217.     SUBWF LRAM_0x31,W
  1218.     BTFSS STATUS,C
  1219.     GOTO LADR_0x0427     ; !!Bank!! 0x0427 - 0x0C27
  1220.     NOP
  1221.     MOVLW 0x10
  1222.     MOVWF LRAM_0x66
  1223.     DECFSZ LRAM_0x67,F
  1224.     GOTO LADR_0x00B1     ; !!Bank!! 0x00B1 - 0x08B1
  1225.     MOVLW 0x10
  1226.     MOVWF LRAM_0x67
  1227.     MOVWF LRAM_0x66
  1228.     GOTO LADR_0x0430     ; !!Bank!! 0x0430 - 0x0C30
  1229. LADR_0x0427
  1230.     NOP
  1231.     MOVLW 0x10
  1232.     MOVWF LRAM_0x67
  1233.     DECFSZ LRAM_0x66,F
  1234.     GOTO LADR_0x00B1     ; !!Bank!! 0x00B1 - 0x08B1
  1235.     MOVLW 0x10
  1236.     MOVWF LRAM_0x66
  1237.     MOVWF LRAM_0x67
  1238.     GOTO LADR_0x0472     ; !!Bank!! 0x0472 - 0x0C72
  1239. LADR_0x0430
  1240.     MOVLW 0x10
  1241.     SUBWF LRAM_0x64,W
  1242.     BTFSS STATUS,C
  1243.     GOTO LADR_0x00B1     ; !!Bank!! 0x00B1 - 0x08B1
  1244.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1245.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1246.     BCF INTCON,PEIE
  1247.     BCF INTCON,GIE
  1248.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1249.     DECF LRAM_0x64,F
  1250.     MOVLW 0x28
  1251.     MOVWF LRAM_0x5C
  1252.     MOVLW 0x00
  1253.     MOVWF LRAM_0x5D
  1254. LADR_0x043E
  1255.     BCF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  1256.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1257.     MOVLW 0x08
  1258.     BSF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  1259.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1260.     MOVWF TMR1H          ; !!Bank!! TMR1H - Unimplemented - PMADRH - Unimplemented
  1261.     BCF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  1262.     MOVF LRAM_0x5D,W
  1263.     BSF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  1264.     MOVWF PIR2           ; !!Bank!! PIR2 - PIE2 - PMADR - Unimplemented
  1265.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1266.     BSF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1267.     NOP
  1268.     NOP
  1269.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1270.     MOVF PIR1,W          ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1271.     BCF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  1272.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1273.     MOVWF LRAM_0x5E
  1274.     BCF STATUS,IRP
  1275.     MOVLW 0xA0
  1276.     ADDWF LRAM_0x5D,W
  1277.     MOVWF FSR
  1278.     MOVF INDF,W
  1279.     MOVWF LRAM_0x5F
  1280.     MOVF LRAM_0x5E,W
  1281.     BCF STATUS,C
  1282.     SUBWF LRAM_0x5F,F
  1283.     BTFSC STATUS,C
  1284.     GOTO LADR_0x0462     ; !!Bank!! 0x0462 - 0x0C62
  1285.     BCF STATUS,IRP
  1286.     MOVLW 0xD0
  1287.     ADDWF LRAM_0x5D,W
  1288.     MOVWF FSR
  1289.     DECF INDF,F
  1290.     GOTO LADR_0x0462     ; !!Bank!! 0x0462 - 0x0C62
  1291. LADR_0x0462
  1292.     BCF STATUS,IRP
  1293.     MOVLW 0xA0
  1294.     ADDWF LRAM_0x5D,W
  1295.     MOVWF FSR
  1296.     MOVF LRAM_0x5F,W
  1297.     MOVWF INDF
  1298.     INCF LRAM_0x5D,F
  1299.     DECFSZ LRAM_0x5C,F
  1300.     GOTO LADR_0x043E     ; !!Bank!! 0x043E - 0x0C3E
  1301.     NOP
  1302.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1303.     BSF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1304.     BSF INTCON,PEIE
  1305.     BSF INTCON,GIE
  1306.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1307.     GOTO LADR_0x00B1     ; !!Bank!! 0x00B1 - 0x08B1
  1308. LADR_0x0472
  1309.     MOVLW 0xD0
  1310.     SUBWF LRAM_0x64,W
  1311.     BTFSC STATUS,C
  1312.     GOTO LADR_0x00B1     ; !!Bank!! 0x00B1 - 0x08B1
  1313.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1314.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1315.     BCF INTCON,PEIE
  1316.     BCF INTCON,GIE
  1317.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1318.     INCF LRAM_0x64,F
  1319.     MOVLW 0x28
  1320.     MOVWF LRAM_0x5C
  1321.     MOVLW 0x00
  1322.     MOVWF LRAM_0x5D
  1323. LADR_0x0480
  1324.     BCF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  1325.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1326.     MOVLW 0x08
  1327.     BSF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  1328.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1329.     MOVWF TMR1H          ; !!Bank!! TMR1H - Unimplemented - PMADRH - Unimplemented
  1330.     BCF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  1331.     MOVF LRAM_0x5D,W
  1332.     BSF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  1333.     MOVWF PIR2           ; !!Bank!! PIR2 - PIE2 - PMADR - Unimplemented
  1334.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1335.     BSF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1336.     NOP
  1337.     NOP
  1338.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1339.     MOVF PIR1,W          ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1340.     BCF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  1341.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1342.     MOVWF LRAM_0x5E
  1343.     BCF STATUS,IRP
  1344.     MOVLW 0xA0
  1345.     ADDWF LRAM_0x5D,W
  1346.     MOVWF FSR
  1347.     MOVF INDF,W
  1348.     MOVWF LRAM_0x5F
  1349.     MOVF LRAM_0x5E,W
  1350.     BCF STATUS,C
  1351.     ADDWF LRAM_0x5F,F
  1352.     BTFSS STATUS,C
  1353.     GOTO LADR_0x04A4     ; !!Bank!! 0x04A4 - 0x0CA4
  1354.     BCF STATUS,IRP
  1355.     MOVLW 0xD0
  1356.     ADDWF LRAM_0x5D,W
  1357.     MOVWF FSR
  1358.     INCF INDF,F
  1359.     GOTO LADR_0x04A4     ; !!Bank!! 0x04A4 - 0x0CA4
  1360. LADR_0x04A4
  1361.     BCF STATUS,IRP
  1362.     MOVLW 0xA0
  1363.     ADDWF LRAM_0x5D,W
  1364.     MOVWF FSR
  1365.     MOVF LRAM_0x5F,W
  1366.     MOVWF INDF
  1367.     INCF LRAM_0x5D,F
  1368.     DECFSZ LRAM_0x5C,F
  1369.     GOTO LADR_0x0480     ; !!Bank!! 0x0480 - 0x0C80
  1370.     NOP
  1371.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1372.     BSF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1373.     BSF INTCON,PEIE
  1374.     BSF INTCON,GIE
  1375.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1376.     GOTO LADR_0x00B1     ; !!Bank!! 0x00B1 - 0x08B1
  1377. LADR_0x04B4
  1378.     NOP
  1379.     NOP
  1380.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1381.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1382.     BCF INTCON,PEIE
  1383.     BCF INTCON,GIE
  1384.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1385.     MOVLW 0x00
  1386.     MOVWF T1CON          ; !!Bank!! T1CON - Unimplemented - Unimplemented - Unimplemented
  1387.     MOVLW 0x00
  1388.     MOVWF TMR1L          ; !!Bank!! TMR1L - PCON - PMDATH - Unimplemented
  1389.     MOVLW 0x8B
  1390.     MOVWF TMR1H          ; !!Bank!! TMR1H - Unimplemented - PMADRH - Unimplemented
  1391.     NOP
  1392.     BCF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1393.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1394.     MOVLW 0x00
  1395.     MOVWF CCP1CON        ; !!Bank!! CCP1CON - Unimplemented - Unimplemented - Unimplemented
  1396.     MOVLW 0x00
  1397.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  1398.     MOVLW 0x00
  1399.     MOVWF CCP2CON        ; !!Bank!! CCP2CON - Unimplemented - Unimplemented - Unimplemented
  1400.     MOVLW 0x00
  1401.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  1402.     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1403.     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1404.     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1405.     BSF LRAM_0x37,0
  1406.     BCF LRAM_0x3A,0
  1407.     MOVLW 0x00
  1408.     MOVWF CCP1CON        ; !!Bank!! CCP1CON - Unimplemented - Unimplemented - Unimplemented
  1409.     MOVLW 0x00
  1410.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  1411.     MOVLW 0x00
  1412.     MOVWF CCP2CON        ; !!Bank!! CCP2CON - Unimplemented - Unimplemented - Unimplemented
  1413.     MOVLW 0x00
  1414.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  1415.     BTFSS LRAM_0x3A,7
  1416.     GOTO LADR_0x04DE     ; !!Bank!! 0x04DE - 0x0CDE
  1417.     NOP
  1418.     BCF PORTB,6          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1419.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  1420. LADR_0x04DE
  1421.     NOP
  1422.     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  1423. LADR_0x04E0
  1424.     NOP
  1425.     GOTO LADR_0x00B1     ; !!Bank!! 0x00B1 - 0x08B1
  1426. LADR_0x04E2
  1427.     MOVLW 0x0F
  1428.     MOVWF LRAM_0x20
  1429. LADR_0x04E4
  1430.     DECFSZ LRAM_0x20,F
  1431.     GOTO LADR_0x04E4     ; !!Bank!! 0x04E4 - 0x0CE4
  1432.     RETURN
  1433. LADR_0x04E7
  1434.     MOVWF LRAM_0x25
  1435.     MOVF STATUS,W
  1436.     MOVWF LRAM_0x26
  1437.     MOVF FSR,W
  1438.     MOVWF LRAM_0x27
  1439.     BCF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  1440.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1441.     BTFSS PIR1,0         ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1442.     GOTO LADR_0x0549     ; !!Bank!! 0x0549 - 0x0D49
  1443.     CLRWDT
  1444.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1445.     BTFSC LRAM_0x37,0
  1446.     GOTO LADR_0x0512     ; !!Bank!! 0x0512 - 0x0D12
  1447.     NOP
  1448.     BTFSC LRAM_0x68,0
  1449.     GOTO LADR_0x0507     ; !!Bank!! 0x0507 - 0x0D07
  1450.     NOP
  1451.     DECFSZ LRAM_0x69,F
  1452.     GOTO LADR_0x04FC     ; !!Bank!! 0x04FC - 0x0CFC
  1453.     NOP
  1454.     GOTO LADR_0x0507     ; !!Bank!! 0x0507 - 0x0D07
  1455. LADR_0x04FC
  1456.     BCF LRAM_0x68,0
  1457.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1458.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1459.     BCF INTCON,PEIE
  1460.     BCF INTCON,GIE
  1461.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1462.     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1463.     BSF LRAM_0x68,5
  1464.     MOVLW 0x00
  1465.     MOVWF T1CON          ; !!Bank!! T1CON - Unimplemented - Unimplemented - Unimplemented
  1466.     GOTO LADR_0x0549     ; !!Bank!! 0x0549 - 0x0D49
  1467. LADR_0x0507
  1468.     BSF LRAM_0x68,0
  1469.     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1470.     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  1471.     BCF INTCON,PEIE
  1472.     BCF INTCON,GIE
  1473.     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  1474.     BCF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  1475.     BSF LRAM_0x68,5
  1476.     MOVLW 0x00
  1477.     MOVWF T1CON          ; !!Bank!! T1CON - Unimplemented - Unimplemented - Unimplemented
  1478.     GOTO LADR_0x0549     ; !!Bank!! 0x0549 - 0x0D49
  1479. LADR_0x0512
  1480.     MOVLW 0xFE
  1481.     MOVWF TMR1H          ; !!Bank!! TMR1H - Unimplemented - PMADRH - Unimplemented
  1482.     MOVLW 0x25
  1483.     MOVWF TMR1L          ; !!Bank!! TMR1L - PCON - PMDATH - Unimplemented
  1484.     BTFSS LRAM_0x63,1
  1485.     GOTO LADR_0x052E     ; !!Bank!! 0x052E - 0x0D2E
  1486.     NOP
  1487.     DECFSZ LRAM_0x5B,F
  1488.     GOTO LADR_0x0527     ; !!Bank!! 0x0527 - 0x0D27
  1489.     MOVLW 0x00
  1490.     MOVWF LRAM_0x61
  1491.     MOVLW 0x28
  1492.     MOVWF LRAM_0x5B
  1493.     BCF LRAM_0x63,1
  1494.     BTFSS LRAM_0x63,2
  1495.     GOTO LADR_0x0524     ; !!Bank!! 0x0524 - 0x0D24
  1496.     BCF LRAM_0x63,2
  1497.     GOTO LADR_0x0537     ; !!Bank!! 0x0537 - 0x0D37
  1498. LADR_0x0524
  1499.     BSF LRAM_0x63,2
  1500.     BCF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  1501.     GOTO LADR_0x0537     ; !!Bank!! 0x0537 - 0x0D37
  1502. LADR_0x0527
  1503.     MOVLW 0xD0
  1504.     ADDWF LRAM_0x61,W
  1505.     MOVWF FSR
  1506.     MOVF INDF,W
  1507.     MOVWF LRAM_0x62
  1508.     DECF LRAM_0x61,F
  1509.     GOTO LADR_0x053E     ; !!Bank!! 0x053E - 0x0D3E
  1510. LADR_0x052E
  1511.     DECFSZ LRAM_0x5B,F
  1512.     GOTO LADR_0x0537     ; !!Bank!! 0x0537 - 0x0D37
  1513.     MOVLW 0x27
  1514.     MOVWF LRAM_0x61
  1515.     MOVLW 0x28
  1516.     MOVWF LRAM_0x5B
  1517.     BSF LRAM_0x63,1
  1518.     BSF LRAM_0x63,0
  1519.     GOTO LADR_0x0527     ; !!Bank!! 0x0527 - 0x0D27
  1520. LADR_0x0537
  1521.     MOVLW 0xD0
  1522.     ADDWF LRAM_0x61,W
  1523.     MOVWF FSR
  1524.     MOVF INDF,W
  1525.     MOVWF LRAM_0x62
  1526.     INCF LRAM_0x61,F
  1527.     GOTO LADR_0x053E     ; !!Bank!! 0x053E - 0x0D3E
  1528. LADR_0x053E
  1529.     BTFSS LRAM_0x63,2
  1530.     GOTO LADR_0x0545     ; !!Bank!! 0x0545 - 0x0D45
  1531.     MOVF LRAM_0x62,W
  1532.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  1533.     MOVLW 0x00
  1534.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  1535.     GOTO LADR_0x0549     ; !!Bank!! 0x0549 - 0x0D49
  1536. LADR_0x0545
  1537.     MOVF LRAM_0x62,W
  1538.     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  1539.     MOVLW 0x00
  1540.     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  1541. LADR_0x0549
  1542.     MOVF LRAM_0x27,W
  1543.     MOVWF FSR
  1544.     MOVF LRAM_0x26,W
  1545.     MOVWF STATUS
  1546.     MOVF LRAM_0x25,W
  1547.     RETFIE
  1548.     ADDLW 0xFF
  1549.     ADDLW 0xFF
  1550.     ADDLW 0xFF
  1551.     ADDLW 0xFF
  1552.     ADDLW 0xFF
  1553.     ADDLW 0xFF
  1554.     ADDLW 0xFF
  1555.     ADDLW 0xFF
  1556.     ADDLW 0xFF
  1557.     ADDLW 0xFF
  1558.     ADDLW 0xFF
  1559.     ADDLW 0xFF
  1560.     ADDLW 0xFF
  1561.     ADDLW 0xFF
  1562.     ADDLW 0xFF
  1563.     ADDLW 0xFF
  1564.     ADDLW 0xFF
  1565.     ADDLW 0xFF
  1566.     ADDLW 0xFF
  1567.     ADDLW 0xFF
  1568.     ADDLW 0xFF
  1569.     ADDLW 0xFF
  1570.     ADDLW 0xFF
  1571.     ADDLW 0xFF
  1572.     ADDLW 0xFF
  1573.     ADDLW 0xFF
  1574.     ADDLW 0xFF
  1575.     ADDLW 0xFF
  1576.     ADDLW 0xFF
  1577.     ADDLW 0xFF
  1578.     ADDLW 0xFF
  1579.     ADDLW 0xFF
  1580.     ADDLW 0xFF
  1581.     ADDLW 0xFF
  1582.     ADDLW 0xFF
  1583.     ADDLW 0xFF
  1584.     ADDLW 0xFF
  1585.     ADDLW 0xFF
  1586. …………
  1587. …………
  1588. …………限于本文篇幅 余下代碼請從51黑下載附件…………
所有資料51hei提供下載,僅供參考,如有錯誤請指出大家一起討論:
程序文件.zip (546.95 KB, 下載次數: 353)
pcb原理圖工程文件 DDB文件.zip (1.41 MB, 下載次數: 363)
收藏收藏12 分享淘帖 頂 踩
ID:267435 發表于 2018-7-10 08:15 | 只看該作者
有線路板嗎
有線路板嗎
ID:407930 發表于 2018-11-15 14:56 來自觸屏版 | 只看該作者
謝謝分享
ID:140183 發表于 2018-11-24 12:56 | 只看該作者
很好的資料。。。!
ID:420836 發表于 2018-12-9 04:01 | 只看該作者
謝謝分享
ID:426889 發表于 2018-12-12 19:14 | 只看該作者
謝謝樓主分享
ID:487288 發表于 2019-3-9 11:12 | 只看該作者
太好了
ID:47528 發表于 2019-4-26 12:35 | 只看該作者
資料不完整.
ID:446841 發表于 2019-5-22 10:39 | 只看該作者
匯編看不懂 看不懂
ID:12417 發表于 2019-5-24 02:19 | 只看該作者
謝謝分享1
ID:526735 發表于 2019-5-25 09:10 | 只看該作者
匯編的,和Microchip官網上那個例子有區別嗎?看起來好像代碼量比那個例子要多。
ID:487288 發表于 2019-8-20 09:08 | 只看該作者
咋了啊,能用不
ID:593904 發表于 2019-8-21 03:17 | 只看該作者
亂七八糟的,也不注釋一下,這樣學做一樣東西要花太多時間!誤人子弟…資料不完整……………
ID:140183 發表于 2019-12-22 10:52 | 只看該作者
源程序全是亂碼?
ID:511461 發表于 2020-7-31 10:51 | 只看該作者
表示匯編完全看不懂
ID:137526 發表于 2020-10-11 16:31 | 只看該作者
表示匯編完全看不懂
ID:242092 發表于 2020-12-1 13:51 | 只看該作者
這樣學做一樣東西要花太多時間!
ID:169756 發表于 2021-1-15 15:18 | 只看該作者
工頻逆變器,有一個50Hz的大變壓器
ID:137526 發表于 2021-2-15 18:40 | 只看該作者
如果有C源碼那就好了 匯編看起來太吃力了
ID:691573 發表于 2021-7-14 20:45 | 只看該作者
看不懂啊。。。。
ID:23844 發表于 2021-7-19 06:59 | 只看該作者
匯編大神再現江湖
ID:550077 發表于 2021-10-1 17:21 | 只看該作者
資料不完整,原理圖與PCB對不上,拼湊的大雜燴!!!
ID:531743 發表于 2021-11-6 10:13 | 只看該作者
不錯的資料,可以參考學習
ID:66500 發表于 2022-5-3 21:32 | 只看該作者
很多年沒有去碰匯編了,不太想看了
ID:77589 發表于 2022-11-30 16:16 | 只看該作者
匯編寫的,牛逼
ID:71952 發表于 2022-12-6 13:33 | 只看該作者
不錯的資料,可以參考學習
ID:582276 發表于 2023-9-22 13:42 | 只看該作者
剛弄一個項目,參考參參考。
ID:7199 發表于 2023-10-28 14:36 | 只看該作者
匯編頭疼
ID:1068410 發表于 2024-11-15 18:00 | 只看該作者
看起來頭大,
ID:325646 發表于 2025-1-11 17:21 | 只看該作者
不錯的資料,可以參考學習
