查看: 2124|回復: 1
睡眠-喚醒定時器
ID:350005 發表于 2018-7-17 15:47 | 顯示全部樓層 |閱讀模式
#define MAIN_Fosc                22118400L        //定義主時鐘
#include        "STC15Fxxxx.H"
#define DIS_DOT                0x20
#define DIS_BLACK        0x10
#define DIS_                0x11
/****************************** 用戶定義宏 ***********************************/
#define                Timer0_Reload        (65536UL -(MAIN_Fosc / 1000))                //Timer 0 中斷頻率, 1000次/秒
/*************        本地常量聲明        **************/
u8 code t_display[]={                                                //標準字庫
//         0    1    2    3    4    5    6    7    8    9    A    B    C    D    E    F
        0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71,
//black         -     H    J         K          L           N        o   P         U     t    G    Q    r   M    y
        0x00,0x40,0x76,0x1E,0x70,0x38,0x37,0x5C,0x73,0x3E,0x78,0x3d,0x67,0x50,0x37,0x6e,
        0xBF,0x86,0xDB,0xCF,0xE6,0xED,0xFD,0x87,0xFF,0xEF,0x46};        //0. 1. 2. 3. 4. 5. 6. 7. 8. 9. -1
u8 code T_COM[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};                //位碼
/*************        IO口定義        **************/
sbit        P_HC595_SER   = P4^0;        //pin 14        SER                data input
sbit        P_HC595_RCLK  = P5^4;        //pin 12        RCLk        store (latch) clock
sbit        P_HC595_SRCLK = P4^3;        //pin 11        SRCLK        Shift data clock
/*************        本地變量聲明        **************/
u8         LED8[8];                //顯示緩沖
u8        display_index;        //顯示位索引
u16        msecond;                //1000ms計數
u8        Test_cnt;        //測試用的秒計數變量
u8        SleepDelay;        //喚醒后再進入睡眠所延時的時間
void        delay_ms(u8 ms);
void         DisplayScan(void);
void        SetWakeUpTime(u16 SetTime);
/********************** 主函數 ************************/
void main(void)
        u8        i;
        P0M1 = 0;        P0M0 = 0;        //設置為準雙向口
        P1M1 = 0;        P1M0 = 0;        //設置為準雙向口
        P2M1 = 0;        P2M0 = 0;        //設置為準雙向口
        P3M1 = 0;        P3M0 = 0;        //設置為準雙向口
        P4M1 = 0;        P4M0 = 0;        //設置為準雙向口
        P5M1 = 0;        P5M0 = 0;        //設置為準雙向口
        P6M1 = 0;        P6M0 = 0;        //設置為準雙向口
        P7M1 = 0;        P7M0 = 0;        //設置為準雙向口
        display_index = 0;
        for(i=0; i<8; i++)        LED8[i] = DIS_BLACK;        //全部消隱
        Test_cnt = 0;        //秒計數范圍為0~255
        SleepDelay = 0;
        LED8[5] = 0;
        LED8[6] = 0;
        LED8[7] = Test_cnt;
        EA = 1;                //允許總中斷
                delay_ms(1);        //延時1ms
                DisplayScan();
                if(++msecond >= 1000)        //1秒到
                        msecond = 0;                //清1000ms計數
                        Test_cnt++;                        //秒計數+1
                        LED8[5] = Test_cnt / 100;
                        LED8[6] = (Test_cnt % 100) / 10;
                        LED8[7] = Test_cnt % 10;
                        if(++SleepDelay >= 2)        //2秒后睡眠
                                SleepDelay = 0;
                                P_HC595_SER = 0;
                                for(i=0; i<16; i++)                //先關閉顯示,省電
                                        P_HC595_SRCLK = 1;
                                        P_HC595_SRCLK = 0;
                                P_HC595_RCLK = 1;
                                P_HC595_RCLK = 0;                //鎖存輸出數據
                                SetWakeUpTime(2000);        //2秒后醒來
                                PCON |= 0x02;        //Sleep
                                _nop_();
                                _nop_();
                                _nop_();
// 函數: void        SetWakeUpTime(u16 SetTime)
// 描述: 喚醒定時器設置時間值函數。
// 參數: SetTime: 要設置的時間值(睡眠的時間), 單位為ms.
// 返回: none.
// 版本: VER1.0
// 日期: 2014-7-15
// 備注:
        SetTime = (u16)((32768UL * (u32)SetTime) / 16000);        //重裝值 = Fwkt/16 * SetTime/1000 = Fwkt * SetTime / 16000
        if(SetTime > 0)        SetTime--;
        WKTCL = (u8)SetTime;
        WKTCH = (u8)(SetTime >> 8) | 0x80;
// 函數: void  delay_ms(unsigned char ms)
// 描述: 延時函數。
// 參數: ms,要延時的ms數, 這里只支持1~255ms. 自動適應主時鐘.
// 返回: none.
// 版本: VER1.0
// 日期: 2013-4-1
// 備注:
     u16 i;
         do{
              i = MAIN_Fosc / 13000;
                  while(--i)        ;   //14T per loop
     }while(--ms);
/**************** 向HC595發送一個字節函數 ******************/
void Send_595(u8 dat)
        u8        i;
        for(i=0; i<8; i++)
                dat <<= 1;
                P_HC595_SER   = CY;
                P_HC595_SRCLK = 1;
                P_HC595_SRCLK = 0;
/********************** 顯示掃描函數 ************************/
        Send_595(~T_COM[display_index]);                                //輸出位碼
        Send_595(t_display[LED8[display_index]]);        //輸出段碼
        P_HC595_RCLK = 1;
        if(++display_index >= 8)        display_index = 0;        //8位結束回0
參與人數 1黑幣 +15 收起 理由
564654654 + 15 回帖助人的獎勵!
ID:1 發表于 2018-7-17 23:03 | 顯示全部樓層
本帖補全原理圖和其他資料后可獲得積分
