STM32單片機源程序如下:
- /* Includes 包含庫函數操作的文件---------------------------------------------------*/
- #include "main.h"
- /*Include SYSTEM 包含操作寄存器的頭文件-------------*/
- #include "sys.h"
- #include "delay.h"
- #include "PWM.h"
- /*Include linye 包含用戶linye的文件-----------*/
- #include "key.h"
- #include "led.h"
- #include "exit.h"
- #include "adc.h"
- #include "time.h"
- #include "Adjust.h"
- #define ADC1_DR_Address ((u32)0x4001244C)
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- static vu32 TimingDelay = 0;
- ErrorStatus HSEStartUpStatus = SUCCESS;
- DMA_InitTypeDef DMA_InitStructure;
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- void RCC_Configuration(void);
- void NVIC_Configuration(void);
- void GPIO_Configuration(void);
- void DMA_Configuration(void);
- void ADC_Configuration(void);
- void TIM_Configuration(void);
- * Function Name : main
- * Description : Main program.
- * Input : None
- * Output : None
- * Return : None
- u8 Counter_1mS;
- u8 Counter_100mS;
- u8 Flag_1mS;
- u8 Flag_100mS;
- u8 Flag_1S;
- float Current_set=0.1,Pv; //設定的電流值(范圍是0.1-0.8A 步進0.05A),Pv是PID返回值
- u16 U_Set_adcvalue; //設定的電流值轉化成ADC值
- u16 CCR1_Val; // PWM的設定值
- u16 ADCConvertedValue; //ADC返回的值
- u8 PIDStart=1; //PID調節(jié)使能標識
- u8 x=0,y=0;
- u16 ADCConvertedValue_100[100];
- u32 ADCConvertedValue_ave;
- int main(void)
- #ifdef DEBUG
- debug();
- #endif
- /* System clocks configuration ---------------------------------------------*/
- RCC_Configuration(); //配置時鐘
- /* NVIC configuration ------------------------------------------------------*/
- NVIC_Configuration(); //配置串口中斷
- /* GPIO configuration ------------------------------------------------------*/
- GPIO_Configuration();
- USART1_Configuration(); //配置串口 在本文件中
- /* Configure the systick */
- SysTick_Config();
- /* Initialize the LCD */
- STM3210E_LCD_Init();
- /*以下是配置直接操作寄存器的文件--------------*/
- led_init();
- //key_init();
- delay_init(72);
- Exit_Init();
- Timer2_Init(10,7200);
- DMA_Configuration();
- ADC_Configuration();
- TIM_Configuration();
- /* Clear the LCD */
- LCD_Clear(White);
- LCD_SetBackColor(White);
- LCD_SetTextColor(Blue);
- LCD_DisplayHZLine(Line0,5,"PID恒流源控制系統(tǒng)");
- LCD_DisplayStringLine(Line1,0,"ADCConvertedValue:");
- LCD_DisplayStringLine(Line2,0,"Current_set:");
- LCD_DisplayStringLine(Line2,22,"A");
- LCD_DisplayStringLine(Line3,0,"U_Set_adcvalue:");
- LCD_DisplayStringLine(Line4,0,"CCR1_Val:");
- while (1)
- U_Set_adcvalue=Current_set*3474.55; //=(Current_set*2.94*4095)/0.8*3.3
- if(Flag_100mS==1)
- LCD_DisplayU16Line(Line1,18,(u16)ADCConvertedValue_ave,0);
- LCD_DisplayU16Line(Line1,24,(u16)((ADCConvertedValue_ave*330)/4095),2);
- LCD_DisplayU16Line(Line2,18,(u16)(Current_set*100),2);
- LCD_DisplayU16Line(Line3,18,U_Set_adcvalue,0);
- LCD_DisplayU16Line(Line3,24,(U_Set_adcvalue*33)/4095,1);
- LCD_DisplayU16Line(Line4,18,CCR1_Val,0);
- LCD_DisplayU16Line(Line7,18,ADCConvertedValue,0);
- if(PIDStart==1)
- if(U_Set_adcvalue-(u16)ADCConvertedValue_ave>=15||U_Set_adcvalue-(u16)ADCConvertedValue_ave<=-15)
- Pv=Vol(U_Set_adcvalue,(u16)ADCConvertedValue_ave);
- CCR1_Val=CCR1_Val+Pv/0.34; //0.68=4095/3000*2
- if(CCR1_Val>=11999)
- CCR1_Val=11999;
- else if(CCR1_Val<=1)
- CCR1_Val=1;
- TIM3->CCR1=CCR1_Val;
- Flag_100mS=0;
- if(Flag_1mS==1)
- ADCConvertedValue_100[x]=ADCConvertedValue;
- x=x+1;
- if(x==100)
- x=0;
- for(y=0;y<100;y++)
- ADCConvertedValue_ave+=ADCConvertedValue_100[y];
- ADCConvertedValue_ave=ADCConvertedValue_ave/101;
- Flag_1mS=0;
- * Function Name : RCC_Configuration
- * Description : Configures the different system clocks.
- * Input : None
- * Output : None
- * Return : None
- /* RCC system reset(for debug purpose) */
- RCC_DeInit();
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- /* Wait till HSE is ready */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)
- /* Enable Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
- /* Flash 2 wait state */
- FLASH_SetLatency(FLASH_Latency_2);
- /* HCLK = SYSCLK */
- RCC_HCLKConfig(RCC_SYSCLK_Div1);
- /* PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);
- /* PCLK1 = HCLK/2 */
- RCC_PCLK1Config(RCC_HCLK_Div2);
- /* ADCCLK = PCLK2/4 */
- RCC_ADCCLKConfig(RCC_PCLK2_Div4);
- /* PLLCLK = 8MHz * 9 = 72 MHz */
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
- /* Enable PLL */
- RCC_PLLCmd(ENABLE);
- /* Wait till PLL is ready */
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
- /* Select PLL as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- /* Wait till PLL is used as system clock source */
- while(RCC_GetSYSCLKSource() != 0x08)
- /* Enable peripheral clocks --------------------------------------------------*/
- /* Enable DMA1 clock */
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2|RCC_APB1Periph_TIM3, ENABLE);
- /* Enable GPIOx clock */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
- * Function Name : NVIC_Configuration
- * Description : Configures Vector Table base location.
- * Input : None
- * Output : None
- * Return : None
- //#ifdef VECT_TAB_RAM
- // /* Set the Vector Table base location at 0x20000000 */
- // NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
- //#else /* VECT_TAB_FLASH */
- // /* Set the Vector Table base location at 0x08000000 */
- // NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
- //#endif
- NVIC_InitTypeDef NVIC_InitStructure;
- /* Set the Vector Table base location at 0x08000000 */
- NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
- /* Configure the NVIC Preemption Priority Bits */
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
- /* Enable the USART1 Interrupt */
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel; //通道設置為串口1中斷
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //中斷響應優(yōu)先級0
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //打開中斷
- NVIC_Init(&NVIC_InitStructure); //初始化
- * Function Name : GPIO_Configuration
- * Description : Configures the different GPIO ports.
- * Input : None
- * Output : None
- * Return : None
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Configure PG.08 as input */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- GPIO_Init(GPIOG, &GPIO_InitStructure);
- /* Configure PB.01 (ADC Channel9) as analog input -------------------------*/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull| GPIO_Pin_7 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 ;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- * Function Name : SysTick_Config
- * Description : Configure a SysTick Base time to 10 ms.
- * Input : None
- * Output : None
- * Return : None
- void SysTick_Config(void)
- /* Configure HCLK clock as SysTick clock source */
- SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);
- /* SysTick interrupt each 100 Hz with HCLK equal to 72MHz */
- SysTick_SetReload(720000);
- /* Enable the SysTick Interrupt */
- SysTick_ITConfig(ENABLE);
- 函數名:USART1_Configuration
- 輸 入:
- 輸 出:
- 功能說明:
- 初始化串口硬件設備,啟用中斷
- 配置步驟:
- (1)打開GPIO和USART1的時鐘
- (2)設置USART1兩個管腳GPIO模式
- (3)配置USART1數據格式、波特率等參數
- (4)使能USART1接收中斷功能
- (5)最后使能USART1功能
- void USART1_Configuration(void)
- USART_InitTypeDef USART_InitStructure;
- /* 第1步:打開GPIO和USART部件的時鐘 */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
- /* 第2步:將USART Tx的GPIO配置為推挽復用模式 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- /* 第3步:將USART Rx的GPIO配置為浮空輸入模式
- 由于CPU復位后,GPIO缺省都是浮空輸入模式,因此下面這個步驟不是必須的
- 但是,我還是建議加上便于閱讀,并且防止其它地方修改了這個口線的設置參數
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
- /* 第3步已經做了,因此這步可以不做
- /* 第4步:配置USART1參數
- - BaudRate = 115200 baud
- - Word Length = 8 Bits
- - One Stop Bit
- - No parity
- - Hardware flow control disabled (RTS and CTS signals)
- - Receive and transmit enabled
- USART_InitStructure.USART_BaudRate = 9600;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- USART_Init(USART1, &USART_InitStructure);
- /* 若接收數據寄存器滿,則產生中斷 */
- USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
- /* 第5步:使能 USART1, 配置完畢 */
- USART_Cmd(USART1, ENABLE);
- /* 如下語句解決第1個字節(jié)無法正確發(fā)送出去的問題 */
- USART_ClearFlag(USART1, USART_FLAG_TC); // 清標志
- /* STM32向串口1發(fā)送1字節(jié) */
- void Uart1_PutChar(u8 ch)
- USART_SendData(USART1, (u8) ch);
- while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
- * Function Name : Delay
- * Description : Inserts a delay time.
- * Input : nCount: specifies the delay time length (time base 10 ms).
- * Output : None
- * Return : None
- void Delay(u32 nCount)
- TimingDelay = nCount;
- /* Enable the SysTick Counter */
- SysTick_CounterCmd(SysTick_Counter_Enable);
- while(TimingDelay != 0)
- /* Disable the SysTick Counter */
- SysTick_CounterCmd(SysTick_Counter_Disable);
- /* Clear the SysTick Counter */
- SysTick_CounterCmd(SysTick_Counter_Clear);
- * Function Name : Decrement_TimingDelay
- * Description : Decrements the TimingDelay variable.
- * Input : None
- * Output : TimingDelay
- * Return : None
- void Decrement_TimingDelay(void)
- if (TimingDelay != 0x00)
- TimingDelay--;
- /* DMA1 channel1 configuration ----------------------------------------------*/
- DMA_DeInit(DMA1_Channel1);
- DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
- DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADCConvertedValue;
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
- DMA_InitStructure.DMA_BufferSize = 1;
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
- DMA_InitStructure.DMA_Priority = DMA_Priority_High;
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
- DMA_Init(DMA1_Channel1, &DMA_InitStructure);
- /* Enable DMA1 channel1 */
- DMA_Cmd(DMA1_Channel1, ENABLE);
- ADC_InitTypeDef ADC_InitStructure;
- /* ADC1 configuration ------------------------------------------------------*/
- ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
- ADC_InitStructure.ADC_ScanConvMode = ENABLE;
- ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
- ADC_InitStructure.ADC_NbrOfChannel = 1;
- ADC_Init(ADC1, &ADC_InitStructure);
- /* ADC1 regular channel9 PB1 configuration */
- ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 1, ADC_SampleTime_55Cycles5);
- /* Enable ADC1 DMA */
- ADC_DMACmd(ADC1, ENABLE);
- /* Enable ADC1 */
- ADC_Cmd(ADC1, ENABLE);
- /* Enable ADC1 reset calibaration register */
- ADC_ResetCalibration(ADC1);
- /* Check the end of ADC1 reset calibration register */
- while(ADC_GetResetCalibrationStatus(ADC1));
- /* Start ADC1 calibaration */
- ADC_StartCalibration(ADC1);
- /* Check the end of ADC1 calibration */
- while(ADC_GetCalibrationStatus(ADC1));
- /* Start ADC1 Software Conversion */
- ADC_SoftwareStartConvCmd(ADC1, ENABLE);
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- TIM3 Configuration: generate 4 PWM signals with 4 different duty cycles:
- TIM3CLK = 36 MHz, Prescaler = 0x0, TIM3 counter clock = 36 MHz
- TIM3 ARR Register = 999 => TIM3 Frequency = TIM3 counter clock/(ARR + 1)
- TIM3 Frequency = 36 KHz.
利用stm32實現PID 恒流源控制.7z
(632.45 KB, 下載次數: 294)
2019-4-23 18:05 上傳
