查看: 3320|回復: 0
數碼管的動態顯示
ID:70976 發表于 2014-12-27 13:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/*數碼管的動態顯示不是那么難,只要屢敗屢戰就好*/
#include<reg52.h>
#define unit unsigned int
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar code tableduan[]={
0xfe,0xfd,0xfb,
uchar a,b,c;
  TMOD=1;
  TH0=(65536-1000)/256;
  TL0=(65536-1000)%256;
  EA=1;  //開中斷
   ET0=1;  //開定時器中斷;
  TR0=1;  //開定時器;
  a=0;
  b=0;
  c=0;
     if(a==5)
       a=0;
       P0=tableduan[c];
       c++;
       P2=table[b++];
          if(c==3)
              c=0;
              b=0;
void time_0() interrupt 1
  a++;
