查看: 4463|回復(fù): 0
STM32F103程序 兩個(gè)燈一亮一滅,每按一下開關(guān),兩個(gè)燈的亮滅狀態(tài)翻轉(zhuǎn)
ID:770730 發(fā)表于 2020-6-5 21:41 | 顯示全部樓層 |閱讀模式
STM32F103設(shè)計(jì)電路,在GPIO C口,分別接有一個(gè)開關(guān)K1和兩個(gè)指示燈LED1和LED2。兩個(gè)燈一亮一滅,每按一下開關(guān),兩個(gè)燈的亮滅狀態(tài)翻轉(zhuǎn)
#include"stm32f10x.h"
/*pc5green,6red,10button*/
void LED_Init(void)
{RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_5|GPIO_Pin_6;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode= GPIO_Mode_Out_PP;//輸出模式
GPIO_Init(GPIOC,&GPIO_InitStructure);
void KEY_Init(void)
//定義一個(gè)GPIO_InitTypeDef類型的結(jié)構(gòu)體
GPIO_InitTypeDefGPIO_InitStructure;
//開啟GPIO相關(guān)的外設(shè)時(shí)鐘
//選擇要控制的GPIO引腳
GPIO_InitStructure.GPIO_Pin= GPIO_Pin_10;
//設(shè)置GPIO引腳的輸入模式
GPIO_InitStructure.GPIO_Mode= GPIO_Mode_IPU;//高電平
//調(diào)用庫函數(shù)初始化GPIO
int main(void)
{int i;
    LED_Init();
  KEY_Init();
GPIO_ResetBits(GPIOC,GPIO_Pin_5);//green亮
        GPIO_WriteBit(GPIOC,GPIO_Pin_6,Bit_SET);//red滅
    while(1){
        if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))
                GPIO_WriteBit(GPIOC,GPIO_Pin_5,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_5)));
                 for(i=0;i<500000;i++) { } ;
             GPIO_WriteBit(GPIOC,GPIO_Pin_6,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_6)));
                    for(i=0;i<500000;i++) { };
